V7.20 [stable] is released!
PPPoE Server seems broken. No traffic forwarded to PPP clients
[cknipe@x] > /ppp/active/print
Columns: NAME, SERVICE, CALLER-ID, ADDRESS, UPTIME
   # NAME  SERVICE  CALLER-ID          ADDRESS         UPTIME
   0 test  pppoe    02:00:00:00:00:04  100.80.127.255  2m59s
   1 test  pppoe    02:00:00:00:00:1C  100.80.127.254  2m59s
   2 test  pppoe    02:00:00:00:00:16  100.80.127.253  2m59s
   3 test  pppoe    02:00:00:00:00:31  100.80.127.252  2m59s
[cknipe@x] > /ip/address/print
Flags: X - disabled, I - invalid; D - dynamic; S - slave
 #     ADDRESS            NETWORK         INTERFACE
 2 ID  10.144.0.4/32      100.80.127.255  *F00038
 3 ID  10.144.0.4/32      100.80.127.249  *F00007
 4 ID  10.144.0.4/32      100.80.127.234  *F00019
 5 ID  10.144.0.4/32      100.80.127.248  *F00006
 6 ID  10.144.0.4/32      100.80.127.233  *F00010
And even worse...
[cknipe@x] > /ip/route/print detail where dst-address=100.80.40.15
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn; H - hw-offloaded;
+ - ecmp
   DAc   dst-address=100.80.40.15/32 routing-table=main gateway="" immediate-gw="" distance=0 scope=10 target-scope=5 local-address=10.144.0.4%
[cknipe@x] > /ping 100.80.40.15
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0                                                              22 (Invalid argument)
    1                                                              22 (Invalid argument)
    sent=2 received=0 packet-loss=100%
Time to roll back I guess
Don't get me wrong, please.
I meant that a properly set up firewall is the first line of defense against 98% of attacks...
exactly, the 7.19.6 is stable for us and we don't plan to upgrade anything since magically everything is running perfectly fine now.
Why is this done?
I'm seeing a lot of blackhole routes now. How can I remove/filter or disable them?
Please open a separate thread to discuss this and avoid polluting this topic.
Exporting your BGP is helpful... (on the other topic)
Thank you for confirming this problem. I am currently using the beta version until MikroTik staff fix the problem.
Are you sure about that? Often such issues can also be exploited by a malware site that the user visits, or a bad document that the user downloads, and that uses some javascript to start a connection to the local router. Which is conveniently always at 192.168.88.1.
I'm no expert on this, but it seems a bit difficult to include a corrupted json file sent to the RouterBOARD in a web page.
But again, I'm no expert on this...
What I did mean - if you drop such traffic, then it does not reach the service so it can not "crash it". Does not matter what kind of traffic, what kind of service - if firewall is open only for "good" devices, then you are safe. However, as stated before - fix is on the way.
WinBox 3 "crash" is reproduced, and we will fix it as soon as possible.
The firewall is normally open to all traffic from the LAN, right? So when a PC on the LAN can be tricked into making a bad connection, it will be allowed to crash the device.
That could be something like a bad advert on a website, a mail sent to the user, whatever.
It has happened before in cases of "router vulnerable to attack via the web interface" (also other manufacturers), so why not in this case?
Anyway, it surprises me that you rushed out a 7.20 release without a fix. This issue became known before the timestamp on the release, clearly somebody decided "we'll worry about that later". While it probably is an easy fix.
When you are fixing it, please also include some setting to disable the REST API altogether. Including the parsing. Most people never use this, but it is an open attack surface. The normal API can be disabled because it runs on its own port, but the REST API shares the port with the WebFig and user-manager. That can be improved, make it possible to disable/enable these sub-services separately.
I upgraded from 7.19.6 to 7.20 on the RB3011 and os freezing after a few seconds. I had to downgrade to 7.19.6. It is stable.
I have supout.rif if anyone from Mikrotik needs it.
Wow...
A little less than 2 hours later, we already have 5 more different problem reports. Most of them from names that appear frequently around here.
I wonder if it was a rushed release.
And what's worse:
No official recognition of CVEs.
Yeah... I think I'll wait!
You were right, no doubt about it...
Had the RC gone on for another 2 weeks, you all would have been complaining about when is stable coming. The 7.19.x is stable and arguably close to some kind of LTS quality in terms of releases. Devs have acknowledged the issues and promised fixes within a point release.
I'm not sure what you all want but honestly it's getting a bit ridiculous. Can things be improved? Yes, always, that's life and no organization is perfect, but damn it's clear they have been improving and yet it's just constant head bashing around here.
I for one am happy there is constant work and incremental progress in the right direction, keep up the solid work Mikrotik!
No type 5 routes?
I haven't had time to actually test this yet.
But in a quick glance, I didn't see a way to advertise these types of routes through EVPN. I also couldn't find a way to add the VPNs to which these types of routes belong.
Isn't that included?
What about multi-bridge and MAC-VRF?
Doesn't EVPN allow you to control and advertise different bridge domains?
This sounds good.
Not a Router/Switch feature, but sounds good.
Finally! Thanks!
Who knows, maybe event-based hooks will appear before v8.
Hope is the last thing to die.
That's also a good one!
I remember asking this(with a parameter) on my first interactions, when ticket tool wasn't jira yet.
any docs ? example ?
Bug report.
Just updated our lab/test rose server (RDS2216), somehow the update to 7.20 decided on its own to assign esoteric speeds to several of our interfaces despite being properly configured with 7.19.6, and webfig in 7.20 won't let you correct that (even after reboot, tried with Chrome as well as Firefox just in case, you just can't save changes). If you try to make changes, webfig goes into some kind of weird reload loop, it reloads itself every second (it's more visible if you go to the terminal via webfig in firefox or chrome).
A reboot gets you back on track (kind of), the webfig reload loop will re-engage if you try to change the messed up interfaces again. To be clear, no interface can be edited via webfig. Having said that, the terminal allows you to make changes.
Update: it's way too messy, reverting back to 7.19.6.
Update 2: Interestingly, RouterOS 7.20 allows you to pick both "advertise" and "speed" concurrently for interfaces:
In previous iterations of RouterOS, the "speed" option only showed when "auto negotiation" was turned off.
Not saying that's what's causing the problem, I'm merely pointing out the differences as I'm trying to figure out why webfig is acting up.
Either way, it's not "stable", at least not for that specific router.
It's in Mikrotik's own interest, times have changed. Since the European Cyber Resilience Act is in place, releasing SW with known CVEs is a violation of EU law and can cause penalties. In severe cases including personal reliability for responsible managers.
And the sentence below does also not help for Mikrotik's reputation:
The vendor was contacted early about this disclosure but did not respond in any way
(from https://www.cve.org/CVERecord?id=CVE-2025-10948)
Well, that can also affect the reporter's reputation. Some reporters define their own ways of contacting manufacturers and when they cannot do it they say "did not respond". E.g. they demand the use of PGP and when there is no PGP key available they classify that as "did not respond".
