v7.18rc [testing] is released!
RouterOS version 7.18rc has been released on the “v7 testing” channel!
Before an upgrade:
  2. Make sure the device will not lose power during the upgrade process;
  3. Device has enough free storage space to download all RouterOS packages.
What’s new in 7.18rc2 (2025-Feb-21 12:50):
*) cloud - added “Back To Home Files” feature (additional fixes);
*) dhcpv6-relay - added option to create routes for bindings passing through relay (additional fixes);
*) disk - do not allow adding device in raid when major settings mismatch in superblock and config;
*) disk - fixed removing device from raid while resyncing;
*) ethernet - fixed issue with default-names for RB4011, RB1100Dx4, RB800 devices (additional fixes);
*) ethernet - fixed link-down on startup for ARM64 devices (introduced in v7.16);
*) l3hw - added initial HW offloading for VXLAN on compatible switches (additional fixes);
*) lte - added initial eSIM management support (additional fixes);
*) lte - fix R11e-4G modem initialization (introduced in v7.18beta4);
*) lte - fixed cases where the MBIM dialer could get stuck;
*) lte - fixed interface recovery in mixed multiapn setup for MBIM modems (additional fixes);
*) lte - improved initialization for external USB modems;
*) ptp - improved system stability;
*) qos-hw - fixed wred-threshold (introduced in v7.18beta2);
*) ssh - improved channel resumption after rekey and eof handling;
*) wifi-qcom - prevent AP from transmitting broadcast data unencrypted during authentication of first client;
*) winbox - added missing options under “System/Disk” menu (additional fixes);
What’s new in 7.18rc1 (2025-Feb-18 08:57):
*) console - renamed “back-to-home-users” to “back-to-home-user”;
*) disk - allow to set only type=raid devices as raid-master;
*) disk - cleanup raid members mountpoint, improve default name of file base block-device;
*) disk - do not allow configuring empty slot as raid member;
*) disk - fixed setting up dependent devices when file-based block-device becomes available;
*) disk - improved stability;
*) disk - mount multi-device btrfs filesystems more reliably at startup;
*) disk - set non-empty fs label when formatting by default;
*) file - improved handling of filesystems with many files (additional fixes);
*) log - added CEF format support for remote logging (additional fixes);
*) lte - fixed interface recovery in mixed multiapn setup for MBIM modems;
*) lte - improved automatic link recovery and modem redial functions;
*) lte - reduce modem initialization time for R11e-LTE-US;
*) lte - reduced SIM slot switchover time for modems with AT control channel (except R11e-LTE) (additional fixes);
*) poe-out - fixed PoE-out not working on first boot after upgrade for CRS354 (introduced in v7.18beta2);
*) rose-storage - fixes for btrfs server;
*) smb - fixes for SMB server;
*) winbox - added “Reset Alert” button under “IP/DHCP Server/Alerts” menu;
*) winbox - added missing options under “System/Disk” menu;
*) winbox - do not show LTE “Antenna Scan” button on devices that do not support it;
Other changes since v7.17:
*) 60ghz - improved system stability;
*) bgp - fixed certain affinity options not working properly;
*) bgp - improved system stability when printing BGP advertisements;
*) bgp - make NO_ADVERTISE, NO_EXPORT, NO_PEER communities work;
*) bond - added transmit hash policies for encapsulated traffic;
*) bridge - added MLAG heartbeat property;
*) bridge - avoid duplicate VLAN entries with dynamic wifi VLANs;
*) bridge - do not reset MLAG peer port on heartbeat timeout (log warning instead);
*) bridge - fixed endless MAC update loop (introduced in v7.17);
*) bridge - fixed missing S flag on interface configuration changes;
*) bridge - improved stability when using MLAG with MSTP (introduced in v7.17);
*) bridge - improvements to MLAG host table updates;
*) bridge - process more DHCP message types (decline, NAK, inform);
*) bridge - removed controller-bridge (CB) and port-extender (PE) support;
*) bridge - show VXLAN remote-ip in host table;
*) btest - allow limiting access to server by IP address;
*) certificate - fixed localized text conversion to UTF-8 on certificate creation;
*) chr - fixed limited upgrades for expired instances;
*) chr/x86 - added network driver for Huawei SP570/580 NIC;
*) chr/x86 - fixed error message on bootup;
*) chr/x86 - fixed GRE issues with ice network driver;
*) chr/x86 - Realtek r8169 updated driver;
*) cloud,bth - use in-interface matcher for masquerade rule;
*) console - added dsv.remap to :serialize command to unpack array of maps from print as-value (additional fixes);
*) console - added file-name parameter to :serialize;
*) console - allow ISO timezone format in :totime command;
*) console - allow tab as dsv delimiter;
*) console - allow to toggle script error logging with “/console settings log-script-errors”;
*) console - do not autocomplete arguments when match is both exact and ambiguous;
*) console - do not show numbering in print follow;
*) console - fixed “get” and “proplist” for certain settings;
*) console - fixed issue where ping command displays two lines at the same time;
*) console - fixed issue with disappearing global variable;
*) console - implement scriptable safe-mode commands and safe-mode handler;
*) console - improved hints;
*) console - log errors within scripts to the system log;
*) console - make non-pseudo terminals work with imports;
*) console - put !empty sentence when API query returns nothing;
*) container - add default registry-url=https://lscr.io;
*) container - allow HTTP redirects when accessing container registry;
*) container - allow specifying registry using remote-image property;
*) container - improved image arch choice;
*) container - use parent directory of container root-dir for unpack by default, so that container layer files are downloaded directly on target disk;
*) defconf - added IPv6 FastTrack configuration;
*) device-mode - do not allow changing CPU frequency if “routerboard” is not allowed by device mode (introduced in v7.17);
*) device-mode - fixed feature and mode update via power-reset on PPC devices;
*) dhcpv4-client - allow selecting to which routing tables add default route (additional fixes);
*) dhcpv4-client - fixed default option export output;
*) dhcpv4-server - fixed “active-mac-address” update when client has changed MAC address;
*) dhcpv4-server - fixed framed-route removal;
*) dhcpv4-server - fixed lease assigning when server address is not bind to server interface (introduced in v7.17);
*) dhcpv6-client - added “validate-server-duid” option;
*) dhcpv6-client - allow specifying custom DUID;
*) dhcpv6-client - do not run script on prefix renewal;
*) dhcpv6-relay - add routes for bindings passing through relay;
*) dhcpv6-server - respond to client in case of RADIUS reject;
*) discovery - advertise IPv6 capabilities based on “Disable IPv6” global setting;
*) discovery - improved stability during configuration changes;
*) discovery - report actual PSE power-pair with LLDP;
*) discovery - use power-via-mdi-short LLDP TLV only on pse-type1 802.3af;
*) disk - add disk trim command (/disk format-drive diskx file-system=trim);
*) disk - allow to add swap space without container package;
*) disk - fix detecting disks on virtual machines;
*) disk - fixed showing free space on tmpfs (introduced in v7.17);
*) disk - improved system stability when SMB interface list is used (introduced in v7.17);
*) dns - do not show warning messages for DNS static entries when they are not needed;
*) ethernet - fixed issue with default-names for RB4011 and RB1100Dx4 devices;
*) ethernet - improved link speed reporting on 2.5G-baseT and 10Gbase-T ports;
*) fetch - added “http-max-redirect-count” parameter, allows to follow redirects;
*) fetch - do not require “content-length” or “transfer-encoding” for HTTP;
*) fetch - fixed IPv6 handling in URL (introduced in v7.18beta2);
*) file - added “recursive” and “relative” parameters to “/file/print” for use in conjunction with “path” parameter;
*) file - allow printing specific directories via path parameter;
*) file - fixed missing meta information from special files such as packages (introduced in v7.18beta2);
*) file - hide store directories, such as container (introduced in v7.18beta2);
*) firewall - allow in-interface/in-bridge-port/in-bridge matching in postrouting chains;
*) firewall - fixed incorrectly inverted hotspot value configuration;
*) firewall - increased maximum connection tracking entry count based on device total RAM size;
*) hotspot - fixed an issue where extra “flash/” is added to html-directory for devices with flash folders (introduced in v7.17);
*) igmp-proxy - fixed multicast routing after upstream interface flaps (introduced in v7.17);
*) iot - added new “iot-bt-extra” package for ARM, ARM64 which enables use of USB Bluetooth adapters (LE 4.0+);
*) iot - improvements to LoRa logging and stability;
*) iot - limited MQTT payload size to 32 KB;
*) ip - added support for /31 address;
*) ippool - added pool usage statistics;
*) ipsec - added hardware acceleration support for hEX refresh (additional fixes);
*) ipsec - fixed chacha20 poly1305 proposal;
*) ipsec - fixed installed SAs update process when SAs are removed;
*) ipv6 - added ability to disable dynamic IPv6 LL address generation on non-VPN interfaces;
*) ipv6 - added FastTrack support;
*) ipv6 - added routing FastPath support (enabled by default) (additional fixes);
*) ipv6 - added support for neighbor removal and static entries;
*) ipv6 - fixed configuration loss due to conflicting settings after upgrade (introduced in v7.17);
*) l2tp - added IPv6 FastPath support;
*) l3hw - added neigh-dump-retries property;
*) l3hw - fixed /32 (IPv6 /128) route offloading when using interface as gateway;
*) l3hw - fixed partial route offloading for 98DX224S, 98DX226S, 98DX3236 switches;
*) l3hw - respect interface specifier (%) when matching a gateway;
*) log - added option to select TCP or UDP for remote logging;
*) lte - added at-chat support for EC21EU;
*) lte - added basic support for Quectel RG255C-GL modem in “at+qcfg=“usbnet”,0” USB composition;
*) lte - added confirmation-code parameter for eSIM provisioning;
*) lte - fixed Huawei ME909s-120 support;
*) lte - fixed missing 5G info for “/interface lte print” command;
*) lte - fixed missing IPv6 prefix advertisement on renamed LTE interfaces;
*) lte - fixed prolonged reboots on Chateau 5G ax;
*) lte - fixed R11eL-EC200A-EU modem RAT mode selection (introduced in v7.18beta2);
*) lte - fixed SIM slot initialization with multi-APN setups;
*) lte - lte monitor, show CQI when modem reports it as 0 - undetectable, no RX/down-link resource block assigned to modem by provider;
*) lte - R11eL-EC200A-EU fixed online firmware upgrade and added support for firmware update from local file;
*) lte - R11eL-EC200A-EU improved failed connection handling and recovery;
*) lte - removed nonexistent CQI reading for EC200A-EU modem;
*) net - added initial support for automatic multicast tunneling (AMT) interface (additional fixes);
*) netinstall - try to re-create socket if link status changes;
*) netinstall-cli - fixed DHCP magic cookie;
*) ospf - fixed DN bit not being set;
*) ospfv3 - fixed ignored metric for intra-area routes;
*) ovpn - added requirement for server name when exporting configuration;
*) ovpn - disable hardware accelerator for GCM on Alpine CPUs (introduced in v7.17);
*) ovpn-client - added 1000 character limit for password;
*) pimsm - fixed incorrect neighbor entry when using lo interface;
*) poe-out - added “power-pair” info to poe-out monitor (CLI only);
*) poe-out - added console hints;
*) poe-out - added new modes “forced-on-a” and “forced-on-bt”, where old “forced-on” mean “forced-on-bt” (CLI only);
*) poe-out - fixed invalid poe-in status detection for RB5009 (introduced in v7.18beta2);
*) poe-out - upgraded firmware for 802.3at/bt PSE controlled boards (the update will cause brief power interruption to PoE-out interfaces);
*) port - improved handling of USB device plug/unplug events;
*) ppc - fixed HW encryption (introduced in v7.17);
*) ppp - add support for configuration of upload/download queue types in profile;
*) ppp - added support for random UDP source ports;
*) ppp - fixed setting loss when adding new ppp-client interface for BG77 modem from CLI;
*) ppp - properly cleanup failed inactive sessions on pppoe-server;
*) ptp - do not send packets on STP blocked ports;
*) qos-hw - fixed global buffer limits for 98CX8410 switch;
*) queue - improved system stability when many simple queues are added (introduced in v7.17);
*) queue - improved system stability;
*) queue - prevent CAKE bandwidth config from potentially causing lost connectivity to a device;
*) resolver - fixed static FQDN resolving (introduced in v7.17);
*) rip - fixed visibility of added key-chains in interface-template;
*) rose-storage - add btrfs filesystem add-device/remove-device/replace-device/replace-cancel commands to add/remove/replace disks to/from a live filesystem;
*) rose-storage - add btrfs filesystem balance-start/cancel commands;
*) rose-storage - add btrfs filesystem scrub-start, scrub-cancel commands (CLI only);
*) rose-storage - add btrfs transfers, supports send/receive into/from file for transferring subvolumes across btrfs filesystems;
*) rose-storage - add support to add/remove btrfs subvolumes/snapshots;
*) rose-storage - added support for advanced btrfs features: multi-disk support, subvolumes, snapshots, subvolume send/receive, data/metadata profiles, compression, etc;
*) rose-storage - allow to separately mount any btrfs subvolumes;
*) rose-storage - update rsync to 3.4.1;
*) rose-storage,ssh - support btrfs send/receive over ssh;
*) route - added /ip/route/check tool;
*) route - added subnet length validation on route add;
*) route - do not use disabled addresses when selecting routing id;
*) route - fixed busy loops (route lockups);
*) route - fixed incorrect H flag usage;
*) route - improved stability when polling static routes via SNMP;
*) route - properly resolve imported BGP VPN routes;
*) routerboot - disable packet switching during etherboot for hEX refresh (“/system routerboard upgrade” required);
*) routerboot - improved stability for IPQ8072 (“/system routerboard upgrade” required);
*) routing-filter - improved stability when using large address lists (>5000);
*) routing-filter - improved usage of quotes in filter rules;
*) sfp - fixed missing “1G-baseX” supported rate for NetMetal ac2 and hEX S devices;
*) sfp - improved linking with certain QSFP modules on CRS354 devices;
*) sfp - improved system stability with some GPON modules for CCR2004 and CCR2116 devices (additional fixes);
*) sfp,qsfp - improved initialization and linking;
*) smb - fixed connection issues with clients using older SMB versions (introduced in v7.17);
*) smb - improved system stability;
*) snmp - added “mtxrAlarmSocketStatus” OID to MIKROTIK-MIB;
*) snmp - added disk serial number through description field;
*) snmp - sort disk list and assign correct disk types;
*) supout - added IPv6 settings section;
*) supout - added per CPU load information;
*) switch - allow entering IPv6 netmask for switch rules (CLI only);
*) switch - fixed dynamic switch rules created by dot1x server (introduced in v7.17);
*) switch - fixed issues with inactive hardware-offloaded bond ports;
*) switch - improved egress-rate on QSFP28 ports;
*) switch - improved system stability for CRS304 switch;
*) switch - improvements to certain switch operations (port disable, shaper and switch initialization) (additional fixes);
*) system - added option to list and install available packages (after using “check-for-updates”);
*) system - do not allow to install multiple wireless driver packages at the same time;
*) system - do not cause unnecessary sector writes on check-for-updates;
*) system - enable “ipv6” package on RouterOS v6 downgrade if IPv6 is enabled;
*) system - fixed a potential memory leak that occurred when resetting states after an error;
*) system - force time to be at least at package build time minus 1d;
*) system - improved HTTPS speed;
*) system - improved stability on busy systems;
*) system,arm - automatically increase boot part size on upgrade or netinstall (fixed upgrade failed due to a lack of space on kernel disk/partition);
*) tile - improved system stability;
*) traceroute - added “too many hops” error when max-hops are reached;
*) traceroute - limit max-hops maximum value to 255;
*) user - improved authentication procedure when RADIUS is not used;
*) vxlan - added disable option for VTEPs;
*) vxlan - added IPv6 FastPath support;
*) vxlan - added option to dynamically bridge interface and port settings (hw, pvid);
*) vxlan - added TTL property;
*) vxlan - changed default port to 4789;
*) vxlan - fixed unset for “group” and “interface” properties;
*) vxlan - replaced the “inherit” with “auto” option for dont-fragment property (new default);
*) webfig - added confirmation when quitting in Safe Mode;
*) webfig - do not reload form when failed to create new object;
*) webfig - fixed “TCP Flags” property when inverted flags are set in console;
*) webfig - fixed datetime setting under certain menus;
*) webfig - fixed displaying passwords;
*) webfig - fixed Switch/Ports menu not showing correctly;
*) webfig - hide certificate information in IP Services menu when not applicable;
*) webfig - remember expand/fold state;
*) wifi - added max-clients parameter;
*) wifi - avoid excessive re-transmission of SA Query action frames;
*) wifi - fix issue which made it possible for multiple concurrent WPA3 authentications to interfere with each other;
*) wifi - implement steering parameters to delay probe responses to clients in the 2.4GHz band;
*) wifi - log a warning when a client requests power save mode during association as this may prevent successful connection establishment;
*) wifi - re-word the “can’t find PMKSA” log message to “no cached PMK”;
*) wifi - try to authenticate client as non-FT client if it provides incomplete set of FT parameters;
*) wifi-qcom - fix reporting of radio minimum antenna gain for hAP ax^2;
*) wifi-qcom - fixed potentially lowered throughput for station interfaces if channel.width property is set (introduced in v7.18beta2);
*) winbox - added “Copy to Provisioning” button under “WiFi/Radios” menu;
*) winbox - added “Last Logged In/Out” and “Times Matched” properties under “WiFi/Access List” menu;
*) winbox - added L3HW Advanced and Monitor;
*) winbox - added TCP settings under “Tools/Traffic Generator/Packet Templates” menu;
*) winbox - do not show 0 Tx/Rx rate under “WiFi/Registration” menu when values are not known;
*) winbox - fixed locked input fields when creating new certificate template;
*) winbox - fixed usb power-reset bus selection for RB924iR-2nD-BT5&BG77 (introduced in v7.18beta2);
*) winbox - show LTE “CA Band” field only when CA info is available;
*) winbox - show warning messages for static DNS entries;
*) x86 - fixed “unsupported speed” warning (additional fixes);
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, please send a supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
Thanks for the improvements.
Heads-up - breaking changes for management and monitoring:
Does this mean that Mode A is going to be possible now or in future?
i’d really appreciate an option to disable this for both relay and server (unless one already exists and i couldn’t find it) – when using DHCPv6 for IA_NA, there’s often no need to add these routes and they clog up the routing table.
Thanks for the RC release.
But what I have mention in the beta channel that should be fixes has been fixed. Like the duplicate name in logs
Nice feature, too bad MPLS isn’t on the list of supported protocols.
Only for PSE devices that support 4-pair powering
Documentation was just updated: https://help.mikrotik.com/docs/spaces/ROS/pages/19136769/PoE-Out#PoEOut-PortSettings
It’s still not in docs, which is annoying since we’re now at “rc”. IMO docs should be done by a “release candidate” (i.e. theoretically shippable). And developing an API client requires accurate docs. I mean it’s not entirely clear if it’s only if you use .query or any get…
God only knows how many other API clients in the bowels of ISPs networks that are going to run into this one.
No mention of CVE-2024-54772 fixing?
It was published on cve.org on 2025-02-11.
And the first time it was mentioned here on the forum was in 2025-02-13:
This repo contains the exploit for CVE-2024-54772 which can enumerate valid usernames in Mikrotik routers running RouterOS v6.43 through v7.17.2. The patch is present in v6.49.18 and it will be available in branch v7.18 but it’s now still under testing (as v7.18beta2) and will be released in the near future. Please, check the following link for RouterOS change log
It might not be mentioned in release notes but seems patch already incorporated into 7.18b2 onwards.
already RC state … ? it’s fast…
on the 6.X release they mentioned that this line means the CVE has been fixed.
Its also present on the RC here.
Still a bit confusing since they dont mention the CVE itself
Here:
http://forum.mikrotik.com/t/cve-2024-54772-information-about/181947/1
skindesigner solution still not working…
Why there no way to disable the quickset menu everywhere… ?
Please check SUP-172615.
Mikrotik is one of the best company doing this Stuff…
I need to check again, but at first glance it seems 7.18rc1 broke my 6to4 tunnel
EDIT: yep, back to 7.18beta6 and 6to4 tunnel is working ok.
I get y’all use the singular form in commands. But if you were going to rename it “back-to-home-shares” or something that reflect the are the _N_th users that some “shared” the VPN in your app. Anyway, how back-to-home was reflected in CLI is weird.
IMO, the first BTH user should move to under the “back-to-home-user” so all the BTH “users” are in one place.
