v6.46.1 [stable] is released!
strods That is correct, /system check-installation fails after I update my RB850Gx2 to 6.46 or 6.46.1. In Winbox the error is “Couldn’t continue - damaged routeros-powerpc package: bade image (6).” I think the wording is slightly different at the command line.
So far it’s only been a problem with 6.46 and 6.46.1, and only on a RB850Gx2 (I only have one RB850Gx2, so I can’t say if it’s this particular router or not). I have a RB750GL and NetMetal5, neither of which have had a problem with 6.46 or 6.46.1.
After upgrade my usb modem on RB951-2n not working?
It sat it is connected but no data at all :frowning:
Hi!
What is an “unregistered interface”?
*) ipsec - improved system stability when processing decrypted packet on unregistered interface;
skurudo - It was not possible to upgrade CAPs from the CAPsMAN if “.npk” files were on the root folder.
leonardogyn - Will be fixed in the next release.
osc86 - Can you please try to generate supout file, while the problem is present on your device? If you manage to do so, then send this file to support@mikrotik.com. If not, then generate file after reboot and send it to us.
shahani, nmt1900, Jimmy - Please send supout file to support@mikrotik.com.
anav - What is the wireless problem that you refer to? Have you reported this to support@mikrotik.com?
bcall - This problem will be resolved in the next release.
dnordenberg - Interface which is already closed/removed/disconnected.
Updated 3xHap AC 6.46 → 6.46.1 - so far without issues
Updated 3xHap AC Lite 6.46 → 6.46.1 - No issues, I’m using CAPSMAN but this upgrade was done manually
Thanks!
RB951Ui-2HnD was bricked after upgrade 6.45.7 → 6.46.1.
Very sad :frowning:
HapAc,wireless is no good,ping 11,12,18,speed is poor!!!
Now it looks like problems are somehow related to wireless and/or CAPsMAN - at least when router is mmips and access point is mipsbe architecture. Both had to be downgraded to 6.45.7 to regain normal operation. Only switch in between works fine with 6.46.1.
Let’s see what developers can dig out from these supouts…
You are not paying attention dear Sir/Maam. I didnt upgrate to 6.46 due to the reported WiFI problems in the thread. Further, there was nothing in the update notes to .1, that indicated any work had been done to rectify the issues. Finally, and clearly I have no inclination to upgrade to 6.46.1 based on the feedback on this thread.
By the way, perhaps not an Latvian expression, but having your avatars as nothing but bird heads (big or small) only leads in one direction.
“Putnu smadzenes” :wink:
6.46.1 RBSXTLTE3-7 gsm and 3g are always active. Unable to disable. You cannot leave the LTE range active.
6.45.7 rules
In versions 6.46 and 6.46.1, Omnitik and LHG series constantly began to receive the error in the photograph and often began to see this problem many times during the day reboot devices
962UiGS-5HacT2HnT => The new release pissed me off more then the law allow…
Just to resume:
after upgrade from 6.45.7
  • NONE of devices could connect on 5g interface
  • performance of 2.4G was mediocre,
  • got intermittent disconnect of a direct cable connection between the hap-ac and computer.
  • after restart of the hap-ac I was able to see 5g interface but only for a few seconds
    -so the device was close to be bricked.
To overcome this “featured” release I had to try previous releases: 6.45.7 and 6.44 LTS both behaving as expected.
system->auto-upgrade was broke starting 6.46 til 6.46.1 please fix it
Yesterday my RB4011iGS freeze without any reason.
Log did not capture anything.
All eth led are on but i cant login with any method (IP, mac).
The only solution was to restart with power supply.
Is this relative with that.
When can we expect this fix to be released? It’s for us an important issue.
I had the same problem and had to unplugged the power supply . 6.46 is perfect for me. I downgraded.
RB1100ahx2
6.45.7->6.46.1
Upgrade via winbox (system-packages)
Upgrade went seemingly ok, rebooted fine and all packages were displayed as 6.46.1
But clicking on “check installation”, got message “system package damaged”.
Reverted back to 6.45.7 → “check installation” ok again.
Tried upgrading several times, 100% reproducible.
Tested on multiple rb1100AHX2’s, it’s no hardware defect.
This error was already present in 6.46, but is still not fixed!!!
Also people with other ppc Rb’s are reporting this, and reported it at 6.46 already too.
Apparently nobody at MT cares about simply testing ppc packages/functionality anymore, now that they retired the last ppc-RB recently from their sales-catalog.
Seems that as soon as they stop shipping a particular type, they also stop properly supporting it too…
Maybe a good idea to put less focus on Ros7, and make the current one work properly first???
New features are nice, but I would settle for properly working ‘current’ feature-set.
Getting pretty annoyed by those very simple and avoidable errors lately…
(Rb1100-series) Ppc-devices were high-end and sold until pretty recently.
Not being able to trust even the simplest download package anymore is not a vote of confidence for companies buying more new high-end MT devices.
Or… rename bugfix/longterm in stable, stable into rc, rc into beta, and beta into alpha, and create a new PROPER long-term stream
(longer then the current “long-term” of barely a year, which is actually “short-term” for most professional companies)
@ Strods and Bcall:
This is NOT a rb850-only issue, also on RB1100AHX2.
This points to a PPC issue…
Or better said: a poorly tested 2 releases (6.46 and 6.46.1) for ppc.
If they bothered to even test it, they noticed it themselves.
upgrading my RB1100 (PPC) went flawlessly …
