RouterOS version 7.2rc3 has been released “v7 testing” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 7.2rc3 (2022-Jan-28 16:33):
*) bridge - fixed filter and NAT “set-priority” action;
*) queue - fixed traffic processing (introduced in v7.2rc2);
What’s new in 7.2rc2 (2022-Jan-28 11:00):
*) arm - fixed “shutdown” command on hAP ac^2;
*) bgp - fixed routing table and BGP configuration order in export;
*) bluetooth - disable scanning by default;
*) bridge - added fast-path and inter-VLAN routing FastTrack support when vlan-filtering is enabled;
*) bridge - fixed bridge filter and NAT rules on ARM64 and TILE devices;
*) capsman - improved stability when running background scan on CAP;
*) clock - properly notify all instances about time changes;
*) conntrack - properly detect helper status;
*) console - improved console responsiveness when processing received characters;
*) console - updated copyright notice;
*) crs3xx - fixed QSFP+ interface LEDs;
*) crs3xx - fixed optical SFP+ linking (introduced in v7.2rc1);
*) crs3xx - improved SFP+ interface linking after reboot for CRS312 device;
*) crs3xx - improved SFP+/QSFP+ link stability for CRS309, CRS312, CRS326-24S+2Q+ and CRS354 devices (introduced in v7.2rc1);
*) defconf - made “192.168.188.1/24” the default LAN IP address for LTE CPE devices;
*) dhcpv4-server - remove dynamic leases when server configuration is removed;
*) dot1x - added “server-fail-vlan-id”, “guest-vlan-id” and “reauth-timeout” settings for dot1x server;
*) dot1x - added “src-address”, “src-mac-address” and “src-port” settings for dynamic switch rules;
*) dot1x - added NAS-Port-ID attribute for RADIUS Access-Request;
*) firewall - improved system stability when using address lists (introduced in v7.2rc1);
*) hotspot - fixed memory leak on every web page loading;
*) hotspot - fixed web page loading using HTTPS;
*) ike2 - ignore “INITIAL-CONTACT” payload on responder when “send-initial-contact” is disabled;
*) interface - fixed minor memory leak when interface or connected route is changed;
*) l3hw - added HW offloaded FastTrack support for inter-VLAN routing;
*) l3hw - fixed HW offloaded NAT;
*) leds - fixed user LED on RB750Gr3;
*) log - include message also in e-mail body;
*) lora - fixed “antenna-gain” parameter unit;
*) lte - added 3 APN profile support and APN name re-using on R11e-LTE6;
*) lte - added MAC address and IPv6 LL address persistence after reboot on EG12 and EG18 modems;
*) lte - added class based support for configless RNDIS LTE modems;
*) lte - do not show external antenna selector on devices that does not support it;
*) lte - fixed IPv6 address addition after startup on R11e-LTE6;
*) lte - fixed possible timeouts when sending SMS in LTE only mode on R11e-LTE;
*) lte - fixed support for Sierra MC7710;
*) lte - fixed support for Telit 960;
*) lte - improved stability on “+EGMR” response in MBIM mode;
*) lte - improved support for sending/receiving SMS in LTE only mode on R11e-LTE6;
*) lte - properly recognize MBIM modem in USB port as LTE on Chateau 5G;
*) ospf - added “ptmp-broadcast” interface type (compatible with RouterOSv6 PTMP type);
*) ospf - convert ospf “static” redistribute to “static,dhcp,modem,vpn” after update from RouterOS v6;
*) ospf - fixed MD5 authentication;
*) ospf - fixed NBMA hello’s not being sent if priority is set to 0;
*) ospf - fixed default type-3 LSA’s not being injected to stub area;
*) ospf - fixed incorrect LSA types when changing area types;
*) ospf - fixed neighbor election failure;
*) ospf - improved logging;
*) ospf - improved stability on OSPFv3 instance disabling;
*) ovpn - improved UDP session handling;
*) ppp - fixed AT+CPIN chat when SIM PIN is specified;
*) pptp - show insecure connection warning on dynamic interfaces;
*) qsfp - correctly display auto-negotiation status;
*) queue - improved system stability when processing traffic;
*) route - fixed “suppress-hw-offload” update;
*) route - fixed router’s LSA for PTP networks;
*) route - fixed routing configuration export on SMIPS devices;
*) route - improved routing table print speed;
*) route - show OSPF and RIP specific attributes in “/routing route” table;
*) route-filter - fixed “return” action;
*) route-filter - fixed complex matchers with “|| or and &&”;
*) route-filter - fixed incorrect invert-match configuration upgrade from RouterOS v6;
*) route-filter - fixed range conversion after update from RouterOS v6;
*) rpki - made RPKI verify non-strict, introduces new state “unverified”;
*) rpki - show expire timer;
*) smb - fixed SMB2.0 disk size reporting;
*) snmp - added SFP vendor name to optical table;
*) snmp - added support for “ipv6AddrPrefixTable” and “ipv6RouteNumber” OID’s;
*) snmp - allow two level nesting for vlan, bonding speed query;
*) system - fixed license loss on some RB1100Dx4 and RB4011 devices;
*) traffic-flow - do not handle NAT events when “nat-events” is disabled;
*) traffic-generator - fixed transmit speed for multiple asymmetric streams;
*) usb - fixed display of incorrect port count for USB serial ports;
*) vlan - fixed improper VLAN priority addition for routed packets;
*) vxlan - allow unsetting “group” and “interface” properties;
*) webfig - do not show side menu if WebFig is disabled by skin;
*) winbox - added “Disconnect Notify” checkbox to “Interface/OVPN Client” menu;
*) winbox - added “Freq. Usage” and “Scan” buttons for WifiWave2 interfaces;
*) winbox - added “Ignore Missing” selector to “System/Packages” menu;
*) winbox - added “Routing Table” parameter for IPv6 routes;
*) winbox - added “VPN” tab to “Routing/BGP” menu;
*) winbox - added “VRF” parameter to “IP/Services” menu;
*) winbox - added “comment” parameter to “User Manager/Users” menu;
*) winbox - added MLAG support;
*) winbox - added SHA256 and SHA512 “Auth” values for OVPN menu’s;
*) winbox - added ZeroTier support;
*) winbox - added explicit “Upload” and “Download” names for “Bucket Size” parameters under “Queues” menu;
*) winbox - allow setting “Interface” parameter for 100G LED types;
*) winbox - do not show “Antenna Scan” button on devices that do not support it;
*) winbox - fixed “action” field in “IP/Web Proxy/Access” menu;
*) winbox - fixed CHR License renewing process;
*) winbox - fixed content filtering in “Tools/Packet Sniffer/Packets” menu;
*) winbox - fixed entry order in “Tools/Packet Sniffer/Packets” menu;
*) winbox - made OSPF interface type names consistent between CLI and GUI;
*) winbox - properly save “IPv6/Settings” menu in session file;
*) winbox - renamed “MBPS” to “Mbps” value unit name in “Tools/Traffic Generator” menu;
*) winbox - show “H” flag for offloaded connections in “IP/Firewall/Connections” menu;
*) winbox - show “System/SwOS” menu only on boards that have dual boot;
*) winbox - sort “Address List” parameter values alphabetically in “IP/DHCP Server/Leases” menu;
*) wireless - improved wireless connection stability during background scans;
*) wireless - fixed interface initialization on Metal 2SHPn;
*) x86 - added support for Intel E810 NIC;
*) x86 - made “no” the default value for “disable-running-check” ethernet parameter;
*) x86 - properly distinguish multiple NICs that share the same PCI bus number;
*) zerotier - made MAC and MTU values read-only;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
