I wonder if this is the start of something to provide synchronisation for NV2/3? based access points without needing GPS modules. You only need relative synchronisation not something synchronised to absolute time to make it work.
Please add the following features in upcomming release:
1. Walled garden or some filtering service to limit the invalid PPPOE request hits.–> To filter Unnecessary Hits or Request from unauthenticated PPPOE Clients.
2. IPv6 Accounting for radius. → Most important and expected by almost all ISP’s
3. Hotspot Service for Ipv6
4. NATv6 Service.
5. DHCPv6 IP server → for giving IPv6 Address to direct clients or PPPOEv6 Service.
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.46beta68 (2019-Nov-21 09:13):
**MAJOR CHANGES IN v6.46:
!) lora - added support for LoRaWAN low-power wide-area network technology for MIPSBE, MMIPS and ARM;
!) package - accept only packages with original filenames (CVE-2019-3976);
!) package - improved package signature verification (CVE-2019-3977);
!) security - fixed improper handling of DNS responses (CVE-2019-3978, CVE-2019-3979);
Changes in this release:
*) backup - store automatically created backup file in "flash" directory;
*) capsman - improved radar detection algorithm;
*) certificate - added progress bar when creating certificate request (CLI only);
*) certificate - added support for certificate request signing with EC keys;
*) certificate - allow specifying "file-name" parameter for export (CLI only);
*) certificate - allow specifying "name" parameter for import (CLI only);
*) certificate - removed "key-size" parameter for "create-certificate-request" command;
*) defconf - fixed default configuration generation on SXT R (introduced in v6.46beta28);
*) dhcpv4-client - allow empty "dhcp-options" parameter when adding new client;
*) dhcpv4-server - improved stability when RADIUS Interim update is sent;
*) ike2 - improved stability when retransmitting first packet as responder;
*) ipsec - fixed policy "sa-src-address" detection from "local-address" (introduced in v6.45);
*) led - fixed default LED configuration for RBLHG-2nD and RBLHG-5HPnD;
*) lte - added support for D402 modem;
*) ptp - added support for IEEE 1588 Precision Clock Synchronization Protocol on CRS317-1G-16S+ (CLI only);
*) route - fixed area range summary route installation in VRF;
*) snmp - added option to monitor "link-downs" parameter using MIKROTIK-MIB;
*) snmp - fixed "dot1dBasePort" index offset for BRIDGE-MIB;
*) snmp - fixed "ifLastChange" OID reporting for IF-MIB;
*) snmp - improved interface status reporting for IfOperStatus OID;
*) ssh - fixed output printing when "command" parameter used;
*) supout - include information from all LTE interfaces;
*) switch - ignore "default-vlan-id" property after switch reset on RTL8367 switch chip;
*) telnet - fixed successful connection establishment output in console (introduced in v6.46beta28);
*) timezone - updated time zone database to version 2019c;
*) ups - improved compatibility with APC UPS's;
*) winbox - fixed "CAPs Scanner" stopping;
*) wireless - added "indonesia4" regulatory domain information;
*) wireless - added "push-button-5s" value for "wps-mode" parameter;
*) wireless - added U-NII-2 support forRBSXTsqG-5acD, RBLHGG-5acD-XL, RBLHGG-5acD, RBLDFG-5acD, RBDiscG-5acD;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as expected or after crash.
RouterBOARD 1100Dx4 Dude Edition.
I have multiple l2tp/ipsec connections to my clients. After update from 6.46beta59 to 6.46beta68 no connection has ever worked.
And it seemed to me that certain sites were not loading properly. I don’t know if it has anything to do with it.
I returned to the 6.45.7 version.
