v6.46.1 [stable] is released!
I have a single RB1100AHX2 and it’s running 6.46.1 just fine. However, funny enough, “Check Installation” is really failing with “damaged routeros-powerpc package: bad image”.
Despite of that failure on check installation, the box is running just fine and i haven’t noticed any problem at all with 6.46 and now 6.46.1.
I’ll have to admit …
I just checked the “Check installation” and it also fails with “damaged routeros-powerpc package: bad image”.
… no problems while running …,
I know it SEEMS to update and run just fine. That;s what was reported by me and others.
But if the system package is really damaged, it’s just waiting for it to crash/fail on some little used function.
Apart from that, this is such a basic test, they (MT) should have tested that themselves before releasing 2 successive versions with this error.
Moreover, the error was reported in 6.46 by more people, but they didn’t even bother to check it before releasing 6.46.1-“so called-stable”.
reading your comment throws up a few questions …
  • DID anyone actually report this to support@mikrotik.com ?
    Just shouting here is useless, this is a userforum and not an official support channel …
And I totally disagree on your statement about testing, the guys at MT perform countless tests on countless problems. After that they release everything in a test channel.
If NOBODY noticed this, it is NOT because MT doesn’t care … It is just because nobody noticed it.
Oh… They (MT) read along… If you follow the “released version” threads a little, you will notice the comments from official MT moderators.
Time and again it’s have been proven that user-comments in the forum are picked up by MT in the next release. And that is great!
The way I saw it here is that I did not need any support from them, they just released a product with a (potentially) corrupt package.
That issue should have definitely been noticed prior to release, since they themselves provide a function to test packages after install.
In winbox it’s a simple button… 3 seconds of work! (In a CLI-script, it’s a simple command, been there for years)
Apparently they didn’t bother…
The forumusers are defacto being used as betatesters of the -so called- stable stream. (that why “Stable”, as a name, makes no sense imho)
So in a way… they are the ones that need support from us for this debug-mechanism to work.
Therefore that is why I report in the forum, not via the support-mail. (but in this case I did anyway, after your comment)
A simple click after installing the packages in winbox would have shown them that there is something seriously wrong. That is the most basic test one can do after installing packages.
If that test is not even done by them, then in my eyes they do not test anywhere near enough before releasing a “stable” version, especially for the now recently retired ppc’s.
This is an avoidable issue, and I should not need to report it at all… Therefore I can only conclude there is insufficient testing being done.
Anyway… I may seem overly critical on this, but I mean well. It’s intended like a wake-up call to make Ros better in future. I really do feel MT screwed things up here.
As far as I’m concerned… enough said about this… I’m sure they picked the issue up by now. :slight_smile:
There are a ton of other issues being reported in the (pretty premature) 6.46.x release so far… So they (MT) have their hands more than full after the holidays.
So please discuss those…
Merry Christmas everyone !!!
Hello, something really weird with 6.46.1
I have all my IPv6 advertisements off, DHCPv6 off, yet my machines are getting IPv6 addresses. This behavior started after the upgrade.
@eddieb, @ozone,
FWIW: Just checked my RB4011, RB2011, PL7411 and RB750U and none of them have this issue. All devices run 6.46.1 [Stable]
@complex1 I also did check all my other devices, no problems on other architectures.
AND,
I just filed a ticket on this issue as it should be done …
@complex1
Thank you for checking and confirming… I didn’t see it on misbe- or arm-arch either… just on our ppc-1100’s.
(and Bcall reported it on a ppc-RB850 as well)
@eddieb
Good!!
Now they have at least 2 of those reports in their mailbox after the holidays. :slight_smile:
Make sure your “bridge” Interface is also turned off in IPv6/ND. Clients receive their address configuration through SLAAC.
my hapac is broken,red light wont flash,and I can not connect with adress 192.168.88.1,only with mac adress,and does not occur home ap dual!!!
What could I do?
revert to 6.44.6 (Long-term) or 6.45.7
I was tormented that her fool was from the provider
but ping however, it is large,12,20!!!
for whatever reason, I use 6.45.7
I have had both omnitik and powerbox pro go into a hard lockup state. Watchdog did not reboot. No romon access. Nothing works until I power cycle it. Too bad they are on top of a mountain. I’ll be downgrading for now and testing further stable releases in a lab from now on.
Has anyone else been seeing performance degrading throughput after about 7-14 days of uptime with ROS 6.46 & 6.46.1 with the RB4011 ?? After reboot everything would be fine for a while..
Since downgrading to ROS 6.44.6 i don’t seem to have any issues..
Two days ago upgraded to 6.46.1…
Since then, cannot connect to Huawei MA5608T OLT using /system telnet. When I press console is behaving like I double press .
So, during the authentication process, I type the username, and when I press console add second so I cannot type the password.
UPDATE: Same problem while trying to connect via telnet to CTC FRM220 NMC & Cards.
UPDATE2: Same problem while trying to connect via telnet to switch DCN S5750E-28X-SI-24F-D (ssh works fine).
With other devices, like some ZyXEL and Huawei managed switches there is no such problem.
I can still use /system ssh to connect to same Huawei MA5608T OLT.
ok i took the chance and upgraded my RB4011 to 6.46.1 and it did not go well :frowning:
I know I tested my speed over wireless as I have other non mikrotik WDS to run. It should be said that my 4011 is RB4011iGS + but after upgrading to 6.46.1 I had a download speed of about 37 Mbit and upload of 0.24. My internet speed is 1000/1000 and usually on the wireless I am at 200 to 300 both up and down. I have downgraded to 6.45.6 as it was and everything seems normal again.
[quote=nishabhabi01 post_id=768064 time=1578046669 user_id=153842]
[quote=mihaiLLL post_id=766684 time=1577253716 user_id=146187]
[/quote]
Damm even I am having a similar kind of issue
[/quote]
Similar or same? Create a dedicated topic (if you haven’t yet) and give a link to it here. This topic is dedicated to version related issues.
I have the exact same issue here
Anyone running hotspots and encounter the issue with the redirect and/or splash page randomly stopping being served? In my bug report response I was asked to run 6.46.1, however I see nothing in the change notes to address this. Considering it wasn’t happening all the time I can’t just test it in a lab and say it works. The problem didn’t seem to surface until days or a week after upgrading. It’s almost required to run it in production and wait for users to report issues, so I may be able to upgrade just one of my locations to test it for a while. Even then, I have 30+ locations and less than 5 reported the issue, so no guarantee I even see the problem at one site over a month after.
