V7.20 [stable] is released!
RouterOS version 7.20 have been released in the "v7 stable" channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.20 (2025-Sep-29 12:33):
  • arm64/x86/chr - added Aquantia network driver;
  • bgp - added brief, unnumbered output for advertisements list;
  • bgp - added initial EVPN support;
  • bgp - added NLRI filter for more precise accept/discard of ipv4/6 prefixes;
  • bgp - automatically create output.network blackhole routes;
  • bgp - decode and log notifications;
  • bgp - fixed nexthop force-self for IPv4 and IPv6;
  • bgp - fixed selection of received BGP VPN routes;
  • bgp - improved configuration upgrade from versions prior to 7.20;
  • bgp - improved logging;
  • bgp - introduced BGP instance configuration (note, downgrading to earlier versions without instance support may cause config issues);
  • bgp - make "as" parameter optional in template configuration;
  • bgp - print aigp attribute in advertisements;
  • bgp - refresh WinBox when BGP session is created/deleted;
  • bgp - resend routes after nexthop-choice update;
  • bgp - support for Advertising IPv4 Network Layer Reachability Information (NLRI) with an IPv6 Next Hop;
  • bridge - added dynamic tagged entry named "switch-cpu" in scenarios where the same VLAN spans multiple switch chips or is used on both HW and SW ports;
  • bridge - added verbose STP debug logging (rx/tx BPDU, edge-port and port-role transitions, FDB flush);
  • bridge - added warning log when all MACs cannot be displayed under the host table;
  • bridge - disable/enable HW offload on bonding slave disable/enable (fixes potential MAC learning issue);
  • bridge - fixed MVRP leave indication;
  • bridge - fixed port-id when adding a new port in non-primary MLAG;
  • bridge - improved stability when disabling bridge with dynamic VLANs in MSTI;
  • bridge - refactored host learning logic in MLAG setups in order to make it more robust and predictable;
  • bth - added extra file-share functionality for use with apps;
  • bth - improved tunnel name in client config export;
  • bth,file - added direct file sharing from the WinBox Files menu;
  • certificate - added "Amazon Root CA 1" to built-in root certificate authorities store;
  • certificate - fixed ACME certificate usage after renewal;
  • certificate - improved stability after failed import;
  • certificate - trust built-in root certificate authority store after configuration reset;
  • chr - added Chelsio VF driver for PCIID 5803;
  • chr - improved virtio_net performance;
  • cloud - fixed restoring "BTH Files" service after a prolonged network outage;
  • cloud - reduced "BTH Files" ping interval dynamically upon failure;
  • console - added use-tz option to :timestamp command;
  • console - fixed :convert to=num on MIPSBE;
  • console - fixed incorrect multibyte to=num conversions;
  • console - fixed issue where file completion sometimes shows duplicates;
  • console - improved stability and visuals for /interface/wireless/snooper/snoop;
  • console - improved visuals for brief print when displaying large tables;
  • console - improved visuals for hexadecimal strings;
  • console - improved visuals for hiding sensitive commands;
  • console - include flags by default when printing to value;
  • console - prioritize directory specific parameters and hide rarely used ones in print autocomplete;
  • console - replace TAB characters with spaces when editing scripts and added tab-width user configuration in /console/settings;
  • console - unified string representation of ID values;
  • console - updated hints for some /file/print parameters;
  • console - use file name completions (and basic validation) for file output related parameters for export and print commands;
  • console - validate filenames upon addition (if enabled in /console/settings);
  • container - added "device" option to pass a device from /system/hardware menu to a container;
  • container - added /container/log menu, keep 100 messages per container;
  • container - added default print brief mode;
  • container - added initial support for container in container setups;
  • container - added option to execute commands inside a container using "/container/shell cmd= user=";
  • container - added per-container memory limiting and monitoring;
  • container - added repull command;
  • container - added SCTP support;
  • container - added support for cpuset, cpu, memory, pids cgroups;
  • container - allow picking passthrough devices by descriptive name;
  • container - allow read-only mounts;
  • container - allow to mount individual files, not just directories;
  • container - allow to specify multiple envlists;
  • container - allow to use multiple veths in a container, change the in container interface name to same as in RouterOS;
  • container - can use KVM (x86 and arm64) in container QEMU for faster virtualization;
  • container - display any error prominently in WinBox;
  • container - do not allow multiple containers with same root directory;
  • container - enable check-certificate by default for new remote imports;
  • container - fixed containers that use inotify interface;
  • container - fixed environment variables not being passed to "/container/shell" properly;
  • container - fixed QEMU VM to host bridge;
  • container - fixed shell exit causing freeze;
  • container - improved compatibility when running containers with custom "cmd" and "entrypoint" commands;
  • container - improved error and log messages;
  • container - prevent user from setting "root-dir=/" for a container;
  • container - show a more descriptive error when tar extraction fails, particularly "No space left on device";
  • container - show config.json to user;
  • container - show explicit stopped flag for container;
  • container - stability improvements;
  • container - support for direct access to hardware devices;
  • container - terminate containers on shutdown, allow them to clean up properly;
  • dhcp - show error only after interface status is synced with the system (instead of erroneously displaying it immediately);
  • dhcp-client - show warning if DHCP client is configured on dot1x server port;
  • dhcp-server - do not show "I" flag when server is disabled;
  • dhcp-server - improved logging when dual-stack is enabled but fails to acquire client MAC from DUID;
  • dhcpv4-client - allow specifying DSCP of outgoing packets;
  • dhcpv4-client - allow specifying vlan-priority of outgoing packets (for VLAN interfaces only);
  • dhcpv4-client - show "custom-hostname-suffix" and "custom-source-mac-address" properties if set;
  • dhcpv4-server - added "add dns" step to setup wizard;
  • dhcpv4-server - added "lease-agent-circuit-id" and "lease-agent-remote-id" variables to the lease script;
  • dhcpv4-server - added "ntp-none" parameter;
  • dhcpv4-server - changed the default value of address-pool to "static-only" in the option matcher, removed "none" option;
  • dhcpv4/v6-client - properly resume client service after underlying interface status changes;
  • dhcpv4/v6-server - added CoA support;
  • dhcpv6-client - added "accept-prefix-without-address" allowing client to accept prefix when address is not available although requested;
  • dhcpv6-client - update the routing table and address list on manual client configuration changes;
  • dhcpv6-server - added "ignore-ia-na-bindings" setting that allows server to ignore address requests and work just with prefixes;
  • dhcpv6-server - do not trim real client DUID when assigning it to the binding;
  • discovery - disable discovery on loopback, LTE, ppp-out interfaces;
  • discovery - improved LLDP Power via MDI TLV with 802.3bt specific field support;
  • discovery - output LLDP fault message once per port poe-out status change;
  • discovery - report router as "CAPsMAN" on MNDP under "running" parameter;
  • discovery - set initial poe-out Tx power above 0dW;
  • disk - allow to format multiple disks at once;
  • disk - allow to remove Btrfs device by ID;
  • disk - better manage disks disappearing from RAID;
  • disk - cleanup mountpoint when setting mount-filesystem=no;
  • disk - disallow adding SMB share or user with empty name;
  • disk - do Btrfs remove-device asynchronously;
  • disk - offer to blink only PCI slots in console;
  • disk - rename raid-role=unspecified to spare;
  • disk - reset RAID role of old disk after spare assumes a new role;
  • disk - show error when file based block-device uses a mountpoint to be unmounted;
  • disk - show total/free inode counts for fs's that support it;
  • dlna - recognize flac extension;
  • dns - fixed memory leak when static CNAME record was matched;
  • fetch - display file sizes between 1-1023 bytes as 1KiB (instead of 0KiB);
  • fetch - include RouterOS version in the "User-Agent" field;
  • file - improved file handling performance in WinBox v4;
  • filesystem - improved calculation of free space on NAND flash (fixes potential "disk is too small" issue);
  • firewall - added "liberal-tcp-tracking" connection tracking setting;
  • firewall - added connection tracking "total-ip4-entries" and "total-ip6-entries" counters;
  • firewall - allow "dst-limit" matcher to work properly above value 10000;
  • firewall - fixed IPv6 firewall interface matchers not matching VRF interfaces;
  • firewall - improved IPv6 connection tracking lookup responsiveness;
  • firewall - improved system stability when processing connections on multicore systems;
  • firewall - reorganized firewall connection tracking table values and make them persistent between IPv4 and IPv6;
  • flashfig - bind to local address (fixes issue when multiple interfaces are enabled);
  • iot - added additional dongle firmwares to iot-bt-extra package;
  • iot - added an option to increase the amount of LoRa's traffic entries displayed;
  • iot - added support for MQTT last will message;
  • iot - adjusted default LoRa antenna gain values for specific devices;
  • iot - fixed an issue where channel #7 is ignored during LoRa LNS connection;
  • iot - fixed logic for unknown NetIDs;
  • iot - fixed support for LoRa Alliance NetID list;
  • iot - improved LoRa stability and error recovery;
  • iot - improvement to LoRa band verification logic;
  • iot - iot-bt-extra package stability improvement and additional dongle support;
  • iot - LoRa netid filters now can be configured as a "range";
  • iot - LoRa server list is no longer generated if the LR card is not physically attached;
  • iot - LR8G/9G firmware update;
  • iot - removed lora-package, LoRa functionality was moved into iot-package;
  • iot - removed non-existent GPIO pin functionality;
  • ip - added socksify feature and new NAT action "socksify";
  • ip-service - show service name "nfs" for port 2049;
  • ipsec - fixed degraded IPsec performance for IPQ-6010 (introduced in v7.17);
  • ipsec - move raw RSA keys to /ip/ipsec/key/rsa;
  • ipv6 - added support for IPv6 ND proxying of individual addresses;
  • ipv6 - do not allow removal of dynamic address on lo interface;
  • ipv6 - fixed "auto-link-local" feature on WireGuard interface;
  • ipv6 - make pref-src work and settable for static routes;
  • isis - added passive parameter for interface templates;
  • log - added command to clear memory action entries;
  • log - improved the "transmit loop detected" warning log;
  • lte - added "done" status for modem firmware-upgrade version check;
  • lte - added "remove-sent-sms-after-send" option to automatically delete sent SMS messages;
  • lte - added log entry if eSIM has no profiles on read;
  • lte - added modem-init string response to system log;
  • lte - added passthrough support for RG650E-EU modem;
  • lte - added show-capabilities eSIM presence detection for MBIM modems;
  • lte - allow only one IPv6 APN for AT modems;
  • lte - display ICCID regardless of SIM PIN entry status;
  • lte - do not reconfigure modem if deactive eSIM profile is deleted;
  • lte - exempt eSIM provision from global CRL certificate settings;
  • lte - exit LTE scan if modem reconfigured;
  • lte - fallback to RA for global IPv6 if unattained via AT channel (resets on config change);
  • lte - fixed inappropriate LTE interface inactive flag shown during modem initialization;
  • lte - fixed modem recovery on unexpected modem reboot for Chateau 5G and Chateau 5G R16;
  • lte - fixed progress message for R11e-LTE modem firmware-upgrade;
  • lte - fixed rare case where AT dialer could stop;
  • lte - improved EC200A-EU firmware-upgrade stability;
  • lte - improved SMS sending stability over MBIM protocol;
  • lte - refresh eSIM profile list after successful provision;
  • lte - renamed "uicc" to "iccid" in LTE monitor and eSIM profile print;
  • lte - show ip-type in /interface/lte/apn/print;
  • lte - use modem-supplied IPv6 address over EUI-64 when available;
  • macvlan - allow creating macvlan interfaces on all interfaces with a MAC address;
  • mpls - fixed minimal dynamic-label-range setting;
  • net - fixed possible slave flag issues after user configuration changes;
  • net - improved system stability when processing TCP/UDP connections;
  • net - prevent removal of lo interface via WinBox;
  • netinstall - added after-install controls (reboot after installation, shutdown after installation, none);
  • netinstall - alert on unreadable configuration scripts;
  • netinstall - detect inactive install interface;
  • netinstall - fixed install for PPC devices;
  • netinstall - fixed mutually exclusive checkbox behavior;
  • netinstall - show router and package architecture;
  • netinstall - warn user if not enough space on device;
  • netinstall-cli - added MAC filter option "--mac";
  • netinstall-cli - added multiple install option "-m";
  • netinstall-cli - improved client device architecture detection;
  • netwatch - added "early-success-detection" and "early-failure-detection" properties for ICMP probe;
  • netwatch - fixed date and time for stats;
  • ovpn - added support for sha384 hmac;
  • ovpn - improved tunnel setup speeds in configurations with large ammount of active OVPN clients;
  • partitions - fixed failure to repartition correctly from 32MB partition size;
  • partitions - hide partition menu on unsupported boards (without NAND);
  • partitions - limit minimal partition size to 60MB;
  • poe-out - added support for line-interactive and offline UPS on CRS320;
  • poe-out - firmware update for 802.3at capable boards (the update will cause brief power interruption to poe-out interfaces);
  • poe-out - firmware update for 802.3bt capable boards (the update will cause brief power interruption to poe-out interfaces);
  • poe-out - improved dual-signature detection on CRS320;
  • poe-out - improved short-circuit detection and reporting on CRS320;
  • poe-out - increased maximum power margin for all classes on CRS320;
  • port - added IPv6 support for "remote-access" tool;
  • port - improved port status handling at unexpected device removal;
  • ppp - added "dhcpv6-use-radius" PPP profile feature that enables "use-radius" option on dynamically created DHCPv6 servers;
  • ppp - added "remote-ipv6-prefix-reuse" PPP profile feature that allows to advertise same prefix on multiple VPN clients at the same time;
  • ppp - added DHCPv6 assigned prefix to address list when configured and received from RADIUS;
  • ppp - added dhcpv6-lease-time profile configuration property;
  • ppp - do not send initial echo request if keepalive-timeout=disabled;
  • ppp - improved system stability when closing connections;
  • pppoe-server - added accept-untagged=yes/no option to accept untagged traffic in combination with pppoe-over-vlan-rage property;
  • ptp - added PTP support for RDS2216 device;
  • ptp - removed delays between timestamping and packet transmission, improving PTP precision;
  • qos-hw - added mirror-buffers property and monitoring values;
  • radius - fixed issue with Session-Timeout attribute functionality;
  • romon - changed default "disabled=yes" to "disabled=no" under /tool/romon/port;
  • romon - improved error message;
  • route - added missing and remove unnecessary parameters from /ipv6/route menu;
  • route - afi naming consistency in logs;
  • route - attempt to clean up stuck routes in the routing table;
  • route - do not allow to modify dynamic routes;
  • route - fixed incorrectly set nexthop interfaces for BGP VPN routes;
  • route - fixed issue when route table is installed to kernel without fib setting;
  • route - fixed skipping updated destinations;
  • route - improved stability;
  • route - removed fib-reinstall;
  • route - update router ID when disabled address is removed;
  • routerboot - fixed boot MAC for CRS212 switch ("/system routerboard upgrade" required);
  • routing-filter - added filter-wizard (filter generator with v6-like syntax);
  • routing-filter - added sync command;
  • routing-filter - make "chain" and "list" parameters required when adding new item;
  • sfp - fixed low power mode pins on CRS326-4C+20G+2Q+ for optical QSFP modules;
  • sfp - fixed qsfp28 breakout disable;
  • sfp - improved initialization and linking for sfp28 on CRS518;
  • sfp - improved SFP handling for CRS418 device;
  • sfp - improved system stability with some GPON modules for CCR2004 and CCR2116 devices;
  • smips - reduced package size, removed hotspot feature and provide it as a separate package;
  • sniffer - added CPU number and fast-path status in per-packet comment;
  • sniffer - save packets in pcapng format, it now includes interface name the packet was sniffed on, packet direction and nanosecond timestamp resolution;
  • snmp - added SNMP OIDs for firewall connection tracking "total-entries", "total-ip4-entries" and "total-ip6-entries";
  • snmp - improved service stability when processing v3 requests;
  • snmp - set maximum message size to 4 KB;
  • ssh - improved stability on busy server;
  • ssh - show user public key fingerprint under /user/ssh-keys;
  • ssh/sftp - fixed session disconnects during file transfer;
  • ssl/tls - fixed SSL looping behavior when multiple different TLS connections were used;
  • supout - added certificate settings section;
  • supout - added IP Service section;
  • supout - added MPLS settings section;
  • supout - added VXLAN VTEP section;
  • switch - fixed bonding MAC flush in certain cases for 98DX224S, 98DX226S, 98DX2528, and 98DX3236 switch chips;
  • switch - fixed egress-rate on QSFP ports;
  • switch - fixed port blocking by MSTP for 88E6393X, 88E6191X and 88E6190 switches;
  • switch - hide cpu-flow-control on irrelevant devices;
  • switch - improved bond MAC flush for 88E6393X, 88E6191X and 88E6190 switches;
  • switch - improved hash calculation for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98CX8410 switches (affects load balancing for bonds, ECMP routes, and VXLAN source port);
  • switch - improved ingress-rate limit precision for 88E6393X, 88E6191X and 88E6190 switches;
  • switch - reset all Ethernet counters on reset-counters command on QoS Port menu;
  • switch - rework ethernet counters for 98DXxxxx, 98PX1012 and CRS1xx/2xx switches (add tx-drop-queueX-byte/packet, tx-drop-byte/packet, tx-queueX-byte to /in/eth and updated GUI);
  • system - added support for OpenFlow 1.3 (new package "openflow" available);
  • system - do not automatically retry in case /system/package/update download fails;
  • system - fixed bb-upgrade failure on RB5009;
  • system - fixed certain notifications (e.g. kid-control activity, connection tracking table) (introduced in v7.17);
  • system - fixed stuck TCP transmit on virtual interfaces, leading to retransmits;
  • system - improved system configuration journaling procedure;
  • system - improved system stability for hEX refresh and hEX S (2025);
  • system - improved system stability when processing large amount of traffic;
  • system - merge /system/resource/usb and /system/resource/pci into /system/resource/hardware and create a device tree;
  • usb - improved system stability after unplugging USB device for RB5009;
  • user - added tiny delay on any user login attempt to limit login attempts;
  • user - change /user/active/request-logout to /user/active/remove;
  • veth - added dhcp=yes/no property to be able to easily run a container in LAN, runs a special dynamic dhcp-client on interface and sets acquired address/gateway/dns to in-container interface;
  • veth - added mac-address property;
  • veth - make veth interface MAC address stable in both RouterOS and container (container-side MAC incremented by +1 from RouterOS-side interface);
  • vrrp - added "connection-tracking-port" and "connection-tracking-mode" settings for "sync-connection-tracking";
  • vrrp - added proxy-arp support;
  • vrrp - fixed invalid TCP connection state after failover with enabled sync-connection-tracking;
  • vrrp - fixed sync-connection-tracking issue when parent interface is disabled/enabled;
  • vrrp - improved responsiveness when router has many IP addresses depending on VRRP state;
  • vrrp - improved stability when removing VRRP interface with enabled sync-connection-tracking;
  • vrrp - make MTU property read-only;
  • vxlan - added checksum and learning properties;
  • vxlan - fixed unset behavior for "local-address" and "bridge" properties;
  • vxlan - prevent socket sharing (cannot create multiple VXLAN interfaces using the same UDP port with different checksum or vtep-vrf settings);
  • vxlan - rename "vrf" setting to "vtep-vrf";
  • webfig - added token authentication (no password prompt on reload or new window, logout button will log out all related sessions, removing a user will disconnect from active sessions);
  • webfig - allow network map scrolling in Dude;
  • webfig - basic mobile keyboard support for terminal;
  • webfig - do not show Keepalive if not set in GRE Tunnel form;
  • webfig - filter out unusable Bands and Channels for wifi interfaces;
  • webfig - fixed an issue where dynamic dropdown lists were hidden despite having values;
  • webfig - fixed container parameters;
  • webfig - fixed hiding New button with skins;
  • webfig - fixed issue where legacy WebFig login page was used;
  • webfig - fixed skin limits for radio buttons;
  • webfig - fixed Target field duplicate when disabling simple queue;
  • webfig - improved stability when displaying read-only scripts;
  • webfig - make columns a bit wider in tables;
  • webfig - make the Close buttons actual buttons, not links;
  • webfig - mask certain fields where values match default value;
  • webfig - redesign logical "not" operator selector;
  • webfig - remove duplicate flag labels in QuickSet tables;
  • webfig - show system note on login;
  • webfig - use lexicographical sort in dropdown lists;
  • webfig - use time stamps for volatile graphs (improved graph visualization);
  • wifi - added tr069 support for wifi interfaces;
  • wifi - avoid picking 5GHz channels by default which are unlikely to be supported by clients, can be overridden with channel.deprioritize-unii-3-4;
  • wifi - fixed inability to apply steering profile to device's native wifi interfaces;
  • wifi - fixed issue where station mode looped connecting to the same BSSID, preventing switching to other APs;
  • wifi - increased wifi scan list;
  • wifi - restart CAPsMAN only on significant configuration changes;
  • wifi-qcom - accept VLAN-tagged packets from clients with vlan-id;
  • wifi-qcom - added country profile "UK 5.8 fixed" and "ETSI 5.5-5.7 Outdoor";
  • winbox - added "Digest Algorithm" under "System/Certificates" menu;
  • winbox - added "Note" field in LTE Firmware Upgrade;
  • winbox - added "Reselect Time" for wifi;
  • winbox - added Address List Extra Time under "IP/DNS" menu;
  • winbox - added EAP identity under "WiFi/Registration" menu;
  • winbox - added Heartbeat under "Bridge/MLAG" menu;
  • winbox - added Installation under "WiFi" menu;
  • winbox - added missing columns under "System/Users/SSH Keys" menu;
  • winbox - added missing Comments under "User Manager" menus;
  • winbox - added missing properties to "Container" menu and improved field ordering;
  • winbox - added missing WPA2 PSK SHA2 option under "WiFi/Security" menu;
  • winbox - added MPLS Mangle;
  • winbox - added option to create new entries under "System/Users/SSH Keys" menu;
  • winbox - allow to specify CAPsMAN Address as IPv6 LL;
  • winbox - bump minimal WinBox version to 3.42;
  • winbox - correctly unset Locked CAPsMAN field;
  • winbox - differentiate PPP Profile Rx/Tx Queue settings;
  • winbox - display errors from the "Files/Sync" menu;
  • winbox - fixed "Rate" and "Full Duplex" monitor values after link down under "Interface/Ethernet" menu;
  • winbox - fixed container RAM parameter type;
  • winbox - fixed missing warning under "Routing/BGP/Instances" menu;
  • winbox - fixed Record Type field under "Tools/Netwatch" menu;
  • winbox - improved byte type field representation;
  • winbox - improved Switch QoS layout;
  • winbox - make IPv6 Immediate Gateway read-only;
  • winbox - make log message field as multiline;
  • winbox - move CAPsMAN settings button from Remote CAP to WiFi table;
  • winbox - removed duplicate mounts option;
  • winbox - rename Ping Timeout field to Interval;
  • winbox - rename SMS Type field to Modem Type;
  • winbox - rework LTE firmware upgrade buttons into one window;
  • winbox - show "Switch" related menus only on boards that support such features;
  • winbox - show all columns under "System/Users/SSH Keys" menu by default;
  • winbox - use same WireGuard default values as in console;
  • wireguard - fixed minor memory leak when IPv6 is disabled;
  • wireguard - improved system stability on busy devices;
  • wireless - changed CLI snooper column name "freq" to "channel";
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
  • I encountered an issue, but I am not sure if it is related to this release
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device.
Congratulations! :partying_face:
Did it fix [Cve-2025-10948] ??
It does not look like it, there are lots of "improved system stability" lines but nothing referring to REST API or JSON...
They are probably working on that, and a 7.20.1 will follow soon. But IMHO there should also be a 7.19.7 for that, most people do not want to upgrade to the next "stable" in a hurry.
too bad it feels we exposed to anything on any device has web access left enabled..
2025-09-30 09:40:58 route,bgp,info EBGP peer is not on a shared network and multihop is not configured  {l_addr: (empty), r_addr: (empty)}
2025-09-30 09:41:57 bridge,warning no buffer space available for fdb notify
2025-09-30 09:50:54 script,error script error: action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
2025-09-30 09:50:55 script,error script error: action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
BGP still intermittently disconnects, with weird messages about the ebgp peer on a /30 becomes unavailable.
Bridge fdb warnings?
Script timeout errors, but no scripts / schedulers configured.
The main question is… Why did you leave it exposed to the rest of the world?
old winbox crashed when trying to connect
What you mean for "old"?
Actual is 3.42 and the beta... is a beta.
I mean winbox 3.42, after updating to RouterOS 7.20 cant access config and winbox imundently closed.
So, is not any "old".
For me both 32 and 64 version work correctly.
Delete the winbox cache
when I open IP Hotspot window and close winbox the winbox wont open after that :sweat_smile:
The REST API CVE will be fixed in 7.20.1 and 7.21 releases. Please note that it affects only "open firewalls" and devices which allow public access to REST API port.
So, AS USUAL, the default firewall protects, as usual.
Of course, if you have devils at home, that's another matter...
Disable session autosave and delete old sessions.
If you experience problems with WinBox 3, then please:
  1. Test WinBox 4
  2. Test WinBox 3 with session on WinBox loader selected as "".
Such "disconnects/crashes" are usually caused by a single field. If this field must be opened after authentication (due to it being saved in "session"), then it can look like "WinBox does not work at all". Then if you can figure out which field must be opened after that to see the problem - please let us know.
tried, didn't fixed :frowning:
Nobody said this is not a problem that needs to be fixed.
See, enough details...
I've replicated the problem EXACTLY, and it exists.
Now it's the MikroTik staff's turn...
EASY How to replicate:
Winbox 3.42 with autosave session active.
Just open ip/hotspot,
close winbox,
winbox never open up until the session is deleted.
How to restore "default session" for not lost all settings: Open another not 7.20, save session, done, work again on 7.20, but delesect autosave first...
