Same for me.
But BGP drop is fixed in this release. It looks like ![]()
Nop BGP hung up continues, with longer working time, but happens. And caps acts strange, cannot find manager, and comes back only after restart. Best stable at this moment 6.45.3. Of course little bit annoying all the time reverting ![]()
Will rise again this case… which stopped working after 6.44.3 version. And your software upgrade to 6.45.2 didn’t fix this… Maybe someone knows how to fix this or avoid it?
6.45.1
*) ospf - added support for link scope opaque LSAs (Type 9) for OSPFv2;
*) ospf - fixed opaque LSA type checking in OSPFv2;
*) ospf - improved “unknown” LSA handling in
6.45.2
*) ospf - fixed possible busy loop condition when accessing OSPF LSAs;OSPFv3;
Quoted from member → rekeds
Code: Select all
11:36:27 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:36:37 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:37:07 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:37:18 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:37:47 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:37:58 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:38:27 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:38:39 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:39:08 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:39:20 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:39:48 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:40:01 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:40:28 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:40:42 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:41:08 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:41:22 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:41:48 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:42:02 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:42:28 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:42:43 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:43:08 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:43:23 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:43:48 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:44:04 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:44:28 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:44:45 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:45:08 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:45:26 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:45:48 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:46:07 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:46:29 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:46:48 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:47:09 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Way
11:47:29 route,ospf,info OSPFv2 neighbor 10.9.0.1: state change from Loading to 2-Waydowngrade 6.44, ospf works :[
about 20 routers, half was updated, all updated did this. downgrade fixes ;[
ospf with backbone and 23 nssa areas.
two links from bbone to nssa. >> :male_sign:
vrf.edit.
added a nokia to the mix:“LCL_RTR_ID 10.9.0.1: Neighbor 0.0.0.6 on TEST-NBR router state changed to exchangeStart (event SEQ_MISM)” >
Update when smooth, but NAT rules no longer work.
Is that not like saying “The surgery went well but he died”? ![]()
At least for me no NAT rules would mean the update did not go well.
It’s more like coma after surgery as router is still alive ![]()
The time has come for a new certificate, “MikroTik Certified Surgeon” ![]()
MikroTik
Certified
Network
Anesthesiologist
will bring your router back to life
With these ever increasing updates (in size) and ever deceasing flash sizes (64->32->16MB), I feel myself more often as I would wish:
MikroTik
Certified
Network
Pathologist
… when my router does not boot any more after update
Has anyone seen any issues with their Queue Trees?
I have a 1072 that I do both Packet Prioritization via Prerouting Mangle and Rate Limits via Forward Mangle.
If I enable one of the Global Queues in the Queue Tree that I use for Prioritization that exceeds an Avg Rate of 1.2 gbps all the CPU’s spike to 100%, the Queue starts dropping packets, and all the normal bad things happen when you run at 100%. Once I disable the Packet Marking for that particular traffic, the CPU’s drop back to normal and run at their normal average. The rules and queue setup that I’m using is a couple years old and the traffic patterns have been similar for 6+ months. This seems to be an issue introduced in 6.45.6.
I have trouble with kid control, it doesn’t add firewall rules anymore.
Tested on two hAP ac lites.
Uptime 12 days x86. No problems.
KID control NOT WORKING after update to 6.45.6.
firewall filter rules not installed
My router is RB2011UiaS
Hi Guys!
I need help, I got an RB4011, it’s currently running on 6.44.1, I have tried installing the latest version on it 6.45.6 but it’s not working. I tried hitting the “Download” which usually end’s up with “reboot to upgrade” but the RB4011 reboots automatically. I tried “Download and Install” after the download, it reboots but it stays on the same 6.44.1 firmware. What am I doing wrong?
Thanks in Advance!
Manny
I setup yesterday Kid Control on 6.45.6 on RB4011 and it was working well (IP Firewall rules went on and off according to setup),
also used TIKApp for pause/resume.
Maybe your setup from pre-6.45.6 does not migrate correctly to 6.45.6?
First, check the Log after reboot.
Thankyou very much, was my fault, error in user name.
Kid control works now flawlessy in 6.45.6 on RB2011.
Regards
I used system/reset-configuration and tryed again with export compact / import configuration - doesn’t work.
I used system/reset-configuration and manually configured settings - doesn’t work.
Then used the reset button and manually configured settings - nope still doesn’t work.
I happy to tell cAP AC users.
Before the upgrade (I used 6.43.2), even connect 20 iPad at 5G.
They cannot pass the upload and download test simultaneously. They will disconnect when the test started.
After I upgrade to 6.45.6, I discover that the performance issue of cAP AC have been solved.
Now I can connect over 80 iPad to the cAP AC (5G) with no problem ! I haven’t tested the highest limit.
And the performance is not bad, that is about 200Mbps with 40 iPad client simultaneously at 5G.
And even the signal at -80 or worst. The connection is so stable.
Can you tell me what the 6.45.2 do ?
*) wireless - improved 802.11ac stability for all ARM devices with wireless;
Hi.
Updated my RB2011. After upgrade, I must adjust scripts.
In 6.40.9, the command:
:local localIP [:pick [/interface pppoe-client monitor PPPoE-Digi as-value] 6;];
worked well.
In 6.45.6, it waits forever.
The correct line is:
:local localIP [:pick [/interface pppoe-client monitor PPPoE-Digi once as-value] 6;];
works again.
Best regards: CsXen
