Simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
What’s new in 6.7 (2013-Nov-29 13:37):
*) support Android usb tethering interface;
*) ipsec - added aes-gcm icv16 encryption mode;
*) wireless - improve rate selection for nstreme protocol
*) poe - new poe controller firmware for RB750UP and OmniTIK UPA;
*) ipsec - added aes-ctr encryption mode;
*) leds - inverted modem signal trigger, now it will trigger when the signal level rises above the treshold;
*) ipsec - added sha256 and sha512 support;
*) ipsec - proposal defaults changed to aes-128 and sha1 for both phase1 and phase2;
*) certificate - support ip, dns and email subject alternative names;
*) dhcpv4 server - added REMOTE_ID option variable for relayed packets;
*) ipsec - fix policy bypass on IPv6 gre, ipip, eoip tunnels when policy uses protocol filter;
*) userman - fix crash on tilera;
*) fixed hairpin nat on bridge with use-ip-firewall=yes;
*) fixed vlan on bridge after reboot having 00:00:00:00:00:00 mac address;
*) address-list - allow manually adding timeoutable entries;
*) address-list - show dynamic entry timeout;
*) fixed l2mtu changing on CCRs - could cause port flapping;
*) disabling/enabling ethernet ports did not work properly on CCRs - could cause port flapping;
*) fixed port flapping on CCR - could happen when having other than only-hardware-queue interface queue.
Note that having other interface queue than only-hardware-queue dramatically reduces performace, so should be avoided if possible;
We have no known issues with RB2011 port flapping. Like explained in the other forum topic, causes could include cabling, drivers, other device issues, etc.
6.5 and 6.6 has this issue on RB2011 (screen posted before in other thread). Cables are almost brand new CAT7, connected to 3 different models of DSL modems, and top models of HP switches…
I will test 6.7 tomorrow.
Upgraded today on RB750UP, previous firmware was 5.24, suddenly I have port flapping, but only if I try to connect with winbox, if I use ssh everything is ok. I have some devices powered on ports, try to change poe status to forced-on and auto but nothing change. I upgraded also rb firmware, but still the same issue. I am connecting to in with winbox on linux (wine).
Any other suggestion?
slech yes, this is normal as there is no other way to guarantee, that your router will have same capabilities than before (like swapping between 2 packages) as in your case ppp-v7 package for 6.7 release is not available.
