The system is not prepared to handle a crash that could be resolved by removing a package…
Exception is the use of partitioning. When you would partition the device, copy and upgrade a partition, and it fails to boot, it would boot the old (copied) partition and you would be back without netinstall.
The package is fine, it’s the driver that install it that likely crashes ;). What to do about that isn’t so clear, downgrade to “stock” wireless and convert the config?
In fairness, it’s the testing build & you’d generally want something to crash, as the core dump has exactly what went wrong, so it can be fixed.
That’s a good point. That Audience has the space for a 2nd partition. We use a lot of wAPacR, so there not room for even one partition (or even the wifiwave2 package)
No, actually partitioning on Audience is not a feasible option when running wifiwave2 package. I tried it with 7.2rc5 and it worked just fine. However when I tried to upgrade to 7.2 final, it failed due to lack of free space and I had to revert to single partition. My audience currently uses around 52MB of flash (no removeable files exist), download packages for 7.2.1 are 26.4MB (12.4MB for main and 14.0MB for wifiwave2), altogether it doesn’t fit 64MB partition (half of installed 128MB flash). Using RAM disk would help (my audience is currently at stable 142MB RAM used, so around 100MB unused), but sadly RAM disk is not an option on these devices.
The situation is probably identical on all other devices elligible for wifiwave2 drivers with flash size less than 256MB.
*) sfp - added 2.5Gbps rate for SFP+ and QSFP+ interfaces on 98DXxxxx and 98PX1012 switches (requires disabled auto-negotiation);
*) sfp - improved Q/SFP interface initialization and stability for 98DXxxxx and 98PX1012 switches;
*) bonding - fixed LACP flapping for RB5009 and CCR2004-16G-2S+ devices;
*) bridge - fixed packet marking for IP/IPv6 firewall;
*) dot1x - improved server stability when using re-authentication;
*) fetch - improved full disk detection;
*) gps - fixed minor value unit typo;
*) l3hw - improved offloading for directly connected hosts on CRS305, CRS326-24G-2S+, CRS328, CRS318, CRS310;
*) led - fixed QSFP+, QSFP28 activity LEDs when using 40Gbps modules (introduced in v7.3beta33);
*) lte - disabled wait for LTE auto attach;
*) mpls - fixed MPLS MTU and path MTU selection;
*) ovpn - fixed hardware offloading support on CHR;
*) ovpn - improved Windows client disconnect procedure in UDP mode;
*) ovpn - moved authentication failure messages to “info” logging level;
*) ppp - added warning when using prefix length other than /64 for router advertisement;
*) ppp - fixed “remote-ipv6-prefix” parameter unsetting;
*) ppp - fixed issue with multiple active sessions when “only-one” is enabled;
*) routerboot - properly reset system configuration when protected bootloader is enabled and reset button used;
*) rsvp-te - improved stability when “Resv” received for non-existing session;
*) sfp - improved QSFP/SFP interface initialization for 98DXxxxx switches;
*) switch - fixed missing stats from traffic-monitor for 98DXxxxx and 98PX1012 switches;
*) system - fixed RouterOS bootup when wifiwave2 package is installed (introduced in v7.3beta34);
*) system - fixed rare partial loss of RouterOS configuration after package upgrade/downgrade/install/uninstall;
*) user-manager - improved stability when received EAP attribute with non-existing state attribute;
*) vpls - fixed “pw-l2mtu” parameter usage;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Everyone, thank you very much for all the input regarding the configuration loss problem. For your reports in the forum and support tickets. By putting our heads together and combining all of your reports we managed to reproduce this problem and seems that we have resolved it. The fix is included in v7.3beta37 and, of course, if it will be proven safe (we have tested it ourselves reliably, but would like to see the feedback from beta releases), then it will be included in stable releases as well.
Please note that the upgrade happens on the old version, not the version which you try to install. So the fix applies only when you try to upgrade FROM 7.3beta37 or a later version. Downgrade to older versions than 7.3beta37 still will be affected.
That is great news! Good that you (and we) remained persistent and not believed in that “well that happened but it is so rare that we just imagine that it did not happen and will go away by itself”. Because that usually does not work in IT.
