RoMon does not work on .46b44. reverting to 46b38 it passes the connection.
Only tested on hEX (mmips)
It is on the slow burner since RouterOS 7 beta so not much test.
I may have the setup totally wrong, but ipsec tunneling seems to be bonkers with the v6.46beta44. The basic ipsec tunnel seems to accept only one policy - only that one which you tinkered with the latest. For instance if there are multiple policies then moving one around will “activate” only that one and all the rest fall silent. By definition there should be no difference of the policy ordering as these are not overlapped etc.
One side of the ipsec tunnel testing is RB2011L and the other is Peplink Balance 380.
Edit: I went down to v6.44.5 and results are the same - only latest policy I touch will be working, all the rest are ineffective.
Edit2: According to https://blog.bravi.org/?p=1209 the issue is with policy level which needs to be set “unique” to fix that behaviour.
Its anybody test LDF 5 AC ARM with this beta?
I have two on my desk works fine but i dont know will be good to put at antena tower.
Last time with version 6.45.6 one LDF stuck in loop reboot.
LDF base on mipsbe works great for my link on satelite antenas 90M TCP ![]()
but LDF AC dont work fine,
when is reset no factory defaults when enable/disable wlan, LDF ac start to reboot.
Version 6.46beta55 has been released.
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.46beta55 (2019-Oct-15 06:08):
**MAJOR CHANGES IN v6.46:
!) lora - added support for LoRaWAN low-power wide-area network technology for MIPSBE, MMIPS and ARM;
Changes in this release:
*) bridge - include whole VLAN-id in DHCP Option 82 message;
*) capsman - fixed background scan showing incorrect regulatory domain mismatch error;
*) capsman - fixed frequency setting requiring multiple frequencies;
*) capsman - fixed newline character missing on some logging messages;
*) console - fixed "address" column width when printing DHCPv4 leases;
*) crs1xx/2xx - allow to set trunk port as mirroring target;
*) crs3xx - correctly display link rate when 10/100/1000BASE-T SFP modules are used in SFP+ interfaces;
*) crs3xx - fixed management access when using switch rule "new-vlan-priority" property;
*) crs3xx - improved switch-chip resource allocation on CRS317-1G-16S+, CRS309-1G-8S+, CRS312-4C+8XG, CRS326-24S+2Q+ devices;
*) crs3xx - improved system stability on CRS309-1G-8S+, CRS312-4C+8XG, CRS326-24S+2Q+ devices;
*) dhcpv6-server - fixed logged error message when using "address-pool=static-only";
*) dude - fixed data retrieval over SNMP (introduced in v6.46beta44);
*) fetch - fixed "dst-path" not allowed to create new directories (introduced in v6.46beta34);
*) hotspot - fixed "html-directory" not allowed to create new directories (introduced in v6.46beta34);
*) led - fixed default LED configuration for RBLHG5nD;
*) lte - added support for LM960A18;
*) lte - fixed modem not receiving IP configuration when roaming (introduced in v6.45);
*) lte - fixed Sierra WP7601 driver loading;
*) lte - fix "operator" names not being displayed properly;
*) ptp - added support for IEEE 1588 Precision Clock Synchronization Protocol on CRS317-1G-16S+;
*) quickset - added "LTE APN" dropdown support;
*) quickset - fixed "LTE Band" checkbox display;
*) sfp - fixed "sfp-rx-power" value for some transceivers;
*) sniffer - allow filtering by packet size;
*) snmp - improved LLDP interface returned index and type;
*) snmp - return only interfaces with MAC addresses for LLDP;
*) system - fixed branding package installation (introduced in v6.46beta34);
*) system - improved system stability for devices with AR9342;
*) tr069-client - added CellDiagnostics parameter support;
*) tr069-client - fixed firmware update (introduced in v6.46beta34);
*) upgrade - improved auto package updating using "check-for-updates";
*) userman - fixed customer referencing on WEB (introduced in v6.46beta9);
*) wireless - updated "united-states" regulatory domain information;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as expected or after crash.
ipsec connections (in my case ike V2) are not initiated after reboot. This behaviour is independent from the hardware architecture. Need to disable/enable the peer to connect.
BR
unfortunately, the LTE interface for Telit LM960 (f/w: v32.00.0x1) doesn’t work (doesn’t appear).
Tested on RBM11 (MMIPS architecture) f/w: 6.46beta44, 6.46beta55; (ignore-directip-modem=no).
Via PPP interface - works (ignore-directip-modem=yes, data-channel=4 or 5, info-channel=6).
So I tested. It is second option - VLAN for rejected clients.
Please add option also for non-dot1x clients. Something like no-dot1x-vlan-id=5 (set VLANID 5 for clients unsuported 802.1x) or just allow-incompatible-clients=yes (and set VLANID for clients unsuported 802.1x according to bridge vlan ports settings).
What’s new in 6.46beta55 (2019-Oct-15 06:08):
Can you comment on which PTP Features are added in this release or will be added in the future? Does this mean that all CRS3xx devices could get support for acting as PTP Boundary Clocks for example?
Edit:fix typo
*) wireless - updated “united-states” regulatory domain information;
Can you elaborate on this?
It is impossible to upgrade from 6.46beta55 to 7.0beta3 on SMIPS devices, not enough space.
After netinstall of 7.0 beta 3 there seems to be enough space for future 7.x upgrades, so the problem is that 6.46beta55 is too big.
Signal Strength Range -1..120 It’s joke ? Access Lists unusable now.
More about 1588 PTP support please - will other devices support it too? It could synchronize NV2 Tx/Rx time slots to help against co-location interference, without GPS hardware. Good old NTP is already supported, but may not have enough precision (microseconds) for this purpose.
Version 6.46beta59 has been released.
Before an upgrade:
What's new in 6.46beta59 (2019-Oct-25 07:44):
!) package - accept only packages with original filenames (CVE-2019-3976);
!) package - improved package signature verification (CVE-2019-3977);
!) security - fixed improper handling of DNS responses (CVE-2019-3978, CVE-2019-3979);
*) backup - fixed automatic backup file generation when configuration reset by button;
*) capsman - fixed background scan showing incorrect regulatory domain mismatch error (CAP upgrade required);
*) ccr - improved general system stability;
*) crs3xx - improved interface initialization;
*) dhcpv4-client - fixed "dhcp-options" parameter setting when adding new client;
*) dhcpv6-client - properly update bind time when unused prefix received from the server;
*) dhcpv6-client - properly update IPv6 address on rebind;
*) dhcvp6-client - fixed timeout when doing rebind;
*) ethernet - do not enable interface after reboot that is already disabled;
*) export - fixed "bootp-support" parameter export;
*) ike2 - improved CHILD SA rekey process with Apple iOS 13;
*) ipv6 - changed "advertise-dns" default value to "yes";
*) ptp - added support for IEEE 1588 Precision Clock Synchronization Protocol on CRS317-1G-16S+ (CLI only);
*) snmp - added "disabled" and "comment" parameters for communities (CLI only);
*) snmp - fixed "dot1dBasePort" index offset for BRIDGE-MIB;
*) switch - show "external" flag for bridge hosts on MT7621, RTL8367 switch chips;
*) wireless - added "canada2" regulatory domain information;
*) wireless - allow using "canada2" regulatory domain on US lock devices;
*) wireless - fixed sensor MAC address reporting in TZSP header;
*) wireless - improved IPQ4019, QCA9984, QCA9888 wireless interface stability;
You need a central grand master clock in your network. These a typical GNSS (GPS, GLONASS, Galileo, ..) based.
mikrotik finally tries wireless improvement
bump at 'tik devs?
Edit: Well I answered my own question, still no 160MHz support for US models. Is this ever going to be implemented?
Signal strength range only -1..120, can’t set -120..120 & access lists useless now.
RoMON is still not working since v6.46beta34. on RouterBOARD 750G r3 mmips.
Nstreme p2p & ARM IPQ4019 speed improve but sometimes latency spikes.
