RouterOS version 7.10beta has been released on the “v7 testing” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 7.10beta8 (2023-May-22 18:52):
!) ipv6 - fixed DNS server processing by IPv6/ND services (CVE-2023-32154);
!) route - added BFD (CLI only);
*) bgp - allow to filter BGP sessions by AFI;
*) bgp - changed default VPNv4 import distance to iBGP value (200);
*) bgp - do not check route distinguisher on import;
*) bgp - fixed “as-override” and rename to “output.as-override”;
*) bgp - fixed “remove-private-as” and rename to “output.remove-private.as”;
*) bgp - show address family in advertisements;
*) bgp - show approximate received prefix count by the session;
*) branding - fixed custom logo (introduced in v7.8 );
*) conntrack - added read-only “active-ipv4” and “active-ipv6” fields to “/ip/firewall/connection/tracking” (CLI only);
*) console - fixed “print without-paging” output in some cases;
*) defconf - allow to use device factory preset credentials in Flashfig and Netinstall configuration files;
*) dhcpv4-server - added name for “IPv6-Only Preferred” option (108) in debug logs;
*) doh - less verbose logging;
*) ipsec - added hardware acceleration support for IPQ-5010 (hAP ax lite);
*) ipsec - removed “ec2n185” and “ec2n155” values from proposal configurations;
*) l3hw - added “autorestart” option to L3HW settings;
*) l3hw - added error message and reset “l3-hw-offloading=no” if L3HW driver fails to start;
*) l3hw - fixed offloading of /32 IPv4 and /128 IPv6 routes;
*) l3hw - improved offloading of IPv6 hosts after L3HW driver restart;
*) l3hw - improved performance of partial offloading;
*) l3hw - improved route offloading after gateway change;
*) lora - improved gateway card detection and upgrade logic;
*) lora - updated firmware version for LoRaWAN gateway (for R11e-LoRa8, R11e-LoRa9 cards);
*) lte - fixed APN authentication for R11e-LTE6 modem;
*) lte - improved MBIM modem firmware reported error handling when settings RAT modes;
*) lte - improved modem firmware upgrade stability for MBIM modems;
*) lte - reduced SIM slot switchover time for MBIM modems with UUIC reset support;
*) netwatch - added warning about non-running probe due to “startup-delay” (CLI only);
*) poe - fixed bogous “poe-in-voltage” values when using DC jack for RB5009;
*) qos-hw - renamed VLAN “priority” field to “pcp” to avoid confusion;
*) rose-storage - added support for multiple smb users and smb shares;
*) routerboot - increased “preboot-etherboot” maximum value to 30 seconds (“/system routerboard upgrade” required);
*) scheduler - fixed incorrectly started scheduler during reboot or shutdown;
*) sfp - fixed combo-sfp linking at 1G rate for CRS312 switch;
*) sfp - improved module compatibility with bad EEPROM data for RB4011, RB5009, CCR2xxx, CRS312 and CRS518 devices;
*) sniffer - fixed large .pcap file limit;
*) snmp - added BGP peer table support IPv4 only (1.3.6.1.2.1.15.3.1);
*) tr069 - added 5G SCC “SNR” parameter for modems that report it;
*) vrrp - added warning if “sync-connection-tracking=yes” while the global connection tracking is inactive;
*) vrrp - added warning if the VRRP group is misconfigured;
*) vrrp - added warning if VRRP or its interface does not have an IP address;
*) vrrp - do not start connection synchronization if the global connection tracking is inactive;
*) vrrp - fixed issue where disabled VRRP interface is affecting group;
*) vrrp - fixed VRRP interface state on physical cable disconnection;
*) vrrp - improved system stability on changing “group-authority” or “sync-connection-tracking”;
*) vrrp - renamed “group-master” to “group-authority” to avoid confusion with VRRP master;
*) vrrp - send VRRP announcements only by “group-authority”;
*) wifiwave2 - do not include in radio hardware capability list a parameter irrelevant to end users (introduced in 7.10beta5);
*) wifiwave2 - fixed CAP interface name when using “name-format”;
*) wifiwave2 - fixed connectivity issues wheen access-list is used;
*) wifiwave2 - fixed wireless throughput issues after 802.11r client roaming events on 802.11ac devices;
*) wifiwave2 - improve protections against DoS attacks on WPA3-PSK;
*) wifiwave2 - less verbose logging when WPA3-PSK clients are connecting;
*) wireguard - retry “endpoint-address” DNS query on failed resolve;
What’s new in 7.10beta5 (2023-May-09 13:38):
*) bridge - fixed HW offloaded STP state on port disable;
*) bridge - fixed HW offloading for vlan-filtered bridge on devices with multiple switches (introduced in v7.8 );
*) certificate - fixed displaying of certificate serial number;
*) certificate - improved error reporting for Let’s Encrypt certificate;
*) certificate - restore available “key-usage” property options;
*) console - added timeout error for configuration export;
*) console - changed time format according to ISO standard;
*) console - disable output when using “as-value” parameter;
*) console - fixed “:terminal inkey” input when resizing terminal;
*) console - hide past commands with sensitive arguments;
*) container - fixed “container pull” to support OCI manifest format;
*) container - fixed crash due to missing system directories;
*) container - improved default internal environment values;
*) defconf - fixed default configuration for RBSXTLTE3-7;
*) dhcp-server - fixed accounting on RADIUS interim update;
*) firewall - added “endpoint-independent-nat” support;
*) firewall - added “nth” option for IPv6 firewall;
*) gps - expose GPS port for Quectel RM520N-GL;
*) ike2 - improved child SA delete request processing;
*) iot - added option to send Modbus function code commands directly from RouterOS (CLI only);
*) ipsec - refactor public key authentication;
*) ipv6 - fixed IPv6 address removal;
*) l3hw - added advanced configuration options for fine-tuning the L3HW offload (l3hw-settings are cleared after upgrade or downgrade) (CLI only);
*) l3hw - added monitoring options for L3HW utilization (CLI only);
*) l3hw - fixed /32 route deletion;
*) l3hw - improved system stability for partial routing table offload;
*) lte - added serving cell query for MBIM modems with necessary MBIM extension;
*) lte - disable DHCP request filtering (UDP port 67) for Chateau 5G;
*) lte - fixed Google Pixel 7 tethering support;
*) lte - improved stability for Chateau 5G LTE modem firmware upgrade;
*) lte - stop “cell-monitor” on LTE interface configuration change for MBIM modems;
*) mpls - added FastPath support;
*) ovpn - added initial support for V2 data transfer protocol;
*) ovpn - improved system stability;
*) pppoe - fixed PPPoE client scan when server is sending PADO messages without Service-Name tag;
*) qos-hw - added QoS marking support for 98DXxxxx switches (CLI only);
*) route - improved system stability when removing multicast forwarding entries;
*) routerboard - fixed memory test on CCR2116-12G-4S+ (“/system routerboard upgrade” required);
*) routerboard - improved RouterBOOT stability for Alpine CPUs (“/system routerboard upgrade” required);
*) sfp - fixed combo-ether link monitor for CRS328-4C-20S-4S+ switch;
*) sfp - improved Q/SFP interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) sfp - improved SFP interface handling for RB4011, RB5009, CCR2xxx and CRS518 devices;
*) sfp - improved system stability with certain SFP modules for CCR2216 and CRS518 devices;
*) sfp - report EEPROM data even if “auto-init-failed” has occurred;
*) smb - improved SMB v1 operation;
*) snmp - added “engine-id-suffix” setting and display actual “engine-id” as read-only property;
*) snmp - added new “mtxrInterfaceStatsTxRx1024ToMax” OID to MIKROTIK-MIB;
*) ssh - added inline key “passphrase” property;
*) switch - added more precise “storm-rate” configuration options for 98DXxxxx switches (CLI only);
*) switch - fixed storm rate on 10G links for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255 switches;
*) system - improved watchdog reporting in log after reboots for several ARM and ARM64 devices;
*) tile - fixed support for microSD card;
*) upgrade - do not run manual upgrade if some packages are missing;
*) ups - fixed updating of “battery-voltage” property;
*) w60g - improved interface stability for PTMP setups;
*) webfig - added high-resolution favicon;
*) webfig - allow limitless upper bounds for number range;
*) webfig - allow to set “0” second time for fields with default values;
*) webfig - changed time format according to ISO standard;
*) webfig - display date and time in local time zone;
*) webfig - fixed missing “WifiWave2” menu;
*) webfig - fixed missing property names in “WifiWave2” menu;
*) webfig - redesigned item configuration display;
*) webfig - redesigned top menu bar;
*) webfig - removed “Tools/Telnet” menu;
*) webfig - removed auto-login with default credentials (admin without a password);
*) wifiwave2 - avoid transmitting extra bytes at the end of the packet after stripping a VLAN tag;
*) wifiwave2 - do not show placeholder transmit power values on interface startup;
*) wifiwave2 - fixed CAP connection when provisioning “manager=capsman”;
*) wifiwave2 - fixed DFS channel availability warning (introduced in v7.9);
*) wifiwave2 - fixed dynamic interface adding to bridge on CAP device;
*) wifiwave2 - fixed inability to disable CAPsMAN when there are RADIUS-authenticated clients connected;
*) wifiwave2 - fixed incorrect limits on number of interfaces in station mode;
*) wifiwave2 - fixed interface name change when restoring backup;
*) wifiwave2 - fixed key handshake timeout with re-associating clients;
*) wifiwave2 - fixed OWE authentication compatibility with 802.11ax client devices;
*) wifiwave2 - fixed OWE authentication compatibility with third-party client devices (introduced in v7.8 );
*) wifiwave2 - improved logging when an interface is unable to assign a VLAN tag to client;
*) wifiwave2 - improved system stability when trying to exceed virtual AP limit;
*) wifiwave2 - improved system stability;
*) wifiwave2 - restore interface running state when connection to CAPsMAN is lost;
*) winbox - added “Queues” configuration tab when creating new entries under “IPv6/DHCP-Server” menu;
*) winbox - rename “URL” property to “Action data” under “IP/Web-Proxy/Access” menu;
*) wireguard - fixed IPv6 traffic processing with multiple peers;
*) x86 - ice driver update to v1.11.14;
*) zerotier - make “identity” setting sensitive;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
