Hi All …
I’m trying desperately to get a v6 config running on v7 beta 6. I need OSPF and BGP to be working and
I am almost there; except I can’t get outgoing BGP route filters to work. The session to my test router
is up, and my input filters work and I can receive route updates. I can send updates as well but not
filter them. If I put them in the main routing table as blackhole routes, they are announced and my test
router receives them. Take 'em out of routing table; they go away on the test router. Nothing I seem
to do in /routing/filter/rule with the “cmcs-out” chain makes any difference. I am testing with the first
entry for 207.225.52.0/24. I’ve also eliminated all rules except the last default reject.
Thanks in advance!
Reiney
[admin@7.1-tst] /routing/bgp/template> print
Flags: * - default; X - disabled, I - inactive
0 * name=“default” no-client-to-client-reflection=no routing-table=main router-id=63.225.11.26 as=395245
[admin@7.1-tst] /routing/bgp/connection> print
Flags: D - dynamic, X - disabled, I - inactive
0 name=“cmcs”
remote.address=65.19.14.33 .as=14818
local.default-address=65.19.14.34 .role=ebgp-peer
connect=yes listen=yes routing-table=main router-id=63.225.11.26 as=395245 redistribute=static
output.filter=cmcs-out-select
input.filter=bgp-in
1 name=“lumen”
remote.address=67.132.229.1 .as=209
local.default-address=67.132.229.2 .role=ebgp-peer
output.filter=lumen-out-select
input.filter=bgp-in
[admin@7.1-tst] /routing/filter/rule> print where chain=cmcs-out
Flags: X - disabled, I - inactive
5 chain=cmcs-out rule=if ([prfx value=dst207.225.52.0/24]) then={ action reject}
6 chain=cmcs-out rule=if ([prfx value=dst63.229.162.0/24]) then={ action accept }
7 chain=cmcs-out rule=if ([prfx value=dst63.233.220.0/23]) then={ action accept }
8 chain=cmcs-out rule=if ([prfx value=dst65.19.8.0/23]) then={ action accept }
9 chain=cmcs-out rule=action do=reject
[admin@7.1-tst] /routing/filter/select-rule> print
0 chain=cmcs-out-select do-where=cmcs-out
[admin@7.1-tst] /routing/bgp/session> print
Flags: E - established
0 E remote.address=65.19.14.33 .as=14818 .id=1.2.3.4 .refused-cap-opt=no .capabilities=mp,rr,as4
.messages=31 .bytes=674 .eor=“”
local.role=ebgp-peer .address=65.19.14.34 .as=395245 .id=63.225.11.26 .capabilities=mp,rr,gr,as4
.messages=30 .bytes=648 .eor=“”
output.procid=20 .filter=#e0e6289500011128
input.procid=20 .filter=bgp-in ebgp
hold-time=3m keepalive-time=1m
