*) certificate - improved stability when sending bogus SCEP message;
*) quickset - use 5GHz interface’s country for “Home AP Dual” configuration;
*) system - improved system stability if device is upgraded from RouterOS and/or RouterBOOT v6.41.4 or older;
*) upgrade - added new “upgrade” channel for upgrades between major versions;
*) winbox - do not allow to add/remove W60G interfaces;
*) wireless - added U-NII-2 support for US and Canada country profiles for cAP ac XL and QRT 5 ac;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this specific RouterOS release.
Device mode does not target any explicit vulnerability. It is a security measure. Just read the wiki article about what device mode does and look for meris botnet here in the forum. It may answer your questions.
If a vendor says something is “for security” in nearly all cases there is some notice about vulnerabilities a security feature address. If it’s just a feature, then don’t mention security.
I worry Mikrotik knows about new vulnerability and device-lock is some fix for it. And, they don’t want to say what the vulnerability is yet.
Ah, so you’re just a californian rextended. Got it.
What is the issue that you encountered after upgrading to this version that you’re trying to report in this topic?
IF (and that’s a big IF) this would be the case, don’t you think they FIRST would make sure to have the fix in place BEFORE making public what the problem is ?
Logical sequence of communicating.
Not saying there IS a vulnerability at play here. But it does make perfect sense to provide the fix first.
i was using accept in dst address in NAT for local ip tv to make ip tv see all users ip address after update to 6.48.6 i cant open ip tv downgade fix it or remove accept rule and use !dst address in Masquerade rule, what makes this happen ?
