RouterOS version 6.47.1 has been released in public “stable” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.47.1 (2020-Jul-08 12:34):
Changes in this release:
*) crs3xx - fixed HW offloading for netPower 15FR and netPower 16P devices (introduced in v6.47);
*) crs3xx - fixed increased CPU temperature for CRS354-48G-4S+2Q+ device (introduced in v6.47);
*) crs3xx - improved Ethernet port group traffic forwarding for CRS354 devices;
*) defconf - fixed default configuration generation on devices without “wireless” package installed;
*) defconf - fixed default configuration loading on RBmAPL-2nD;
*) defconf - improved default configuration generation on devices with changed wireless interface names;
*) dhcpv6-server - disallow changing binding’s “prefix-pool”;
*) dhcpv6-server - improved stability when changing server for static bindings;
*) dns - do not allow setting “forward-to” same as “name” or “regex”;
*) dns - do not allow setting zero value IP addresses for “A” and “AAAA” records;
*) dns - do not use DoH for local queries when a server is specified;
*) export - fixed HotSpot “address-per-mac” parameter export;
*) filesystem - fixed increased “sector writes” reporting (introduced in v6.47);
*) ftp - fixed possible buffer overflow;
*) ike2 - fixed initiator child SA init without policy;
*) ike2 - fixed policy reference for pending acquire;
*) ike2 - retry RSA signature validation with deduced digest from certificate;
*) ipsec - do not update peer endpoints for generated policy entries (introduced in v6.47);
*) lora - added “spoof-gps” parameter for fake GPS coordinate sending;
*) lora - fixed JSON statistics inaccuracies;
*) lte - added support for MTS 8810FT;
*) lte - fixed modem initialization when multiple modems are used simultaneously;
*) lte - fixed PDP authentication configuration for SIM7600;
*) metarouter - fixed image importing (introduced in v6.46);
*) ospf - improved route tag processing for OSPFv3;
*) ppp - allow specifying pool name for “remote-ipv6-prefix-pool” parameter;
*) profile - fixed “unclassified” load reporting on PowerPC devices (introduced in v6.47);
*) qsfp - fixed auto-negotiation status;
*) qsfp - ignore FEC mode when set to fec91, only fec74 mode is supported (introduced in v6.47);
*) routerboard - fixed “mode-button” support on SMIPS devices (introduced in v6.47);
*) routerboard - fixed “reset-button” menu presence on all devices;
*) supout - added “LoRa” section to supout file;
*) switch - fixed MAC address learning on switch-cpu port for Atheros8316, Atheros8227 and Atheros7240 switch chips;
*) w60g - added “mdmg-fix” parameter for RBwAP60Gx3 (CLI only);
*) winbox - fixed flag displaying under “IP/DNS/Static” table;
*) winbox - fixed minor typo in “BGP/Peer” menu;
*) winbox - hide irrelevant switch port parameters;
*) wireless - changed “station-roaming” default setting from “enabled” to “disabled”;
*) wireless - updated “bangladesh” regulatory domain information;
*) wireless - updated “egypt” regulatory domain information;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
