V7.21beta [testing] is released!
RouterOS version 7.21beta has been released on the "v7 testing" channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.21beta11 (2025-Nov-26 16:09):
  • iot - added Modbus rx-switch-offset parameter which helps offset Rx window;
  • ospf - fixed wrong LS Ack warning;
  • pimsm - added comment for static-rp;
  • port - fixed displaying "baud-rate=auto" on x86;
  • wifi - added configuration parameters relevant to the upcoming WiFi 7 products (additional fixes);
  • wifi - improved regulatory compliance for Bangladesh country profile;
What's new in 7.21beta9 (2025-Nov-25 08:08):
  • bgp-vpn - fixed prefix matching for filters "dst" matcher;
  • certificate - added certificate "trust-store" parameter (additional fixes);
  • certificate - added option to configure built-in trust store (replaced "builtin-trust-anchors" parameter) (additional fixes);
  • firewall - fixed "tls-host" not matching expected hosts;
  • isis - improved service stability when receiving a hello packet;
  • lte - provide firmware download URL when no LTE package installed on "SXT LTE3-7";
  • lte - ask for user confirmation before installing eSIM profile (CLI and WinBox 4 only) (additional fixes);
  • lte - do not retry activation for IPv4 and IPv6 APNs on QMI modems if only one address family is assigned;
  • route - fixed some routes installed in main routing table instead of specified VRF;
  • user - improved login service stability on busy system;
  • wifi - add configuration parameters relevant to the upcoming WiFi 7 products;
  • wifi - fix possible duplicate values for WPA3 authentication types in scan results;
  • winbox - added missing "SM-DP+ Oid" LTE eSIM provisioning field;
  • winbox - hide certificate "Issuer" field for certificate template;
  • winbox - show "Trusted" field for certificate template;
  • wireguard - added VRF option (CLI only) (additional fixes);
  • wireless - improved system stability when stopping scan process;
Other beta changelogs:
https://mikrotik.com/download/changelogs?channelFilter=testing
What's new in 7.21beta2 (2025-Oct-06 16:06):
  • arm64 - allow enabling receive packet steering on /system/resource/irq/rps menu in order to overcome unbalanced CPU load;
  • bgp - added output.network-blackhole setting;
  • bgp - allow duplicate router-ids for eBGP sessions (RFC-6286);
  • bgp - always advertise extended nexthop cap for all supported address families;
  • bgp - do not allow iBGP with non-equal ASNs;
  • bgp - do not auto-generate blackhole routes by default (introduced in v7.20);
  • bgp - fixed inactive flag in GUI after instance disable/enable;
  • bgp - fixed route refresh subcode 0 warning;
  • bgp - fixed selection of received BGP VPN routes;
  • bgp - implement RFC 9234 route leak prevention and detection using roles;
  • bonding - added lacp-system-id and lacp-system-priority settings;
  • bonding - fixed lacp-mode=passive;
  • bonding - improved stability for 802.3ad LACP;
  • bridge - fixed filter and NAT matching with "mac-protocol=length";
  • bridge - fixed missing local MAC after changing protocol-mode setting;
  • bridge - fixed static host and MDB entry updates on VLAN add/remove;
  • bridge - improved DHCP Option 82 values (circuit-id:"interface-name:vid", remote-id:"bridge MAC address");
  • bridge - improved stability after failed protocol-mode=mstp change;
  • bth - added file-share link preview;
  • bth - fixed big file upload;
  • bth - fixed file-share expire after reboot;
  • certificate - added SHA384, SHA512 support for SCEP;
  • certificate - allow ca-crl-host parameter for issued certificates;
  • certificate - improved Let's Encrypt logging;
  • certificate - on certificate import, added the "issued" flag if the certificate store contains the imported certificate's CA and its private key;
  • certificate - refactored Certificate internal processes;
  • chr - fixed guest OS type "Other Linux (64-bit)";
  • console - added "mvrp" to mac-protocol setting;
  • console - added changelog to /system/package/update/check-for-updates;
  • console - added delimiter parameter to :toarray command;
  • console - added reset command to settings directories;
  • console - added sensitive flag to QR code in WireGuard "show-client-config";
  • console - added show-sensitive option for print command, hide sensitive settings in print output by default;
  • console - do not set values when "setup" command is interrupted;
  • console - fixed :convert from=num on MIPSBE;
  • console - fixed ".id" printing when using "group-by" (introduced in v7.20);
  • console - fixed "special-login" setting incorrect channel;
  • console - fixed autocomplete in fullscreen editor to append tabs, spaces, etc;
  • console - fixed ip6-prefix visual representation;
  • console - fixed relative path printing (introduced in v7.20);
  • console - improved help for address arguments;
  • console - improved printing visuals (column layout and paging);
  • console - improved stability;
  • console - remove unnecessary commands from /ip/hotspot/active menu;
  • console - removed /quickset menu;
  • console - return error values for certain commands if action failed (e.g. /system/routerboard/upgrade);
  • console - show fullscreen script editor completions above hintbar;
  • console - updated "Change your password" to "Change your password (Ctrl-C to skip)";
  • container - added "/app" menu for simple containerized app installation (requires "container" package);
  • container - added CPU usage;
  • container - added hosts setting;
  • container - added kill command to send signals (CLI only);
  • container - added option to limit CPUs used by containers;
  • container - added root dir size;
  • container - added run command to allow interactive mode (CLI only);
  • container - added stop-time setting;
  • container - added update command (CLI only);
  • container - allow to configure extra ENV variables directly in container;
  • container - allow to disable/enable envs and mounts;
  • container - allow to specify mounts directly in container;
  • container - calculate volume sizes;
  • container - convert container mounts setting to mountlists, old mount name becomes list name, list name can map to multiple mounts;
  • container - enable relevant kernel features to support more container apps;
  • container - fixed error for starting container which consists of large number of layers;
  • container - fixed extract issues;
  • container - fixed VETH when using long interface name;
  • container - have per container layer-dir setting to be able to have separate layer stores for different sets of containers;
  • container - improved stability and fixed other issues;
  • container - show detailed import status, helps understand long imports;
  • container - show image-id field (CLI only);
  • container - store image import data (allows keeping container after netinstall);
  • detnet - do not try detection on slave interfaces;
  • detnet - fixed unnecessary process starting even when feature is not enabled;
  • dhcp - allow to set other gateway types not just IP for dhcp lease "routes" parameter;
  • dhcp-server - added "support-broadcom-tr101" setting to pass additional Option 82 suboptions to RADIUS server;
  • dhcp6-server - attempt to extract MAC from DUID for dual-stack purposes when client uses DUID-EN type of DUID;
  • dhcpv4-client - don't stop client on unsuccessful client option value change;
  • dhcpv4-server - added setting allowing to select client-id, MAC address or both for dynamic lease addition;
  • dhcpv4-server - improved logging;
  • dhcpv4-server - improved setup wizard prompts relating to DNS;
  • dhcpv4-server - respond with hlen 0 when htype is 8;
  • dhcpv4-server - send RADIUS Accounting Stop messages when interim-update is zero;
  • dhcpv6 - improved console hints;
  • dhcpv6-client - do not show I flag for disabled client;
  • dhcpv6-client - fixed misleading "couldn't acquire address, continue with prefix only" error when prefix is not even requested;
  • dhcpv6-relay - added "about" error message option;
  • dhcpv6-relay - enable configuration of options that are added to relayed DHCPv6 requests;
  • dhcpv6-server - added accounting to use-radius setting, similar to DHCPv4 server;
  • dhcpv6-server - improved event logging messages;
  • dhcpv6-server - improved service stability when receiving DHCP requests for PPP service clients without included IA_PD;
  • dhcpv6-server - include traffic usage statistics when accounting is stopped due to binding expiry and removal;
  • discovery - correctly report PoE dual signature per-pair class;
  • discovery - fixed MNDP IPv6 status reporting;
  • discovery - send out neighbor discovery immediately on IPv4/IPv6 changes;
  • disk - added nvme-tcp-server-nqn setting to be able to explicitly configure NQN, will default to "nqn.2000-02.com.mikrotik:slot" for new configurations;
  • disk - allow ":" and "." in slot name;
  • disk - allow only lowercase chars in iscsi-server-iqn;
  • disk - allow to have type=file devices without rose-storage (needed for file based swap);
  • disk - allow to set smb-share only for type=smb;
  • disk - consolidate client states into single field, as each item can be only one type of "client";
  • disk - do not allow setting raid-master when have filesystem;
  • disk - do not allow starting Btrfs replace when replace is suspended;
  • disk - do not delete partition configs on device remove and eject (fixes lost config with unstable hardware);
  • disk - fixed for SMB mount to be writable by container;
  • disk - fixed iscsi client;
  • disk - fixed iscsi export disable;
  • disk - fixed issue with double "/" in SMB share path for some clients;
  • disk - fixed SATA eject/scan;
  • disk - fixed write RAID superblock;
  • disk - improved cleanup order to avoid waiting for timeouts on shutdown;
  • disk - improved RDS2216 SATA controller;
  • disk - improved system stability;
  • disk - rename nvme-tcp client name to nqn everywhere symmetrically with server;
  • disk - show NVMe critical warnings;
  • disk - unshare iscsi and nfs client/server ids, add iscsi-server-iqn;
  • disk - update interface type/speed after scan;
  • disk - use default label when nothing specified when formatting from WinBox;
  • dns - added VRF support for ":resolve" command;
  • dns - added VRF support for DNS servers;
  • email - return all errors to console when executed from console;
  • eoipv6,gre6,ipip6 - added "dont-fragment" setting and allow packet fragmentation for packet sizes exceeding underlay interface MTU;
  • ethernet - added "unsupported speed" for forced 1Gbps modes;
  • ethernet - change default L2MTU 1518 to 1596 for RB5009;
  • ethernet - fixed 2.5G-baseT link-partner-advertising on RB5009, hAP ax3, Chateau ax devices;
  • evpn - fixed Ethernet Segment (ES) routes;
  • fetch - added "http-percent-encoding" parameter;
  • fetch - fixed http headers appearance when received payload is empty;
  • fetch - send http-data for any http method;
  • file - distinguish empty mount points from disks;
  • firewall - added "h" flag indicating that firewall service helper is applied for particular connection;
  • firewall - added support for TOS/mask matching for raw rules;
  • firewall - fixed hotspot value loss on rule enable/disable;
  • firewall - fixed strip-ipv4-options always passthrough;
  • firewall - hide hw-offload setting from devices that do not support it;
  • firewall - improved system stability and memory allocation when using firewall services;
  • firewall - make hw-offload=yes default setting in /ip/firewall/filter menu;
  • firewall - use the highest TTL as timeout value for domain address list entries if multiple domain names resolve to same IP;
  • health - upgraded fan controller firmware to latest version;
  • hotspot - added TOTP support for local hotspot users;
  • hotspot - improved system stability;
  • ike2 - adapt rekey procedure for compatibility with Libreswan;
  • iot - added mqtt disconnect/connect GUI options;
  • ip-service - do not duplicate entries for containers running in same netns;
  • ip-settings - limit IPv4/IPv6 max-neighbor-entries maximum value;
  • ippool6 - added "Valid Lifetime" and "Preferred Lifetime" options and use them when constructing IPv6 address;
  • ippool6 - fixed minor memory leak;
  • ippool6 - log address removal;
  • ippool6 - take into account "subnet-id" when specified on address;
  • ipsec - fixed CHACHA20 typo in log messages;
  • ipsec - support Post-Quantum Pre-shared Key (PPK) with QKD integration;
  • ipv6 - added "none" option for IPv6/ND/Prefix when advertising just options, not prefix;
  • ipv6 - added "self" option for IPv6/ND DNS advertise settings;
  • ipv6 - allow to specify on which interfaces to accept Router-Advertisements;
  • ipv6 - do not disable/enable Router-Advertisements functionality based on IPv6/ND configuration;
  • ipv6 - remove SLAAC installed DNS server and route on expire;
  • isis - improved stability;
  • l3hw - added per-VLAN "l3-hw-offloading" setting and "H" flag for /intervace/vlan menu;
  • l3hw - display warning when partial offloading is active (suggest users to use suppress-hw-offloading to control which routes gets HW offloaded and which are CPU processed);
  • l3hw - fixed partial offloading with /31 routes;
  • l3hw - fixed per-VLAN counters when packets are going through CPU;
  • l3hw - fixed VLAN and VXLAN counters for CRS520 device;
  • l3hw - improved stability and performance during L3HW enable with many routes;
  • l3hw - improvements and optimizations for IPv4 /32 and IPv6 /128 route offloading;
  • l3hw - prioritize local IP address over ARP/neighbor entry with same IP (fixes incorrect packet flow);
  • log - fixed ISO8601 time format;
  • log - fixed remote logging on remote-protocol configuration change;
  • log - fixed unnecessary file creation when configuring a disabled log action with "target=disk";
  • log - hide irrelevant log action parameters;
  • log - limit firewall log prefix length;
  • log - limit log socket buffer memory size;
  • lte - added "force-delete" command to allow deletion of active eSIM profiles;
  • lte - added additional logging for error reported by modem during APN profile setup;
  • lte - added command to send out EUICC generated notifications manually;
  • lte - added confirmation prompt when deleting eSIM profile (CLI only);
  • lte - added support for additional D-Link DWM-222 variation (vendor-id="0x2001" device-id="0x7e46");
  • lte - added support for additional Huawei E3372-325 variation (vendor-id="0x3566" device-id="0x2001");
  • lte - added support for R11e-LTE6 v039 firmware release and availability notification;
  • lte - ask for user confirmation before installing eSIM profile (CLI only);
  • lte - clear SIM not present error when performing modem FW upgrade;
  • lte - discontinued support for RBSXTLTE3-7, further versions will use v7.20 LTE firmware package;
  • lte - fixed cases where LTE monitor could show abnormalities;
  • lte - fixed issue with firmware update for FG621-EA modem;
  • lte - force sms-protocol to AT for FG621-EA modem;
  • lte - improved AT modems at-chat control channel handling after modem has closed AT channel unexpectedly;
  • lte - improved modem recovery for Chateau 5G and Chateau 5G R16;
  • lte - improved stability for FG621-EA modem;
  • lte - improved system stability when receiving SMS messages;
  • lte - relay EUICC generated notifications after profile enable/disable/remove/provision;
  • lte - rework multiapn support for AT modems;
  • lte - unify "SIM not present" status for all modems;
  • macsec - work on hardware-offloaded support (available only on QCA8081 PHY: RB5009, hAP ax3, Chateau ax ether1 port);
  • media - fixed console autocomplete for path parameter;
  • mpls - fixed LDP filter upgrade from v6 where neighbor parameter is not specified;
  • mpls - fixed LDP label binding if nexthop is link-local address;
  • netinstall - fixed install with old RouterBOOT;
  • ospf - changed nssa-translator default value from no to candidate;
  • ospf - improved stability;
  • ospf - show interface as separate prop for interface and neighbor;
  • ovpn-server - added support for pushing IPv6 routes;
  • poe-out - added input name hint to poe max-power settings;
  • poe-out - added LED blink on error for RB5009;
  • poe-out - firmware update for 802.3at capable boards (the update will cause brief power interruption to poe-out interfaces);
  • poe-out - firmware update for 802.3bt capable boards (the update will cause brief power interruption to poe-out interfaces);
  • poe-out - improved firmware update stability;
  • poe-out - improved power-on mechanism for 802.3at capable boards;
  • port - added comment for /port/remote-access (CLI only);
  • port - added support for additional baudrates for USB to serial adapters;
  • port - do not show serial port for ATL 5G R16;
  • port - fixed export for default serial port name;
  • port - give "gps" prefix for R11e-LR8G and R11e-LR9G GPS ports;
  • qos-hw - added "default" flags to default entries;
  • qos-hw - added "mirror-profile" which allows to select profile (traffic-class) for mirrored traffic;
  • qos-hw - always show usage and PFC counters, even when they are zero (CLI only);
  • qos-hw - fixed counters for ports that are configured with "offline" tx-manager;
  • qos-hw - fixed profile add/remove for CRS812;
  • qos-hw - fixed shared-pools for CRS812;
  • qos-hw - remove unnecessary "offline" tx-manager for CRS812 (not supported by hardware);
  • queue - improved system stability when using SFQ kind of queues;
  • quickset - fixed issue where routes set by Quickset did not appear in export;
  • route - added options in /routing/settings to adjust check-gateway=ping timers;
  • route - fixed SNMP output for ECMP routes having interface gateways;
  • route - hide suppress-hw-offload setting from devices that do not support it;
  • route - improved stability;
  • route - improved system stability with multicast routing;
  • route - make check-gateway=ping work on p2p interface gateways;
  • route - removed /routing stats mem-blocks;
  • routerboot - fixed boot MAC for CRS305-1G-4S+ and CRS328-4C-20S-4S+ switches ("/system routerboard upgrade" required);
  • sfp - expose sfp-cmis-module-state to monitor;
  • sfp - filter out non-breakout modes for breakout modules;
  • sfp - fixed combo-mode change for CRS326-4C+20G+2Q+;
  • sfp - fixed missing link up/down notifies;
  • sfp - improved initialization and linking for 25G DAC on CRS812;
  • sfp - improved system stability with some GPON modules for CRS418, CCR2004 and CCR2116 devices;
  • sfp - recognize 40G Active Cable (XLPPI);
  • sfp - remove 40G-baseCR4, 40G-baseSR4-LR4 from sfp-supported list for qsfp28-x-3 interfaces;
  • snmp - added lldpLocChassisId OID;
  • snmp - count only "bound" leases for mtxrDHCPLeaseCount OID;
  • snmp - make lldpLocPortId and lldpLocPortDesc OIDs information consistent with LLDP TLVs;
  • ssh - renamed User SSH keys "key-owner" field to "info";
  • ssh - "always-allow-password-login" replaced with "password-authentication" in SSH settings;
  • ssh - added support for ED25519-SK keys;
  • ssh - improved logging of failed login attempts;
  • ssh - refactored SSH service internal processes;
  • supout - added info log entry when autosupout.rif is generated;
  • switch - added dynamic "copy-to-cpu" ACL rule for loop-protecct;
  • switch - automatically add local bridge MAC to switch FDB;
  • switch - improved stability on MediaTek switch chips;
  • swos - fixed "allow-from" setting for MIPSBE devices;
  • system - added disks to /system/resource/hardware list;
  • system - fixed local update package filename generation;
  • system - fixed network header offset for interfaces with MAC (fixes VRRP Tx on IGMP snooping bridge);
  • system - fixed potential configuration loss when available disk space was insufficient;
  • system - fixed saving panic logs to autosupout.rif for ARM CRS3xx devices;
  • system - improved incoming TCP connection responsiveness;
  • system - improved system stability when processing GRE packets on TILE devices;
  • system - improved system stability when using hardware-offloaded encryption on RB3011 and hAP ac2 (introduced in v7.20);
  • system - improved system stability;
  • system - limit number of interface-lists to 244;
  • tr069-client - added LTE link recovery timer setting;
  • tr069-client - allow disabling Device.WiFi.AccessPoint;
  • traffic-generator - added support for injecting pcapng files;
  • undo - do not show internally issued commands in /system/history;
  • undo - show console commands in winbox/webfig for /system/history entries;
  • usb - LTE modem and USB-Serial Controller enumeration fix;
  • usb - support video capture devices for arm64 and x86, for passthrough to containers;
  • user-manager - added RadSec support;
  • veth - add container-mac-address setting;
  • veth - added default print brief table mode;
  • veth - added dhcp setting that allows to auto-configure IPv4 address, works when VETH is bridged with other interfaces and there is a DHCP server running somewhere on that network;
  • veth - complain immediately when VETH gateway not reachable, more detailed error message when network setup fails;
  • veth - show only when container package installed;
  • vrf - added read-only property to IPv4/IPv6 addresses, ARP and IPv6 neighbor;
  • vrf - allow setting comment on default "lo" interface;
  • vrrp - do not show "ttl not 255" warning when received VRRP VRID does not match with configured VRID;
  • vrrp - fixed gratuitous ARP being sent after VRRP is disabled (fixes packet forwarding on HW offloaded bridge after VRRP is disabled);
  • webfig - added a hint for Undo/Redo buttons;
  • webfig - added Apps menu to login;
  • webfig - added capability to check/uncheck entry tree in skin designer;
  • webfig - added Copy capability;
  • webfig - added missing PPP types to Skin Designer;
  • webfig - added TCP State column for connection tracking table;
  • webfig - check if device is still reachable before disconnect on error;
  • webfig - fixed container config memory high input;
  • webfig - fixed form closing with saving when pressing Enter key (introduced in v7.20);
  • webfig - fixed interface settings and graphs (introduced in v7.20);
  • webfig - fixed issue where routes and PIM table did not load;
  • webfig - fixed issue where Torch stops running;
  • webfig - fixed name and title store in skins;
  • webfig - fixed new item window name when using skins;
  • webfig - improved container form loading performance when router has a lot of files;
  • webfig - improved mikrotik_logo.svg;
  • webfig - increase graph width for better scaling;
  • webfig - increase maximum number size in forms;
  • webfig - make close button a button instead of link;
  • webfig - make combobox accessible to screen readers;
  • webfig - remember last user in login page;
  • webfig - turn off auto-capitalize and auto-correct for on-screen keyboards;
  • wifi - added "CAP" information field on interfaces view;
  • wifi - added CAPsMAN forwarding support (datapath.traffic-processing=on-capsman);
  • wifi - enable configuration of "3gpp-info-raw" and "realms-raw" interworking parameters;
  • wifi - fixed issue when trying to use interface as bonding slave;
  • wifi - fixed multi-passphrase usage in combination with access-list;
  • wifi - fixed possible memory leak when failing to start AP on chosen channel;
  • wifi - fixed some CAPsMAN settings to be optional;
  • wifi - improved formatting of FT request action frames;
  • wifi - improved stability when capturing data at high rates with wifi sniffer;
  • wifi - increased accounting interval, maximum client entry count for 2.4GHz probe response delay feature;
  • wifi - rename ft-wpa2-eap authentication type to "ft-eap";
  • wifi - split access-list time property in days and time;
  • wifi-qcom - added Unsolicited BSS Transition Management Request support;
  • wifi-qcom - enable forcing RTS/CTS hardware protection modes;
  • wifi-qcom - improved default RTS/CTS policy for CPE station radios;
  • wifi-qcom - multicast-enhance will no longer apply for station mode configured devices;
  • winbox - added file selector for BTH files;
  • winbox - added support for new settings and fixed several existing ones;
  • winbox - Bandwith test, Speed test, Ping, Traceroute tools use RouterOS DNS service to resolve domain names;
  • winbox - fixed "Too many entries" not showing in WinBox v4;
  • winbox - fixed Disk iscsi/smb configuration;
  • winbox - fixed Disk NVMe-TCP configuration;
  • winbox - fixed Dude/Tools appearance after Apply action;
  • winbox - fixed graphs in some forms with big numbers;
  • winbox - fixed WinBox 3 application failure when opening IPv6/Firewall/Connection entry (introduced in v7.20);
  • winbox - hide IPv6 addresses for IP neighbors that no longer have them;
  • winbox - make multiple address fields required;
  • winbox - make separate inputs for WiFi Interworking "Authentication Types" and "Connection Capabilities" fields;
  • winbox - move VRF from Ethernet to generic Interface table;
  • winbox - restore route max object 10000 limit;
  • winbox - show warnings in Disk menu;
  • winbox - updated and shortened window titles (e.g. Address List -> Addresses);
  • wireguard - added VRF option (CLI only);
  • wireless - added last-ip parameter for the CAPSMAN registration-table tab;
  • www - added option to disable individual web services in /ip/service/webserver and IP>Services>Web Server;
  • www - improved stability (CVE-2025-10948);
  • www - removed ability to publish directories via "/files" www service;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
  • I encountered an issue, but I am not sure if it is related to this release
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device.
Nice. Please extend it to apply on the whole directory.
ie: /routing reset to reset the whole /routing configuration to the defaults (and remove any config made by the user).
Thanks!
Also, after upgrading, many session windows (eg: interfaces, queues, addresses) got messed up, meaning they lost their customizations in columns etc, and their positions.
The ping window in winbox no longer provides the option to select a VRF and/or interface.
This doesn’t look quite right :smiley:
My hAP ac3 is showing #error exporting "/app/settings" in /export.
Also in my hAP ac3, I noticed that /system/resource/irq/rps disappeared.
In my other devices, I noticed that /app set webtop auto-update=no appeared in /export, even though all "apps" (including "webtop") are disabled.
Lots of settings were reorganized in a full /export (like container mounts, veth, wireguard, vrf and zerotier settings).
This worries me because, for example:
  • Now VRFs are created after /ip/routes and /ip/firewall, which will cause problems in a /system/reset-configuration run-after-reset=export.rsc;
  • Same thing for container mounts defined after a /container add;
  • Same thing for /zerotier/interface/add instance=zt1 defined before /zerotier/set zt1.
This new option results in malformed Router Advertisement packets sent, SUP-201059.
Other than that, 7.21beta2 works well on RB5009UG+S+, E60iUGS, CRS309-1G-8S+ and CRS326-24G-2S+.
nice, finally I can mount ISCSI from Synology to MikroTik. not sure I still need it, but it works in this version
Good to see this was added, I’ve asked about this in the past. I’ll have to throw 7.21 on my test lab and try it out.
on arm64 platform with 128 cores also using RPS the cores from 92 to 128 are not used in handling interface irq, no increase in counters in system/resource/irq
SUP-196466
Thank you! SUP-185090 is now resolved! :handshake:
Finally I can use my hardware key! Thank you!
This is probably a game-changer. I am curious how it improves roaming in real world scenarios.
which driver packages are supported?
:heart_eyes:
Does this just fix the crash on parsing incomplete numerical Unicode in JSON strings or also the fact the REST API can be called without authentication?
Is disabling the REST API while having www for webfig enabled on the roadmap?
What is the definition of “Unsolicited” in this context? Is it about client sending a BSS transition management query without setting the BSS transition supported flag in the association request when connecting to the AP?
Someone here in the forum stated that the crash also happens on CLI json convert command. So this malformed json crash is not limited to www service.
Unsolicited: the AP sends (aka initiates) a request to the client saying: "please transition over to BSSID xyz because it has better signal for you, etc". Something like that. Just the opposite of solicited requests. Solicited when client ask AP for transition possibilities. Unsolicited when client gets this response without having asked for. The most stubborn clients can still ignore it. :sweat_smile:
I know. That’s why I wrote “in JSON strings”
Actually is because the AP “wants” to force the clients to fast roam to another AP, like for example when the channel is changed due to radars or due to reselect-interval finding a better channel. Without it the clients will roam but all network connections are reset.
It’s not clear when Unsolicited BSS Transition Management Requests are used.
On radar detection?
On channel change?
Are the wifi-qcom-ac chipsets covered?
It could be great to add dhcp6-client COS/DSCP settings like in dhcp4-client.
This works. However, there should also be an option to selectively choose whether or not to use the DNS server list provided by RA.
hAP ax3 loads and reboots after a minute
