v6.45.6 [stable] is released!
This makes it even more future-proof:
:local localIP ([/interface pppoe-client monitor PPPoE-Digi once as-value]->"local-address");
Hello.
D402 LTE modem is not detected in interfaces (HAP ac), but router detects a folder in Files.
this version hotspot redirect is not working in hap lite RB941,
but working in RB951.
Router: CCR1009
Problems:
PPPoE server running on router, after 7 days uptime start’s to loose clients (disconnection messages and full breakdown)
OSPF from full to down and after 5 minutes it come’s back to full.
SNMP over Librenms Sensor under limit for FAN rpm’s (it goes to 0 from7500 rpm)
I saw some wierd log errors (script error contact support, system failure, please send supout file to mikrotik support.)
Have you done that already?
DUDE Server looses connection to some Agents running 6.45.6 like every 2-10 minutes, but reconnects succesfully after one or two seconds.
I don’t think it’s a network issue, there is a packet loss of 0.1% out of 1000 packets sent.
Yes I’ve done it already
After upgrade from 6.45.3 to 6.45.6, my vpn doesn’t work correctly. Before my iPhone connect to my vpn without problems and work really good, now i get a notification “user authentication failed” in MT logs
log content
22:10:41 ipsec,info new ike2 SA (R): 192.168.100.6[500]-94.254.xxx.xxx[55669] spi:836b5e5dbcfcb0ee:407ceb47da6f8661
22:10:41 ipsec,info,account peer authorized: 192.168.100.6[4500]-94.254.xxx.xxx[22112] spi:836b5e5dbcfcb0ee:407ceb47da6f8661
22:10:41 ipsec,info acquired 192.168.13.253 address for 94.254.xxx.xxx, iPhone.client
SOLVED - it was my fault (/ppp l2tp-secret was added mistakenly)
after upgrade windows clients lost ability to connect to any VPN (pptp and l2tp)
RB2011 says LCP ConfRej anyway, any settings I do it looks the same, look below
Oct 21 14:43:16 mikrotik.m66.officeburg.ru pptp,ppp,debug,packet m66: <17>: rcvd LCP ConfReq id=0x6
Oct 21 14:43:16 mikrotik.m66.officeburg.ru pptp,ppp,debug,packet m66: <mru 1400>
Oct 21 14:43:16 mikrotik.m66.officeburg.ru pptp,ppp,debug,packet m66: <magic 0x425c5319>
Oct 21 14:43:16 mikrotik.m66.officeburg.ru pptp,ppp,debug,packet m66: <callback 0x06>
Oct 21 14:43:16 mikrotik.m66.officeburg.ru pptp,ppp,debug,packet m66: <17>: sent LCP ConfRej id=0x6
SOLVED (removed wireless-fp...npk from /file)
Please! I need urgent help - after upgrade wireless interfaces disappeared, no wireless options available
[asurkov@m66.officeburg.ru] /interface>
bonding          eoip      l2tp-client  mesh         ppp-server    pptp-server  virtual-ethernet  blink    enable           print
bridge           ethernet  l2tp-server  ovpn-client  pppoe-client  sstp-client  vlan              comment  export           reset-counters
detect-internet  gre       list         ovpn-server  pppoe-server  sstp-server  vpls              disable  find             set
dot1x            ipip      lte          ppp-client   pptp-client   traffic-eng  vrrp              edit     monitor-traffic
and where is wireless npks on file storage
[...] > file print detail where name~"wireless*"
 0 name="wireless-fp-6.45.6-mipsbe.npk" type="package" size=2748.1KiB creation-time=oct/17/2019 18:53:42 package-name="wireless@"
   package-version="6.45.6" package-build-time=sep/10/2019 09:06:31 package-architecture="mips"
 1 name="wireless-6.45.6-mipsbe.npk" type="package" size=2748.1KiB creation-time=oct/17/2019 18:54:18 package-name="wireless@"
and I've rebooted it many times
[...] > /system resource print
                   uptime: 5h31m20s
                  version: 6.45.6 (stable)
               build-time: Sep/10/2019 09:06:31
              free-memory: 75.6MiB
             total-memory: 128.0MiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 9%
           free-hdd-space: 26.5MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 9874
         write-sect-total: 8580777
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB2011UiAS-2HnD
                 platform: MikroTik
What does /log print say after reboot? What does /system package print show?
Hi!
After upgrading from 6.44.1 to 6.45.6 it’s not possible to disable dhcp package. RouterBOARD 750G r3. Why?
Flags: X - disabled
 #   NAME                                                VERSION                                                SCHEDULED
 0   routeros-mmips                                      6.45.6
 1   system                                              6.45.6
 2 X ipv6                                                6.45.6
 3 X wireless                                            6.45.6
 4 X hotspot                                             6.45.6
 5 X mpls                                                6.45.6
 6   routing                                             6.45.6
 7 X ppp                                                 6.45.6
 8   dhcp                                                6.45.6
 9   security                                            6.45.6
10   advanced-tools                                      6.45.6
11   ntp                                                 6.45.6
Thank you in advance.
Because since 6.45.whatever, package security requires package dhcp to provide a route list to windows IKEv2 clients.
Thanks! It would be nice to see such things in changelogs or somewhere in wiki like ‘package dependencies’.
Look again, it is there (in the changelog of the release which has introduced this dependency) and it has also been mentioned multiple times in these “x.xx.x has been released” topics.
Ok. Got it. It was introduced in the 6.44. But in my router with 6.44.1 dhcp was disabled (though security was enabled). Interesting…
Hey guys,
I have two separate wireless p2p links, Link1: two sxtlight5nd routers, Link2: two LHG5 routers
After upgrading from 6.43.x to 6.45.6 i noticed both links now have packet drops(ping drops) on both links, nothing else changed but routeros version.
On LHG link sometimes the wireless link completely drops so i have to reboot one of them.
On SXT link the connection remain stable but now my VoIP fxo-fxs over this link experience voice drops and i can’t talk to the other side very well.
Anyone else have these problems?
How can i downgrade to latest Long-Term version or 6.43.x? Is it possible?
hi
we have dhcp-server behind cisco router (dhcp-relay server)
after upgrade dhcp-server stops giving leases and fills leases with mac-address 00:00:00:00:00:00 and status conflict
disabling conflict detection resolves the issue
New version 6.45.7 has been released in stable RouterOS channel:
http://forum.mikrotik.com/t/v6-45-7-stable-is-released/134262/1
