We tried to use some mibsbe devices with 7.1 (due to lack of support for Huawei e3372h LTE modem in stable). I truly hope that “improved stability” means that a bug causing random outages and dead device has actually been fixed. Any details about this improvement from MT would be welcomed.
in 7.1rc4 on rb450gx4, i see these sporadic errors: “DoH server connection error: Idle timeout - waiting data”
its configured for cloudflare DNS.
Darn! After a reboot I lost about 5000 of my 22000 address-list entries. Good that I had a reasonable recent export so I could restore more than 99%. The router is a 4011.
msatter, please clarfiy. It was a simple reboot on an already installed rc4 device or an upgrade from previous versions?
Manual reboot or crash?My 4011 crash rebooted 2nd time now after 4 day uptime, no supout was generated, just" router rebooted without proper shutdown"
.So far my address list (around 8k) is fine tho.
I have HP 107w printer at home.
Haven’t been using it for a month but it was working fine on betas.
Now however I cannot connect to WIFI anymore.
My short config:
set [ find default-name=wifi1 ] channel.band=2ghz-n .width=20/40mhz configuration.country=Malaysia .mode=ap .ssid=XXXXXXX disabled=no security.authentication-types=wpa2-psk,wpa3-psk .disable-pmkid=no .wps=disable
Tried to reset the printer completely.
Manual setup (no WPS) fail and I can see in logs:
XXXXXXXXXXXX:16@wifi1 disconnected, key handshake failure, signal strength -65
WPS Setup also fails with below in turn:
XXXXXXXXXXXX:16@wifi1 rejected, does not provide suitable security method
Anybody having similar problems?
It was an upgrade to v7RC4 that is running now for some time and was rebooted at least 10 times before over that period. The config was coming from 6.48.4 when it was upgraded to v7RC4 a time ago.
It seems that the last part of the address-list cut short and it not saved or not reloaded on startup. I did not reboot again since then and did not check the log.
I will make backup and reboot to see if it crops up again.
Update: Rebooted and all is the address-list is still at 22001, so no losses.
SOLVED in rc7.1rc5
SUP-61613
/system scheduler with 2 lines shows error in syntax at export it.
/import test.rsc show error of importing scheduler.
Reproduction: create a scheduler and paste this extreme of code:
# comment
local abc1 123
export to file, remove it, try import.
no workaround by long version :local name=abc1 value=123
SOLVED in rc7.1rc5
When i enable IPv6 my CRS326 looses all connections and is unreachable after about 3hours45min. There is no problem if I disable IPv6. The only thing that might be related to the 3:45 time is the lease time for the dhcp prefix I receive.
I think this is the relevant config:
/interface vlan
add interface=ether2 name=telekom-vlan vlan-id=7
/interface pppoe-client
add add-default-route=yes disabled=no interface=telekom-vlan keepalive-timeout=disabled max-mtu=1480 name=pppoe-telekom user=\
xxxx@t-online.de
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=no
/ipv6 address
add address=::1 from-pool=telekom-ipv6 interface=bridge
/ipv6 dhcp-client
add interface=pppoe-telekom pool-name=telekom-ipv6 rapid-commit=no request=prefix use-peer-dns=no
/ipv6 firewall filter
add action=accept chain=input comment="allow established and related" connection-state=established,related
add action=accept chain=input comment="accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/16
add action=drop chain=input disabled=yes in-interface=pppoe-telekom log-prefix=dropLL_from_public src-address=fe80::/16
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=no interface=bridge mtu=1480 ra-lifetime=15m
Can’t create routing bgp connection via WEB-GUI. Remote AS field is always red (Invalid value in Remote AS)
I am new here…I have a question, how can I get FW from my routerboard RB5009?
Because from support I don’t have any answer, what I want. They only told me, so I can download via downloads from mikrotik..
In rourerboard is v7 stable. But if I reinstall to 7rc4, there is no chance to turn back to “official” stable version, which is not i mikrotik site..
Because when I found some bugs..I have prolems to keep back.
Thank you so much.
wrong voltage on 750Gr3
/system/health> print
Columns: NAME, VALUE, TYPE
# NAME VALUE TYPE
0 voltage 0.5 V
It should be repaired in RC5, as I mentioned above. Stay tuned.
I’ve asked support for the “stable” rOS, the reply was that the rc4 was more stable than the 7.0.5(it seems that it is not that stable) that came with it. but I haven’t got any bugs with it for now.
Another OVPN - Problem:
Upgraded a Chateau LTE12 from 7.1Beta5 to 7.1rc3.
Same with 7.1rc4 !
Under PPP/Interface OVPN - Server Button and PPPoE Scan Button disappeard in Winbox AND Webfig !
It looks that the firmware is included in the software itself. If Mikrotik has removed previous versions then their is no way back or you have ask others here if they have they have that earlierversion for you.
Thank you so much..They didn’t say that to me..
I ask, is this a normal version only rename (6.48.x) , but no answer..So I know more now.
I have still 7.0.5, because I don’t know, how buggy is 7rc4..So I only want to know, how to save it, before I want to upgrade..
So is it possible to backup old FW if something happen with new FW?
Thanks ![]()
The 5009 is a v7 only device so there is no 6.4x vetsion for it. v7.0x is in your case the ‘stable’ version. RC is an updated and improved version of that. But you have doubt tjen wait a while for RC5 and a bit more patience added, to if the are initial problems with that version.
No, you can’t make a backup.
regarding the “how buggy” It depends what you want to do, in the normal “home/office” use case, it should be fine. I did not have any issues with mine on both RB5009 and RB4011 when using rc4.
I’m using IPv4/IPv6 with firewall, OSPF, Wireguard and ZeroTier (testing) with no issues for now
