Actually I do. My use case for my hAP ac2 doesn’t require any wireless driver and it’s not available for experimenting. Hence I’m not very interested in discussing this further. If somebody else starts new topic about this, I’ll certainly follow discussion though.
Same disk space issue is with similar specs device Chateau LTE12 #152.
Discussions regarding disk space was already made in several topics when ROS 7.13 was introduced with new wifi drivers, disk space usage was reduced with 7.15 when wifi-qcom-ac package size was optimized and it was possible to use ROS with new wifi drivers on such devices, but from 7.17 ROS base package is increased and we are at beginning.
Unless you have stored some files/graphs on your flash, you can reclaim disk space by a netinstall with keep-configuration flag. Last time I did that at 7.15 IIRC and regained quite some space.
But there is again a trend of shrinking free-space.
I know about netinstall disk space reclaim, doing that occasionally, but not sure how much it will help, I’m sure less than 100KB will be free. I did netinstall after reverting to 7.16 version, backup file was reduced about 40KB with same config for same ROS version. How large is you config file when is exported when performing /export show-sensitive file=export.rsc? My is 141.6KB (having lots of rules and scripts) and also having 3 certificates with keys added, no manually added files on flash, so even if I will have 40-50KB space left after netinstall 7.17 I’m worried about small amount of disk space growth per config chnage or even worse if is needed by VM swap file, if ROS uses it, which can lead to out of space eventually, see some discussion about it → http://forum.mikrotik.com/t/echo-system-error-critical-could-not-save-configuration-changes-not-enough-storage-space-available/181580/1
CCR1016-12G(7.17.1)
Guys, notice that there are no interrim-update packets from DHPCv4 Mikrotik, but at the same time there are packets coming from DHPCv6 Mikrotik.
Does a netinstall with keep-configuration flag effectively to the same as an export to file, then reset-configuration with import from that file?
Or is it more like the restore of a backup?
For me the mistake was made by the moderator who accepted as the first post of this person yet another warning from the little green men with a clickbait title.
If the user wants to report vulnerabilities, write to support, instead of publishing them in plain sight for anyone, so that MikroTik can take action first.
So dear moderators, STOP accepting certain first posts, as has happened several times in these weeks…
What’s the point of a moderator who accepts posts without even thinking about the consequences?
You might as well enable all new users to post anything right away.
Since the “attacker authenticated as admin” problem will always exist on all operating systems that exist now and in the future,
there should be a permanent CVE-UNIVERSAL grade 10 at this point,
since the latest reported vulnerabilities are all “if you shoot yourself in the foot” type…
After testing it a little bit more, IPv4 and IPv6 do not works at all on LDP signaled VPLS. Over BGP signaled, IPv4 works, IPv6 doesn’t.
I replicated this CHR lab with some real MTik HW, both works the same, so support can’t tell us its because of virtualization.
Anyone else having difficulty with Winbox connections to routers using internal ip addresses? The issue eemed to start this morning before updating to 7.17.1 but updating didn’t help. Mac os Winbox version 4 latest beta. thanks.
Today I’ve checked versions 7.17.1 and 7.18beta4 and it didn’t solved the issue with MLAG - SUP-177393.
Problem with the CTSYNC on VRRP interfaces still exist. Everytime after the reboot you have to switch conntrack settings to make it work again - SUP-177488.
set enabled=auto
set enabled=yes
Have strange issue with Rose Storage on hap ax3.
On version 7.17.1 have attached usb flash 8Gb with files. But after downgrade to 7.16.2 files are not seeing in Winbox - Files, usb1 folder is emplty and via FTP protocol is nothing. Before was using only FTP access with no problems.
Tried Samba on win machine via explorer and files are recognised, dispaying and manageable.
Do not want upgrade to latest stable again for now.
I’m having an issue after upgrading. I’m getting a message under bridge vlan:
# duplicate vlan ids are not allowed due to interface list support, please merge vlan entries into one
I have eyeballed the config and don’t see any duplicates. Things seem to be working, but the message is concerning and it also smacks my hands any time I want to make any changes.
[admin@crs309] /interface/bridge/vlan> export compact
# 2025-02-03 10:55:19 by RouterOS 7.17.1
# software id = ZBSD-VLT6
# model = CRS309-1G-8S+
# serial number = HG509ZJGZGZ
/interface bridge vlan
add bridge=bridge comment="public internet" tagged=sfp-sfpplus1,bridge,sfp-sfpplus7 vlan-ids=1000
add bridge=bridge tagged=bridge,sfp-sfpplus1,sfp-sfpplus7,sfp-sfpplus3 vlan-ids=911
add bridge=bridge comment="trunk ports" tagged=sfp-sfpplus7,bridge,sfp-sfpplus1 vlan-ids=5-8,15,44,59,666
add bridge=bridge comment="att wan" tagged=bridge,sfp-sfpplus1,sfp-sfpplus7,sfp-sfpplus5 vlan-ids=1001
add bridge=bridge comment="management vlan 2" tagged=bridge,sfp-sfpplus1,sfp-sfpplus7 untagged=sfp-sfpplus5 vlan-ids=2
add bridge=bridge comment="wifi vlan" tagged=sfp-sfpplus3 vlan-ids=5
