v7.2rc2 and v7.2rc3 is released!
Well PPTP is safer than IPIP or GRE, which don’t have any red error if used without IPSec… There are lot of way to configure a Mikrotik in unsafe ways, so picking on PPTP seems arbitrary since it’s entirely possible the traffic inside may be encrypted thus PPTP wouldn’t be particular unsafe.
Not sure but this may fixable (or should be at least) by using /system/device-mode. I can see perhaps in mode=home providing this kind of error, but mode=“enterprise” the message ideally should be suppressed. The specific behavior of using device-mode set pptp=yes is undefined in the docs however, but seemingly if device-mode allowed PPTP, it’s should not be an error.
7.2rc3 broken IPv6 SNMP
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/mikrotik’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘IPV6-MIB::ipv6RouteTable’]
IPV6-MIB::ipv6RouteTable = No Such Object available on this agent at this OID
7.1 working as expected
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/mikrotik’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:2001’ ‘IPV6-MIB::ipv6RouteTable’]
IPV6-MIB::ipv6RouteDest[2000:0:0:0:0:0:0:0][3][2147483833] = 2000:0:0:0:0:0:0:0
Ok, i tried
already in enterprise mode
pptp=yes, reboot
still same
it is monkey business … Installing RC on ESXI is advanced stuff
and, nooo, MT decided to burn out eyes after all with red/error marking IFs, like we are novice users
Anyone having RADIUS/dot1x issues?
I have three User Manager instances (replicated) between my router and two switches. Most devices are now not responding and getting a timeout instead, I see responses to the EAP challenges but they don’t authorize.
I have also seen such red error message when configuring a tunnel with IPsec PSK (instead of using certificates). But it has gone away later.
I agree that a warning may be ok during configuration but it must be possible to override it when you deem the security sufficient for your usage scenario.
to correct my self
no, it is NOT working on CHR, 7.1 & 7.2 RC both broken on CHR
RB5009 does NOT support l3-hw-offloading (List of supported devices).
Setting hw-offload=yes for FastTrack firewall has a recommendatory meaning (i.e., “please offload if you can”). The actual HW offloading state of FastTrack connections appears in the connection list (H flag):
/ip/firewall/connection print
If you check the above command on RB5009, you notice none of the connections have the H flag (HW-offloaded).
The reason why RB5009 received a huge inter-VLAN routing performance boost in 7.2rc3 is FastPath / FastTrack support by vlan-filtered bridges. Routing is still done by the software (CPU), but now it is going via Fast Path, and RB5009 has a fast CPU.
P.S. Marvell 88E6393 switch chip used in RB5009 is capable of offloading a very limited amount of FastTrack connections, but the feature is not implemented into RouterOS yet. Anyway, if you need hardware-accelerated near wire-speed routing, I suggest looking at CCR2116.
But it is working fine on 7.2rc3 on my RB4011
Don’t you think it would be a good idea to work towards a 7.2 release that is feature complete relative to 6.49.2 and has most of the visible bugs fixed
that were introduced during the v6 to v7 transition?
Then the next step could be a 7.3 which adds all kinds of nice new features. But at least the users could “all” upgrade to v7 and/or have a fully functional
RouterOS again on their devices that only work with v7.
Right now it appears that more attention is going towards nice new features and speedups, but known unimplemented features are left behind.
Since there is no mention in changelog, any ETA on PIM?
yes, when i tested, i tried only CHR on RC
that was a reason for confusion
devices stayed on 7.1, CHR on RC
I tried it with 7.2rc3 and it works OK for me. I see that it returns the routing table data when there is any, and it displays that error message whenever there is no IPv6 route.
So maybe you don’t have IPv6 configured on that CHR.
The main focus is on bugfixes and v6 feature completion. According to the rc2 changelog, there are 82 changes (except Winbox): only 3 of them are new features, and 79 bugfixes or improvements.
So, faced same issue, FastTrack does not work for untagged ports in a VLAN-filtered bridge.
Works as soon as ports are tagged.
SUP-73092 opened accordingly.
Yeah, but several of those bugfixes are in features that were added in v7.
I would hope that priority would be somewhat like this:
1 - fixing of bugs that were not present in v6 but were introduced in v7
2 - completion of features that were present in v6 and are planned to be in v7 but are not yet implemented
3 - fixing bugs that are in the newly introduced features in v7
4 - introducing new features (and/or fixing bugs and limitations) that were not possible in v6
The sooner v7 can be declared a full and riskfree replacement of v6, the sooner all development and support capacity can be put on v7.
As soon as v7 is a no-brainer-update with a matching v6 stability, noone would like to stay on v6 for any reason. v6 could be shut-down and we would no longer talk a second about v6.
How about getting “ PIM-SM” working! :face_with_monocle:
Yes, I hope the focus will be on that, at least for the moment. So we can have a single version again. And don’t have to warn other users against blindly trying “upgrade”.
We have reproduced the issue. It is not related to untagged ports but frame-types. Setting frame-types=admit-only-untagged-and-priority-tagged disables Fast Path. We are working on the fix. Meanwhile, if possible, set frame-types=admit-all for untagged ports.
Good news, many @raimondsp !
