RouterOS version 6.47.6 has been released in public “stable” channel!
Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.47.6 (2020-Oct-21 10:41):
Changes in this release:
*) cap - fixed L2MTU path discovery;
*) crs3xx - fixed hardware offloaded LACP bonding on Ethernet interfaces for CRS354 devices;
*) crs3xx - fixed switch rules for CRS309 and CRS317 devices (introduced in v6.47.3);
*) defconf - fixed default configuration loading on RBmAP-2nD;
*) dhcpv4-client - fixed DHCP offer packet parsing with overload option present;
*) dhcpv6-server - properly save bindings when executing “make-static” command;
*) fetch - improved SSL handshake processing;
*) ike1 - allow using “my-id” parameter with XAuth;
*) leds - fixed LED type setting;
*) lora - expose “joinEui” un “devEui” values in the log;
*) lte - fixed multiple APN passthrough on R11e-4G;
*) lte - improved EARFCN reporting in 3G and LTE modes on Sierra modems;
*) lte - limit allowed APN count to 3 on R11e-LTE;
*) mpls - fixed duplicate “LabelRelease” message sending;
*) ospf - optimized LSA printing for smaller message sizes;
*) radius - added “Service-Type” attribute to Access-Request for IPv4 and IPv6 DHCP servers;
*) smips - reduced RouterOS main package size;
*) switch - fixed Ethernet padding for small packets;
*) user - improved WinBox and The Dude authenticated session handling;
*) vrrp - made “password” parameter sensitive;
*) w60g - general stability and performance improvements;
*) wireless - added support for US FCC UNII-2 and Canada country profiles for NetMetal series devices;
*) wireless - fixed incorrect wireless capability information in association response frames;
What’s new in 6.47.5 (2020-Oct-08 06:48):
(factory only release)
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
On the version 6.47.6 command repartition (e.g. “/partitions repartition partitions =2”) causes the router’s cyclic reboot (about every 10 seconds). On versions 6.47.x situation the same.
Reset didn’t help, I’ve been able to repare it only with netinstall
On the version 6.46.7 this command works correctly
Will this fix the high battery issue with mobile devices? this started with the 6.47 versions, up to 6.46 the battery drain was normal on phones and tablets, it went up to 4x with the 6.47 versions.
I see no improvement here. My Oneplus drains like crazy, but GF’s Nokia doesn’t seem to have problems.
On the laptops I don’t know, They are used with power adapter.
It has been resolved before!
I would hope that when such mistakes are made, they are added to the regression testing done before releasing a new version, especially in [stable].
I can confirm the w60g link instability problem is fixed, I upgraded the Wireless Wire link that was the least stable on 6.47.4 from 6.46.6 to 6.47.6 and it’s still stable.
Yes I agree how does this not get noticed? I just updated two of my 3011 and only one had this issue and that is the one that has wireless package disabled. So it might be related to that?
