v7.10rc is released!
RouterOS version 7.10rc has been released on the “v7 testing” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 7.10rc6 (2023-Jun-13 10:52):
!) route - added BFD;
*) bridge - fixed incorrect host moving between ports with enabled FastPath;
*) sfp - improved 10G interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 based switches;
*) ssh - fixed RouterOS SSH client login when using a key (introduced in v7.9);
What’s new in 7.10rc5 (2023-Jun-08 14:48):
*) ike2 - fixed authentication process using EC digital signature (introduced in v7.10rc3);
What’s new in 7.10rc4 (2023-Jun-06 11:34):
*) ike2 - improved system stability when renewing IKE SA (introduced in v7.10rc1);
What’s new in 7.10rc3 (2023-Jun-02 09:43):
*) l3hw - fixed route table offloading during large volume of route updates;
*) l3hw - improved system stability when creating supout.rif file (introduced in v7.10beta5);
*) leds - fixed modem RAT mode indication on hAP ac^3 LTE6 WPS mode button LEDs;
*) sfp - fixed “combo-mode” copper functionality for CRS312 switch (introduced in v7.10rc1);
*) sfp - fixed “rate” monitor value for SFP interface on L009UiGS series devices;
*) winbox - added “MPLS/Settings” menu;
What’s new in 7.10rc1 (2023-May-25 16:01):
!) route - added BFD (CLI only);
*) console - improved stability when using command completion;
*) l3hw - fixed IPv6 ECMP route offloading;
*) l3hw - improved host and nexthop offloading;
*) l3hw - improved performance of partial offloading;
*) mpls - added FastPath support;
*) system - reduced RAM usage for SMIPS devices;
*) wifiwave2 - improve protections against DoS attacks on WPA3-PSK;
Other changes since v7.9:
!) ipv6 - fixed DNS server processing by IPv6/ND services (CVE-2023-32154);
*) bgp - allow to filter BGP sessions by AFI;
*) bgp - changed default VPNv4 import distance to iBGP value (200);
*) bgp - do not check route distinguisher on import;
*) bgp - fixed “as-override” and rename to “output.as-override”;
*) bgp - fixed “remove-private-as” and rename to “output.remove-private.as”;
*) bgp - show address family in advertisements;
*) bgp - show approximate received prefix count by the session;
*) branding - fixed custom logo (introduced in v7.8 );
*) bridge - fixed HW offloaded STP state on port disable;
*) bridge - fixed HW offloading for vlan-filtered bridge on devices with multiple switches (introduced in v7.8 );
*) certificate - fixed displaying of certificate serial number;
*) certificate - improved error reporting for Let’s Encrypt certificate;
*) certificate - restore available “key-usage” property options;
*) conntrack - added read-only “active-ipv4” and “active-ipv6” fields to “/ip/firewall/connection/tracking” (CLI only);
*) console - added timeout error for configuration export;
*) console - changed time format according to ISO standard;
*) console - disable output when using “as-value” parameter;
*) console - fixed “:terminal inkey” input when resizing terminal;
*) console - fixed “print without-paging” output in some cases;
*) console - hide past commands with sensitive arguments;
*) container - fixed “container pull” to support OCI manifest format;
*) container - fixed crash due to missing system directories;
*) container - improved default internal environment values;
*) defconf - allow to use device factory preset credentials in Flashfig and Netinstall configuration files;
*) defconf - fixed default configuration for RBSXTLTE3-7;
*) dhcp-server - fixed accounting on RADIUS interim update;
*) dhcpv4-server - added name for “IPv6-Only Preferred” option (108) in debug logs;
*) doh - less verbose logging;
*) firewall - added “endpoint-independent-nat” support;
*) firewall - added “nth” option for IPv6 firewall;
*) gps - expose GPS port for Quectel RM520N-GL;
*) ike2 - improved child SA delete request processing;
*) iot - added option to send Modbus function code commands directly from RouterOS (CLI only);
*) ipsec - added hardware acceleration support for IPQ-5010 (hAP ax lite);
*) ipsec - refactor public key authentication;
*) ipsec - removed “ec2n185” and “ec2n155” values from proposal configurations;
*) ipv6 - fixed IPv6 address removal;
*) l3hw - added “autorestart” option to L3HW settings;
*) l3hw - added advanced configuration options for fine-tuning the L3HW offload (l3hw-settings are cleared after upgrade or downgrade) (CLI only);
*) l3hw - added error message and reset “l3-hw-offloading=no” if L3HW driver fails to start;
*) l3hw - added monitoring options for L3HW utilization (CLI only);
*) l3hw - fixed /32 route deletion;
*) l3hw - fixed offloading of /32 IPv4 and /128 IPv6 routes;
*) l3hw - improved offloading of IPv6 hosts after L3HW driver restart;
*) l3hw - improved route offloading after gateway change;
*) l3hw - improved system stability for partial routing table offload;
*) lora - improved gateway card detection and upgrade logic;
*) lora - updated firmware version for LoRaWAN gateway (for R11e-LoRa8, R11e-LoRa9 cards);
*) lte - added serving cell query for MBIM modems with necessary MBIM extension;
*) lte - disable DHCP request filtering (UDP port 67) for Chateau 5G;
*) lte - fixed APN authentication for R11e-LTE6 modem;
*) lte - fixed Google Pixel 7 tethering support;
*) lte - improved MBIM modem firmware reported error handling when settings RAT modes;
*) lte - improved modem firmware upgrade stability for MBIM modems;
*) lte - improved stability for Chateau 5G LTE modem firmware upgrade;
*) lte - reduced SIM slot switchover time for MBIM modems with UUIC reset support;
*) lte - stop “cell-monitor” on LTE interface configuration change for MBIM modems;
*) netwatch - added warning about non-running probe due to “startup-delay” (CLI only);
*) ovpn - added initial support for V2 data transfer protocol;
*) ovpn - improved system stability;
*) poe - fixed bogous “poe-in-voltage” values when using DC jack for RB5009;
*) pppoe - fixed PPPoE client scan when server is sending PADO messages without Service-Name tag;
*) qos-hw - added QoS marking support for 98DXxxxx switches (CLI only);
*) qos-hw - renamed VLAN “priority” field to “pcp” to avoid confusion;
*) rose-storage - added support for multiple smb users and smb shares;
*) route - improved system stability when removing multicast forwarding entries;
*) routerboard - fixed memory test on CCR2116-12G-4S+ (“/system routerboard upgrade” required);
*) routerboard - improved RouterBOOT stability for Alpine CPUs (“/system routerboard upgrade” required);
*) routerboot - increased “preboot-etherboot” maximum value to 30 seconds (“/system routerboard upgrade” required);
*) scheduler - fixed incorrectly started scheduler during reboot or shutdown;
*) sfp - fixed combo-ether link monitor for CRS328-4C-20S-4S+ switch;
*) sfp - fixed combo-sfp linking at 1G rate for CRS312 switch;
*) sfp - improved module compatibility with bad EEPROM data for RB4011, RB5009, CCR2xxx, CRS312 and CRS518 devices;
*) sfp - improved Q/SFP interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) sfp - improved SFP interface handling for RB4011, RB5009, CCR2xxx and CRS518 devices;
*) sfp - improved system stability with certain SFP modules for CCR2216 and CRS518 devices;
*) sfp - report EEPROM data even if “auto-init-failed” has occurred;
*) smb - improved SMB v1 operation;
*) sniffer - fixed large .pcap file limit;
*) snmp - added “engine-id-suffix” setting and display actual “engine-id” as read-only property;
*) snmp - added BGP peer table support IPv4 only (1.3.6.1.2.1.15.3.1);
*) snmp - added new “mtxrInterfaceStatsTxRx1024ToMax” OID to MIKROTIK-MIB;
*) ssh - added inline key “passphrase” property;
*) switch - added more precise “storm-rate” configuration options for 98DXxxxx switches (CLI only);
*) switch - fixed storm rate on 10G links for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255 switches;
*) system - improved watchdog reporting in log after reboots for several ARM and ARM64 devices;
*) tile - fixed support for microSD card;
*) tr069 - added 5G SCC “SNR” parameter for modems that report it;
*) upgrade - do not run manual upgrade if some packages are missing;
*) ups - fixed updating of “battery-voltage” property;
*) vrrp - added warning if “sync-connection-tracking=yes” while the global connection tracking is inactive;
*) vrrp - added warning if the VRRP group is misconfigured;
*) vrrp - added warning if VRRP or its interface does not have an IP address;
*) vrrp - do not start connection synchronization if the global connection tracking is inactive;
*) vrrp - fixed issue where disabled VRRP interface is affecting group;
*) vrrp - fixed VRRP interface state on physical cable disconnection;
*) vrrp - improved system stability on changing “group-authority” or “sync-connection-tracking”;
*) vrrp - renamed “group-master” to “group-authority” to avoid confusion with VRRP master;
*) vrrp - send VRRP announcements only by “group-authority”;
*) w60g - improved interface stability for PTMP setups;
*) webfig - added high-resolution favicon;
*) webfig - allow limitless upper bounds for number range;
*) webfig - allow to set “0” second time for fields with default values;
*) webfig - changed time format according to ISO standard;
*) webfig - display date and time in local time zone;
*) webfig - fixed missing “WifiWave2” menu;
*) webfig - fixed missing property names in “WifiWave2” menu;
*) webfig - redesigned item configuration display;
*) webfig - redesigned top menu bar;
*) webfig - removed “Tools/Telnet” menu;
*) webfig - removed auto-login with default credentials (admin without a password);
*) wifiwave2 - avoid transmitting extra bytes at the end of the packet after stripping a VLAN tag;
*) wifiwave2 - do not include in radio hardware capability list a parameter irrelevant to end users (introduced in 7.10beta5);
*) wifiwave2 - do not show placeholder transmit power values on interface startup;
*) wifiwave2 - fixed CAP connection when provisioning “manager=capsman”;
*) wifiwave2 - fixed CAP interface name when using “name-format”;
*) wifiwave2 - fixed connectivity issues wheen access-list is used;
*) wifiwave2 - fixed DFS channel availability warning (introduced in v7.9);
*) wifiwave2 - fixed dynamic interface adding to bridge on CAP device;
*) wifiwave2 - fixed inability to disable CAPsMAN when there are RADIUS-authenticated clients connected;
*) wifiwave2 - fixed incorrect limits on number of interfaces in station mode;
*) wifiwave2 - fixed interface name change when restoring backup;
*) wifiwave2 - fixed key handshake timeout with re-associating clients;
*) wifiwave2 - fixed OWE authentication compatibility with 802.11ax client devices;
*) wifiwave2 - fixed OWE authentication compatibility with third-party client devices (introduced in v7.8 );
*) wifiwave2 - fixed wireless throughput issues after 802.11r client roaming events on 802.11ac devices;
*) wifiwave2 - improved logging when an interface is unable to assign a VLAN tag to client;
*) wifiwave2 - improved system stability when trying to exceed virtual AP limit;
*) wifiwave2 - improved system stability;
*) wifiwave2 - less verbose logging when WPA3-PSK clients are connecting;
*) wifiwave2 - restore interface running state when connection to CAPsMAN is lost;
*) winbox - added “Queues” configuration tab when creating new entries under “IPv6/DHCP-Server” menu;
*) winbox - rename “URL” property to “Action data” under “IP/Web-Proxy/Access” menu;
*) wireguard - fixed IPv6 traffic processing with multiple peers;
*) wireguard - retry “endpoint-address” DNS query on failed resolve;
*) x86 - ice driver update to v1.11.14;
*) zerotier - make “identity” setting sensitive;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
Welldone…
it seems that there is no fix for the problem with WiFi and wrong password. I hope MT will not release stable version with this BUG. It is already implementet in ROS “STABLE” 7.9.1
What bug do you mean? 7.10rc has all the same fixes as 7.9 and more
it has been mentioned many times here.
I had another error login with WiFi on this “STABLE” 9.1. Ït has been reported as SUP-116195. Mobile can not join WiFi mobile say the password is not correct and after reboot all is OK and mobile can join the WiFi without any chage. Im using only WPA/WPA2.
Wifi issues on the 7.10beta8 same as on 7.9. Reported, SUP-115948
hap ax3
But did you test it before writing?
It happened me already on 7.9.1 and on 7.10beta8. one device was AX2 and another AX3.I do not see any fix in this RC so it must be there.
In ticket SUP-115948 you report you have no more problems.
So by that logic, 7.10 also has no problems. Because they contain same fixes. 7.10 contains even more.
Still problems with openvpn, from version 7.8 onwards it’s a tragedy, I have 130 openvpn clients, I think that since you added “key renegotiate sec” after some time the cpu become saturated at 100% forever starting to disconnect all clients. Downgrading to 7.7 solves the problem.
I’ve already opened several tickets about it, they always told me to try to update to the latest rc to see if it fixes it but in fact it hasn’t been fixed yet even in 7.10rc1
I did not create the SUP but it happened me yesterday in the 7.10beta8 so I did downgrade to 7.8
I repeat… you should test it before writing.
I repeat… it happend me yesterday on the 7.10beta8 and in the RC version is no fix for it. I need to have stable WiFi otherwise family will kill me.
So what do you want?
One of the mikrotik staff who comes to your house?
Currently it doesn’t happen to me (ax² 7.9.1, not tested on ax³), so I doubt it’s a general problem,
but it only concerns a few people who have configured the device like yours
(of which you have not opened a SEPARATE topic and posted the configuration AND THEN LINKED HERE…)
EDIT: added not tested on ax³
EDIT2: added missing ROS version
ok, lets wait till it happend to someone alse..I just wanted to notice, that the issue is not properly sorted out.
To be precise: no one has written that what you write it isn’t true, the problem could also be a defect in the power supply or in the routerboard…
We can only fix things that are reported to support. Above mentioned SUP ticket mentions that issue was gone by itself. If you also have a WiFi issue, rather than post here, make a detailed report, including what devices were connected, what happened, when. Then email to support@mikrotik
But first test with the latest version :grin:
It would be helpful to know if the fix that was given in this http://forum.mikrotik.com/t/ax-series-lineup-wifi-issues/166664/70 thread was added to 7.10RC
Im sorry but wife was working from home and I did not have time to elaborate and create anything…What about the next SUP-116195? It also fixed itself? :slight_smile:
SUP-116195 is not fixed by itself, it is actually not even clear what to fix. So don’t expect any changelog entries, if there is no update in the ticket.
P.S: several wireless reports are not even about the same issue. So don’t panic with this “me too” unless you are sure what the report is about
