*) bridge - added automatic “path-cost” values depending on interface rate;
For flappy interfaces, and/or Wireless, what are the implications of this?
*) bridge - added bridge interface property “port-cost-mode” with “short” and “long” arguments;
The only reference i found to this is in the CRS3xx-specific manual
Was this previously restricted to CRS3xx, and is now a routerOS-wide feature?
*) qos-hw - added initial congestion avoidance support for 98DX224S, 98DX226S, and 98DX3236 switch chips (CLI only);
I see in a CRS318P-16G-2S+:
/interface ethernet switch qos tx-manager queue
set *1 schedule=low-priority-group weight=1
set *2 schedule=low-priority-group weight=2
set *3 schedule=low-priority-group weight=3
set *4 schedule=high-priority-group use-shared-buffers=yes weight=3
set *5 schedule=high-priority-group use-shared-buffers=yes weight=4
set *6 schedule=high-priority-group use-shared-buffers=yes weight=5
set *7 use-shared-buffers=yes
set *8 use-shared-buffers=yes
are there changes in forwarding, compared to past behavior?
shouldn’t never-configured-before keys be hidden in the implicit configuration?
(i.e, not visible in /export without verbose)
*) system - added “rtrace” debugging tool (CLI only);
Is this a IP/routing thing, or a linux stack/trace thing?
*) webfig - allow to display comments in multiline or compact modes;
Since we’re in the mood for both console-related improvements, and comment-related imporvements:
can we get /xxx print comments=inline CLI option?
sometimes on big prints, even using proplist=“” to narrow down paramenters, comments break formatting and readability
*) wifi - added “flat-snoop” tool for surveying WiFi APs and stations (CLI only);
docs? how does this differ from “/interface/wireless/scan” ?
