Multithreading is often not useful in these cases because at least a single connection will have to be processed in sequence.
I.e. when you have a single PPPoE client connected to your ISP via a single network interface, there is not much that can be multithreaded.
Of course when you have two ISP each with a PPPoE client, they can be distributed over different cores, at least when the hardware allows it.
(unfortunately in todays routers there often is a switch chip connected to the CPU with only a single connection, and all incoming traffic is handled the same, no matter what interface it arrived on)
in programming thats not the case. you can have multiple queues bound to a single io. that io can be its own thread, the other queues can be their own threads.
In python it is recommended to thread your IOs/request and multiprocess anything CPU intensive. multi threading is bound to a single process but can better use multiple cores to handle io tasks even if its to a single destination.
The point is that when you use constructs that allow you to process a single stream of information in multiple threads, and also you need to guarantee that the processing is done in sequence, you are only wasting effort on thread synchronization that is not made up for in the increased performance of multiple cores.
Remember the PPPoE processing of data packets is trivial. It is not like processing a web request, or similar.
Do not confuse PPPoE and multi-threading. Its not the PPPoE that does not get multi-threaded.
Each distinct flow/connection that passes through the PPPoE can get multi-threaded but only if there is no active Simple Queue on it.
Once you enable any kind of queuing the entire interface will pass through a single core as the CPU must measure all flows in order to be able to queue them.
If they multi-thread this scenario - each process would have to sync each connection with the other cores to avoid out-of-sync flows effectively creating more harm than good as this is costly for a CPU to do.
These scenarios affect all protocols not only PPPoE.
This is a good point, and a question that needs to be properly validated…
I’m sure I’ve faced several situations of B-RAS in PPPoE without the use of QUEUEs in which subscribers didn’t go beyond 800-900 Mbps.
And during diagnostics we found that when the subscriber tested bandwidth, one of the Cores was at 100% and the rest of the cores were practically idle.
I reiterate that this scenario was WITHOUT THE USE OF QUEUEs.
In one of these cases I made a point of taking the subscriber’s traffic to B-RAS in L2 and doing a proof of concept by changing from PPPoE to Static IP directly assigned to the interface. And during these changes the bandwidth tests reached 1Gbps without any problems. In addition, there was no CPU imbalance stuck on just one of the cores.
Marvell Chips are used by several big vendors, including Juniper and Cisco.
Just recently (after 2018, after buying Cavium) Marvell started to appear more on the market with their own name.
Usually, each switch vendor that the chip would come with a name defined by this buyer.
Before OCP, it was considered ill-favored not using “your own” chips.
I remember (long time ago) taking in my hands two line-cards of Cisco chassi device, same part-number of Cisco, and in one of those the chip had the Cisco logo and name, and the other was identical except that in the chip in the other line card had Marvell wrote on it.
I, in my ignorance, even considered that was a falsification… Not! Just production bath different.
Marvell is not the Godzilla that Broadcom is, but is a very respectful solution.
MikroTik that do not use all the potencial of Marvell chips.
We all should push then to use better the resources of the solution they chose themselves.
Ok but my concern is MikroTik selling CPE type routers that underperform relative to other manufacturer’s routers, despite using the same hardware. People are struggling with their hAP type routers getting 1Gbps performance, while the ISP-branded white box CPE router does the same thing without problem.
That is something that MikroTik should be able to fix and make more customers happy than working for the rare ISP that uses MikroTik for a PPPoE service.
on the Rb5009 the 7.16rc4 keeps rebooting itself every few hours. at this point i’ve pretty much had it with the instabilities. i have exams coming up and i need a reliable internet connection. The only thing i’ve used are vlans, ip segmentation, HDD (samba), a container (adguard but not in use anymore). It was so bad in 7.15 but its still not stable yet.
I’ve been powering it with a bench PSU so voltage/power isnt the problem.
I tried downgrading but that didnt even work, i followed the documentation and the router still did not downgrade itself.
There must be some showstopper(s) apparently. If there are upcoming changes/fixes I hope we se another RC instead of going straight stable. Too high the risk of regressions in last-minute fixes.
Pretty please, no. Just no. A new version (RC or stable, doesn’t matter) should be released ONLY when finished. I’d rather wait 2 months for a new RC than keep battling bugs later.
