v6.47.8 [stable] is released!
Total, not per chain. And with antenna gain already subtracted.
So for ac you can set this as tx-power.
For n - might need to subtract 3 or 5 depending on number of chains.
Txs @XVO, my answer was delayed :slight_smile:
Wanted to point to this, but you explained already.
https://wiki.mikrotik.com/wiki/Manual:Interface/Wireless
Transmit Power representation on 802.11n and 802.11ac
802.11n wireless chipsets represent power per chain and the 802.11ac wireless chipsets represent the total power, for reference see the table below:
Changes with the antenna gain are OK, but does not reflect the manual tx-power set. That’s why I mentioned ’ “some” information.’
And … the wireless interface must be enabled to see it.
Hi !
I have a RBwAPG-60ad Wireless wire link that came pre-configured. https://mikrotik.com/product/wireless_wire
I make updates via Winbox with “check for updates”
I want you to know if I loose the configuration and the link goes down I do not know to to configure it.
Currently I have 6.47.8 Stable and I want ro know if I can change to 6.46.8 Long term directly from Winbox without loose my configuration.
It is safe ?
it is a good ideea ? Or should I remain on Stable?
I did the downgrade and it worked well. But myConfiguration Was very basic!
I have an RB1100AHx4 running on 6.47 for about 185 days now, which is when that version was released. I’m currently not experiencing any issues, bugs or any other problems yet. I checked change logs and there doesn’t seem to be any security fixes since then. Should I leave it as is or upgrade? Router is in production with 1 BGP session and 3 or 4 ports in use.
This is a good question to where there is no general truth I would guess. So the more releases there are between your build and the current build the greater the likelihood is of a upgrade issue I would guess. When MT tested upgrades they do not disclose from which builds they tests etc.
But as you do not need the upgrade you say and if you do not want to upgrade that often I would switch to Long-Term but right now that is a downgrade for you. Sooner or later Long-Term will go to 6.47.X release and then you can switch.
I recently updated a router from 6.47.1 to 6.47.7 because I got hit by a bug that was introduced in 6.47 (the problem with l2tp connects from the same address).
However, it may well be that you do not experience that bug and thus do not need to upgrade for that reason.
It will vary depending on the config. There are so many capabilities and so many variations in config that it really is impossible to advise in these cases.
Of course it would be different when your question was “I am running 6.39 and I want to upgrade to 6.47.8, is it worthwile and is there a risk of issues”.
In such case it would be much easier: yes it would be worthwile, and yes there is a high chance of issues, so plan your recovery. Partition the router, make backups, etc.
Emils,
I am using DoH DNS which works fine, but if I reboot the router and it takes some moments to get a new DHCP lease the log is filled with:
DoH server connection error: resolving error
Can you quieten down the DoH error log rate? In these moments when the WAN interface is down a 1000 entry log overflows quickly.
Ever since DoH been in RouterOS it’s been like that. It’s been in the betas and stable release and they know about the issue but guys at Mikrotik think good the way it is now: http://forum.mikrotik.com/t/v6-47-stable-is-released/140100/1
I have routers:
RB941-2nD
RB951-Ui-2HnD
RB951-G-2HnD
After upgrade to 6.47.8, the communication will be poor between devices.
the pings is lost between two ports in one bridge. The links between routers throuse vlan is lost.
I find reason of problem. I solve problem, by disable hardware offload on the ports in bridge.
If I eneble hardware offload, I have problem.
*) dns - improved stability with large table of static records;
Has anyone else noticed that after several days apart from static DNS entries all new cached DNS items time out in 5 seconds? I found this a week ago and rebooted the RB4011 router and last night I noticed it again. It happens with or without DoH. I can ping a site, see the new cached entry come in (with a timeout of 5 mins), count to 5 and it’s gone again.
Which device do you use? K1984
if write a script through the web interface, it will become one line, because of this, for a some time I could not understand what the problem is, because you can see it only through winbox.
New version 6.48 has been released in stable RouterOS channel:
http://forum.mikrotik.com/t/v6-48-stable-is-released/145609/1
