It seems the inability to get a full Dude installation comes from the fact that ‘dude/files/default’ is hidden (and is automatically hidden by the dude process).
confirm bug on ARM and CHR devices.
Temporary hint on RB3011UiAS where's attached USB flash: move all /dude content to disk1/, after that all default content is accessible and works fine.
After the upgrade cycle (upgrade,reboot,firmware,reboot) the 5GHz Wi-Fi of a RB4011 stop 1 day later to work, a extra reboot solved the issue.
Also upgraded 2x RB2011 and 6x PL7411-2nD.
No errors found so far.
As every time after upgrade I sent the mipsbe and arm firmware files for the CAPs to my CCR1009 CAPSMAN. But obviously it cannot deploy the firmware properly:
11:30:31 caps,error [E4:8D:*********,Run,CAP-E48D********] upgrade status: failed, failed to download file 'routeros-mipsbe-6.46.npk', no such file
Same situation for me with a USB hub and multiple USB–>RS232 adaptors - now seen as one usb port with multiple channels - these work OK but not optimal as you cannot choose separate baud rates etc. etc. for each one individually. @mikrotik can we revert to old behaviour?
This is really bad, I need to set different baudrates for two RS232 adapters because one device needs 9600 and other 38400 and these can’t be changed. Grouping them as multichannel serial with single settings is really bad idea…
I’ve verified this issue and can confirm the problem. It worked with 6.44.6 for example but no longer with 6.46.
The issue is unrelated to the content of “do”. It seems that’s something wrong with the system-commands in the if-part of the script.
