RouterOS version 7.20rc has been released on the “v7 testing” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.20rc5 (2025-Sep-26 11:44):
- bridge - fixed incorrect port STP state after bridge MAC address change (introduced in v7.20beta3);
- container - fixed setting custom dns-servers (introduced in v7.20beta2);
- snmp - fixed issue where OID could be returned more than requested in SNMP GET/GETNEXT queries (introduced in v7.20rc1);
What's new in 7.20rc4 (2025-Sep-23 14:38):
- bgp - fixed selection of received BGP VPN routes;
- bgp - introduced BGP instance configuration (note, downgrading to earlier versions without instance support may cause config issues) (additional fixes);
- console - fixed "special-login" (introduced in v7.20beta2);
- iot - added support for MQTT last will message;
- iot - fixed logic for unknown NetIDs;
- iot - fixed support for LoRa Alliance NetID list;
- lte - added passthrough support for RG650E-EU modem;
- sfp - fixed TX-Power monitor data output (introduced in v7.20beta9);
- system - fixed a potential memory leak when handling high-speed traffic (introduced in v7.20rc1);
What's new in 7.20rc3 (2025-Sep-16 15:01):
- iot - fixed an issue where channel #7 is ignored during LoRa LNS connection;
- poe-out - firmware update for 802.3at capable boards (the update will cause brief power interruption to poe-out interfaces);
- poe-out - firmware update for 802.3bt capable boards (the update will cause brief power interruption to poe-out interfaces);
- system - improved system stability for hEX refresh and hEX S (2025);
- wifi-qcom - added country profile "UK 5.8 fixed" and "ETSI 5.5-5.7 Outdoor";
- winbox - fixed "auto" as default value for VXLAN "Don't Fragment" property;
What's new in 7.20rc2 (2025-Sep-11 08:17):
- bgp - fixed extended nexthop select (introduced in v7.20beta2);
- bridge - improved system stability with IGMP snooping;
- certificate - fixed ACME certificate usage after renewal;
- certificate - trust built-in root certificate authority store after configuration reset;
- container - added option to execute commands inside a container using "/container/shell cmd= user=" (additional fixes);
- container - fixed shell exit causing freeze;
- firewall - reorganized firewall connection tracking table values and make them persistent between IPv4 and IPv6 (additional fixes);
- ike2 - improved system stability;
- l3hw - fixed switch port l3-hw-offloading export (introduced in v7.20beta8);
- lte - fixed modem recovery on unexpected modem reboot for Chateau 5G and Chateau 5G R16 (additional fixes);
- routerboot - fixed load of OpenWrt kernel on NAND-less boards with MT762x, IPQ40xx, QCA955x and QCA953x CPUs ("/system routerboard upgrade" required);
- snmp - fixed v3 response when returning error (introduced in v7.20rc1);
- switch - fixed possible bonding remove issue (introduced in v7.20beta8);
- switch - fixed possible switch initialization issue for L009 device (introduced in v7.20beta9);
- switch - hide cpu-flow-control on irrelevant devices (additional fixes);
- switch - rework ethernet counters for 98DXxxxx, 98PX1012 and CRS1xx/2xx switches (add tx-drop-queueX-byte/packet, tx-drop-byte/packet, tx-queueX-byte to /in/eth and updated GUI);
- traffic-flow - added support for IPv6 packet sampling;
- traffic-flow - fixed flow reports when using IPv6 and packet sampling (introduced in v7.18);
- wifi - added tr069 support for wifi interfaces (additional fixes);
What's new in 7.20rc1 (2025-Aug-28 16:42):
- bgp - fixed possibility to set link-local nexthop with routing filters (introduced in v7.20beta2);
- bgp - install correct interface if nexthop is link-local (introduced in v7.20beta2);
- bgp - resend routes after nexthop-choice update;
- iot - improved LoRa stability and error recovery;
- lte - fixed wrong subnet mask set to Chateau 5G R17 ax LTE interface;
- route - fixed incorrectly set nexthop interfaces for BGP VPN routes;
- route - fixed skipping updated destinations;
- snmp - improved service stability when processing v3 requests;
- snmp - set maximum message size to 4 KB;
- system - fixed stuck TCP transmit on virtual interfaces, leading to retransmits;
- winbox - fixed "Rate" and "Full Duplex" monitor values after link down under "Interface/Ethernet" menu;
Other changes since v7.19:
- arm64/x86/chr - added Aquantia network driver;
- bgp - added brief, unnumbered output for advertisements list;
- bgp - added initial EVPN support;
- bgp - added NLRI filter for more precise accept/discard of ipv4/6 prefixes;
- bgp - automatically create output.network blackhole routes;
- bgp - decode and log notifications;
- bgp - fixed nexthop force-self for IPv4 and IPv6;
- bgp - improved configuration upgrade from versions prior to 7.20;
- bgp - improved logging;
- bgp - introduced BGP instance configuration (note, downgrading to earlier versions without instance support may cause config issues);
- bgp - make "as" parameter optional in template configuration;
- bgp - print aigp attribute in advertisements;
- bgp - refresh WinBox when BGP session is created/deleted;
- bgp - support for Advertising IPv4 Network Layer Reachability Information (NLRI) with an IPv6 Next Hop;
- bridge - added dynamic tagged entry named "switch-cpu" in scenarios where the same VLAN spans multiple switch chips or is used on both HW and SW ports;
- bridge - added verbose STP debug logging (rx/tx BPDU, edge-port and port-role transitions, FDB flush);
- bridge - added warning log when all MACs cannot be displayed under the host table;
- bridge - disable/enable HW offload on bonding slave disable/enable (fixes potential MAC learning issue);
- bridge - fixed MVRP leave indication;
- bridge - fixed port-id when adding a new port in non-primary MLAG;
- bridge - improved stability when disabling bridge with dynamic VLANs in MSTI;
- bridge - refactored host learning logic in MLAG setups in order to make it more robust and predictable;
- bth - added extra file-share functionality for use with apps;
- bth - improved tunnel name in client config export;
- bth,file - added direct file sharing from the WinBox Files menu;
- certificate - added "Amazon Root CA 1" to built-in root certificate authorities store;
- certificate - improved stability after failed import;
- chr - added Chelsio VF driver for PCIID 5803;
- chr - improved virtio_net performance;
- cloud - fixed restoring "BTH Files" service after a prolonged network outage;
- cloud - reduced "BTH Files" ping interval dynamically upon failure;
- console - added non-interactive (scriptable) serial-terminal support;
- console - added use-tz option to :timestamp command;
- console - fixed :convert to=num on MIPSBE;
- console - fixed incorrect multibyte to=num conversions;
- console - fixed issue where file completion sometimes shows duplicates;
- console - improved stability and visuals for /interface/wireless/snooper/snoop;
- console - improved visuals for brief print when displaying large tables;
- console - improved visuals for hexadecimal strings;
- console - improved visuals for hiding sensitive commands;
- console - include flags by default when printing to value;
- console - prioritize directory specific parameters and hide rarely used ones in print autocomplete;
- console - replace TAB characters with spaces when editing scripts and added tab-width user configuration in /console/settings;
- console - unified string representation of ID values;
- console - updated hints for some /file/print parameters;
- console - use file name completions (and basic validation) for file output related parameters for export and print commands;
- console - validate filenames upon addition (if enabled in /console/settings);
- container - added "device" option to pass a device from /system/hardware menu to a container;
- container - added /container/log menu, keep 100 messages per container;
- container - added default print brief mode;
- container - added initial support for container in container setups;
- container - added option to execute commands inside a container using "/container/shell cmd= user=";
- container - added per-container memory limiting and monitoring;
- container - added repull command;
- container - added SCTP support;
- container - added support for cpuset, cpu, memory, pids cgroups;
- container - allow picking passthrough devices by descriptive name;
- container - allow read-only mounts;
- container - allow to mount individual files, not just directories;
- container - allow to specify multiple envlists;
- container - allow to use multiple veths in a container, change the in container interface name to same as in RouterOS;
- container - can use KVM (x86 and arm64) in container QEMU for faster virtualization;
- container - display any error prominently in WinBox;
- container - do not allow multiple containers with same root directory;
- container - enable check-certificate by default for new remote imports;
- container - fixed containers that use inotify interface;
- container - fixed environment variables not being passed to "/container/shell" properly;
- container - fixed QEMU VM to host bridge;
- container - improved compatibility when running containers with custom "cmd" and "entrypoint" commands;
- container - improved error and log messages;
- container - prevent user from setting "root-dir=/" for a container;
- container - show a more descriptive error when tar extraction fails, particularly "No space left on device";
- container - show config.json to user;
- container - show explicit stopped flag for container;
- container - stability improvements;
- container - support for direct access to hardware devices;
- container - terminate containers on shutdown, allow them to clean up properly;
- dhcp - show error only after interface status is synced with the system (instead of erroneously displaying it immediately);
- dhcp-client - show warning if DHCP client is configured on dot1x server port;
- dhcp-server - do not show "I" flag when server is disabled;
- dhcp-server - improved logging when dual-stack is enabled but fails to acquire client MAC from DUID;
- dhcpv4-client - allow specifying DSCP of outgoing packets;
- dhcpv4-client - allow specifying vlan-priority of outgoing packets (for VLAN interfaces only);
- dhcpv4-client - show "custom-hostname-suffix" and "custom-source-mac-address" properties if set;
- dhcpv4-server - added "add dns" step to setup wizard;
- dhcpv4-server - added "lease-agent-circuit-id" and "lease-agent-remote-id" variables to the lease script;
- dhcpv4-server - added "ntp-none" parameter;
- dhcpv4-server - changed the default value of address-pool to "static-only" in the option matcher, removed "none" option;
- dhcpv4/v6-client - properly resume client service after underlying interface status changes;
- dhcpv4/v6-server - added CoA support;
- dhcpv6-client - added "accept-prefix-without-address" allowing client to accept prefix when address is not available although requested;
- dhcpv6-client - update the routing table and address list on manual client configuration changes;
- dhcpv6-server - added "ignore-ia-na-bindings" setting that allows server to ignore address requests and work just with prefixes;
- dhcpv6-server - do not trim real client DUID when assigning it to the binding;
- discovery - disable discovery on loopback, LTE, ppp-out interfaces;
- discovery - improved LLDP Power via MDI TLV with 802.3bt specific field support;
- discovery - output LLDP fault message once per port poe-out status change;
- discovery - report router as "CAPsMAN" on MNDP under "running" parameter;
- discovery - set initial poe-out Tx power above 0dW;
- disk - allow to format multiple disks at once;
- disk - allow to remove Btrfs device by ID;
- disk - better manage disks disappearing from RAID;
- disk - cleanup mountpoint when setting mount-filesystem=no;
- disk - disallow adding SMB share or user with empty name;
- disk - do Btrfs remove-device asynchronously;
- disk - offer to blink only PCI slots in console;
- disk - rename raid-role=unspecified to spare;
- disk - reset RAID role of old disk after spare assumes a new role;
- disk - show error when file based block-device uses a mountpoint to be unmounted;
- disk - show total/free inode counts for fs's that support it;
- dlna - recognize flac extension;
- dns - fixed memory leak when static CNAME record was matched;
- ethernet - improved performance for hEX Refresh and hEX S (2025);
- fetch - display file sizes between 1-1023 bytes as 1KiB (instead of 0KiB);
- fetch - include RouterOS version in the "User-Agent" field;
- file - improved file handling performance in WinBox v4;
- filesystem - improved calculation of free space on NAND flash (fixes potential "disk is too small" issue);
- firewall - added "liberal-tcp-tracking" connection tracking setting;
- firewall - added connection tracking "total-ip4-entries" and "total-ip6-entries" counters;
- firewall - allow "dst-limit" matcher to work properly above value 10000;
- firewall - fixed IPv6 firewall interface matchers not matching VRF interfaces;
- firewall - improved IPv6 connection tracking lookup responsiveness;
- firewall - improved system stability when processing connections on multicore systems;
- firewall - reorganized firewall connection tracking table values and make them persistent between IPv4 and IPv6;
- flashfig - bind to local address (fixes issue when multiple interfaces are enabled);
- iot - added additional dongle firmwares to iot-bt-extra package;
- iot - added an option to increase the amount of LoRa's traffic entries displayed;
- iot - adjusted default LoRa antenna gain values for specific devices;
- iot - improvement to LoRa band verification logic;
- iot - iot-bt-extra package stability improvement and additional dongle support;
- iot - LoRa netid filters now can be configured as a "range";
- iot - LoRa server list is no longer generated if the LR card is not physically attached;
- iot - LR8G/9G firmware update;
- iot - removed lora-package, LoRa functionality was moved into iot-package;
- iot - removed non-existent GPIO pin functionality;
- ip - added socksify feature and new NAT action "socksify";
- ip-service - show service name "nfs" for port 2049;
- ipsec - fixed degraded IPsec performance for IPQ-6010 (introduced in v7.17);
- ipsec - move raw RSA keys to /ip/ipsec/key/rsa;
- ipv6 - added support for IPv6 ND proxying of individual addresses;
- ipv6 - do not allow removal of dynamic address on lo interface;
- ipv6 - fixed "auto-link-local" feature on WireGuard interface;
- ipv6 - make pref-src work and settable for static routes;
- isis - added passive parameter for interface templates;
- leds - fixed signal strength LEDs for Cube 60G ac;
- log - added command to clear memory action entries;
- log - added VRF support for remote logging;
- log - establish a new connection to the remote log server when action settings are edited (e.g. after changing the src-address property);
- log - fixed memory leak when a connection to remote TCP log server failed;
- log - fixed unsent message retransmit to correct endpoints (introduced in v7.18);
- log - improved the "transmit loop detected" warning log;
- log - randomize source port when using remote logging with src-address specified;
- lte - added "done" status for modem firmware-upgrade version check;
- lte - added "remove-sent-sms-after-send" option to automatically delete sent SMS messages;
- lte - added log entry if eSIM has no profiles on read;
- lte - added modem-init string response to system log;
- lte - added show-capabilities eSIM presence detection for MBIM modems;
- lte - allow only one IPv6 APN for AT modems;
- lte - display ICCID regardless of SIM PIN entry status;
- lte - do not reconfigure modem if deactive eSIM profile is deleted;
- lte - exempt eSIM provision from global CRL certificate settings;
- lte - exit LTE scan if modem reconfigured;
- lte - fallback to RA for global IPv6 if unattained via AT channel (resets on config change);
- lte - fixed inappropriate LTE interface inactive flag shown during modem initialization;
- lte - fixed modem recovery for unexpected modem reboot for Chateau 5G and Chateau 5G R16;
- lte - fixed progress message for R11e-LTE modem firmware-upgrade;
- lte - fixed rare case where AT dialer could stop;
- lte - improved EC200A-EU firmware-upgrade stability;
- lte - improved SMS sending stability over MBIM protocol;
- lte - refresh eSIM profile list after successful provision;
- lte - renamed "uicc" to "iccid" in LTE monitor and eSIM profile print;
- lte - show ip-type in /interface/lte/apn/print;
- lte - use modem-supplied IPv6 address over EUI-64 when available;
- mac-server - fixed interface-list change behavior;
- macvlan - allow creating macvlan interfaces on all interfaces with a MAC address;
- mpls - fixed minimal dynamic-label-range setting;
- net - fixed possible slave flag issues after user configuration changes;
- net - improved system stability when processing TCP/UDP connections;
- net - prevent removal of lo interface via WinBox;
- netinstall - added after-install controls (reboot after installation, shutdown after installation, none);
- netinstall - alert on unreadable configuration scripts;
- netinstall - detect inactive install interface;
- netinstall - fixed install for PPC devices;
- netinstall - fixed mutually exclusive checkbox behavior;
- netinstall - show router and package architecture;
- netinstall - warn user if not enough space on device;
- netinstall-cli - added MAC filter option "--mac";
- netinstall-cli - added multiple install option "-m";
- netinstall-cli - improved client device architecture detection;
- netwatch - added "early-success-detection" and "early-failure-detection" properties for ICMP probe;
- netwatch - fixed date and time for stats;
- ovpn - added support for sha384 hmac;
- ovpn - improved tunnel setup speeds in configurations with large ammount of active OVPN clients;
- partitions - fixed failure to repartition correctly from 32MB partition size;
- partitions - hide partition menu on unsupported boards (without NAND);
- partitions - limit minimal partition size to 60MB;
- poe-out - added "poe-in" detection for 802.3at poe-out capable ports;
- poe-out - added support for line-interactive and offline UPS on CRS320;
- poe-out - fixed "low-voltage" LLDP deny for RB5009 and RB960 in specific voltage/power-source combinations;
- poe-out - fixed missing error status report in rare cases for 802.3at;
- poe-out - improved dual-signature detection on CRS320;
- poe-out - improved short-circuit detection and reporting on CRS320;
- poe-out - increased maximum power margin for all classes on CRS320;
- port - added IPv6 support for "remote-access" tool;
- port - improved port status handling at unexpected device removal;
- ppp - added "dhcpv6-use-radius" PPP profile feature that enables "use-radius" option on dynamically created DHCPv6 servers;
- ppp - added "remote-ipv6-prefix-reuse" PPP profile feature that allows to advertise same prefix on multiple VPN clients at the same time;
- ppp - added DHCPv6 assigned prefix to address list when configured and received from RADIUS;
- ppp - added dhcpv6-lease-time profile configuration property;
- ppp - do not send initial echo request if keepalive-timeout=disabled;
- ppp - improved system stability when closing connections;
- pppoe-server - added accept-untagged=yes/no option to accept untagged traffic in combination with pppoe-over-vlan-rage property;
- ptp - added PTP support for RDS2216 device;
- ptp - removed delays between timestamping and packet transmission, improving PTP precision;
- qos-hw - added mirror-buffers property and monitoring values;
- radius - fixed issue with Session-Timeout attribute functionality;
- romon - changed default "disabled=yes" to "disabled=no" under /tool/romon/port;
- romon - improved error message;
- route - added missing and remove unnecessary parameters from /ipv6/route menu;
- route - afi naming consistency in logs;
- route - attempt to clean up stuck routes in the routing table;
- route - do not allow to modify dynamic routes;
- route - fixed issue when route table is installed to kernel without fib setting;
- route - improved stability;
- route - removed fib-reinstall;
- route - update router ID when disabled address is removed;
- routerboot - fixed boot MAC for CRS212 switch ("/system routerboard upgrade" required);
- routing-filter - added filter-wizard (filter generator with v6-like syntax);
- routing-filter - added sync command;
- routing-filter - make "chain" and "list" parameters required when adding new item;
- sfp - corrected the I2C clock frequency for the hEX S (2025) to prevent EEPROM read issues with GPON modules;
- sfp - fixed low power mode pins on CRS326-4C+20G+2Q+ for optical QSFP modules;
- sfp - fixed qsfp28 breakout disable;
- sfp - improved initialization and linking for sfp28 on CRS518;
- sfp - improved SFP handling for CRS418 device;
- sfp - improved system stability with some GPON modules for CCR2004 and CCR2116 devices;
- smips - reduced package size, removed hotspot feature and provide it as a separate package;
- sniffer - added CPU number and fast-path status in per-packet comment;
- sniffer - save packets in pcapng format, it now includes interface name the packet was sniffed on, packet direction and nanosecond timestamp resolution;
- snmp - added SNMP OIDs for firewall connection tracking "total-entries", "total-ip4-entries" and "total-ip6-entries";
- ssh - improved stability on busy server;
- ssh - show user public key fingerprint under /user/ssh-keys;
- ssh/sftp - fixed session disconnects during file transfer;
- ssl/tls - fixed SSL looping behavior when multiple different TLS connections were used;
- supout - added certificate settings section;
- supout - added IP Service section;
- supout - added MPLS settings section;
- supout - added VXLAN VTEP section;
- switch - fixed bonding MAC flush in certain cases for 98DX224S, 98DX226S, 98DX2528, and 98DX3236 switch chips;
- switch - fixed egress-rate on QSFP ports;
- switch - fixed port blocking by MSTP for 88E6393X, 88E6191X and 88E6190 switches;
- switch - fixed switch name for CRS418;
- switch - hide cpu-flow-control on irrelevant devices;
- switch - improved bond MAC flush for 88E6393X, 88E6191X and 88E6190 switches;
- switch - improved hash calculation for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98CX8410 switches (affects load balancing for bonds, ECMP routes, and VXLAN source port);
- switch - improved ingress-rate limit precision for 88E6393X, 88E6191X and 88E6190 switches;
- switch - improved system stability after switch reset while bonding interfaces are active (introduced in v7.18);
- switch - reset all Ethernet counters on reset-counters command on QoS Port menu;
- switch - rework ethernet counters (add tx-drop-queueX-byte/packet, tx-drop-byte/packet, tx-queueX-byte to /in/eth and updated GUI);
- system - added support for OpenFlow 1.3 (new package "openflow" available);
- system - do not automatically retry in case /system/package/update download fails;
- system - fixed bb-upgrade failure on RB5009;
- system - fixed certain notifications (e.g. kid-control activity, connection tracking table) (introduced in v7.17);
- system - improved system configuration journaling procedure;
- system - improved system stability when processing large amount of traffic;
- system - merge /system/resource/usb and /system/resource/pci into /system/resource/hardware and create a device tree;
- usb - improved system stability after unplugging USB device for RB5009;
- user - added tiny delay on any user login attempt to limit login attempts;
- user - change /user/active/request-logout to /user/active/remove;
- veth - added dhcp=yes/no property to be able to easily run a container in LAN, runs a special dynamic dhcp-client on interface and sets acquired address/gateway/dns to in-container interface;
- veth - added mac-address property;
- veth - make veth interface MAC address stable in both RouterOS and container (container-side MAC incremented by +1 from RouterOS-side interface);
- vrrp - added "connection-tracking-port" and "connection-tracking-mode" settings for "sync-connection-tracking";
- vrrp - added proxy-arp support;
- vrrp - fixed invalid TCP connection state after failover with enabled sync-connection-tracking;
- vrrp - fixed sync-connection-tracking issue when parent interface is disabled/enabled;
- vrrp - improved responsiveness when router has many IP addresses depending on VRRP state;
- vrrp - improved stability when removing VRRP interface with enabled sync-connection-tracking;
- vrrp - make MTU property read-only;
- vxlan - added checksum and learning properties;
- vxlan - fixed unset behavior for "local-address" and "bridge" properties;
- vxlan - prevent socket sharing (cannot create multiple VXLAN interfaces using the same UDP port with different checksum or vtep-vrf settings);
- vxlan - rename "vrf" setting to "vtep-vrf";
- webfig - added token authentication (no password prompt on reload or new window, logout button will log out all related sessions, removing a user will disconnect from active sessions);
- webfig - allow network map scrolling in Dude;
- webfig - basic mobile keyboard support for terminal;
- webfig - do not show Keepalive if not set in GRE Tunnel form;
- webfig - filter out unusable Bands and Channels for wifi interfaces;
- webfig - fixed an issue where dynamic dropdown lists were hidden despite having values;
- webfig - fixed container parameters;
- webfig - fixed hiding New button with skins;
- webfig - fixed issue where legacy WebFig login page was used;
- webfig - fixed skin limits for radio buttons;
- webfig - fixed Target field duplicate when disabling simple queue;
- webfig - improved stability when displaying read-only scripts;
- webfig - make columns a bit wider in tables;
- webfig - make the Close buttons actual buttons, not links;
- webfig - mask certain fields where values match default value;
- webfig - redesign logical "not" operator selector;
- webfig - remove duplicate flag labels in QuickSet tables;
- webfig - show system note on login;
- webfig - use lexicographical sort in dropdown lists;
- webfig - use time stamps for volatile graphs (improved graph visualization);
- wifi - avoid picking 5GHz channels by default which are unlikely to be supported by clients, can be overridden with channel.deprioritize-unii-3-4;
- wifi - fixed inability to apply steering profile to device's native wifi interfaces;
- wifi - fixed issue where station mode looped connecting to the same BSSID, preventing switching to other APs;
- wifi - increased wifi scan list;
- wifi - restart CAPsMAN only on significant configuration changes;
- wifi-qcom - accept VLAN-tagged packets from clients with vlan-id;
- winbox - added "Digest Algorithm" under "System/Certificates" menu;
- winbox - added "Note" field in LTE Firmware Upgrade;
- winbox - added "Reselect Time" for wifi;
- winbox - added Address List Extra Time under "IP/DNS" menu;
- winbox - added EAP identity under "WiFi/Registration" menu;
- winbox - added Heartbeat under "Bridge/MLAG" menu;
- winbox - added Installation under "WiFi" menu;
- winbox - added missing columns under "System/Users/SSH Keys" menu;
- winbox - added missing Comments under "User Manager" menus;
- winbox - added missing properties to "Container" menu and improved field ordering;
- winbox - added missing WPA2 PSK SHA2 option under "WiFi/Security" menu;
- winbox - added MPLS Mangle;
- winbox - added option to create new entries under "System/Users/SSH Keys" menu;
- winbox - allow selecting bonding interface under "Switch/Rule" menu;
- winbox - allow to specify CAPsMAN Address as IPv6 LL;
- winbox - bump minimal WinBox version to 3.42;
- winbox - correctly unset Locked CAPsMAN field;
- winbox - differentiate PPP Profile Rx/Tx Queue settings;
- winbox - display errors from the "Files/Sync" menu;
- winbox - fixed container RAM parameter type;
- winbox - fixed missing warning under "Routing/BGP/Instances" menu;
- winbox - fixed Record Type field under "Tools/Netwatch" menu;
- winbox - improved byte type field representation;
- winbox - improved Switch QoS layout;
- winbox - make IPv6 Immediate Gateway read-only;
- winbox - make log message field as multiline;
- winbox - move CAPsMAN settings button from Remote CAP to WiFi table;
- winbox - removed duplicate mounts option;
- winbox - rename Ping Timeout field to Interval;
- winbox - rename SMS Type field to Modem Type;
- winbox - rework LTE firmware upgrade buttons into one window;
- winbox - show "Switch" related menus only on boards that support such features;
- winbox - show all columns under "System/Users/SSH Keys" menu by default;
- winbox - use same WireGuard default values as in console;
- wireguard - fixed minor memory leak when IPv6 is disabled;
- wireguard - improved system stability on busy devices;
- wireless - changed CLI snooper column name "freq" to "channel";
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
