v7.6beta [testing] is released!
This problem still exist in 7.6beta8
thx
what do you mean exactly?
I think it says that the advertisment to peer of the prefix is very slow when there is an huge rotuing table.
In my cases it need 3/4h to send all the advertised prefix.
several supouts (about several 7.6bx) sent for ticket 81652 e 86404
regards
Ros
[admin@R2] > /interface/macsec/print detail
Flags: I - inactive, X - disabled, R - running
 0 R name="macsec1" interface=ether2 status="open-encrypted"
     cak=5509eb30c8515ad7e383f52a7d612e6c
     ckn=6cbda7b285ddf825a8db1659995d87c43cc11b36a3727f10f4388cd4d7344b85
     profile=default
[admin@R2] > ping 10.10.10.1
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 10.10.10.1                                 56  64 2ms294us
    1 10.10.10.1                                 56  64 2ms421us
    2 10.10.10.1                                 56  64 2ms846us
    sent=3 received=3 packet-loss=0% min-rtt=2ms294us avg-rtt=2ms520us
   max-rtt=2ms846us
[admin@R2] >
macsec basic test working
We need both the advertised and the received number of routes.
no, but still not work since upgrade from ROS 6 .. long time allready :frowning:
What is adverts? advertisement? i would prefer the name similar with v6, “advertisements”.
CR2116-12G-4S+ originally netinstaleld with 7.6beta7, update via drag&drop file from 7.6beta7 to 7.6beta8 without problem.
No config lost.
Unreported FIXs:
*) On CCR2116-12G-4S+ with S-31DLC20D now do not need everytime manual disable/enable the sfp interface when reboot the router.
*) On CCR2116-12G-4S+ the S-31DLC20D now correctly support Auto Negotiation.
BUG:
Upgrade RouterBOOT require everytime dual boot.
(temporary fix: extract right firmware with 7-zip from .npk, and upgrade the BIOS before reboot for upgrade the OS)
I got RB3011UiAS-RM
it also got 128MB memory only but i update almost always to latest "testing" version without any problem
I can suggest bu your mikrotik and zero IT tottaly
You can also update it from other mikrotik
They release couple of days ago on youtube movie how to do that.
Okay, but on the issue of release don’t write like this, it’s incomprehensible,
and if he needs help he has to open his own topic, not to mix everything up here.
similar command /routing bgp> advertisements
YES
I think they plan to put the received number of routes in /routing/bgp/sessions in the prefix-count field, which currently always reads 0.
Finally, this release help me a lot, bgp issue is resolved with this release…
we still have issue:
  • 352 sessions
  • 3 fullroute providders
  • 10 routeservers
It starts after some minutes:
  • drpping sessiong about holdtimer expire
  • stop loading the routes from bigger provider
  • very late adverstisment of our prefixes
I think there is a bottleneck in updating the main routing table by bgp.
regards
finally. on which hardware did you test that?
hapac2 → hapac2 just for the sake of the test
Once one party reconnects, the network stops working.
You have to disable both ends and then enable both.
test between hap ac lite & hap ac2.
The stats should be made available as part of /routing/bgp/session instead of as a separate menu. So it can be displayed as a column in the sessions window and on the stats tab of the detail window of a session.
I tried on CRS328-24P-4S+ (7.6beta8) on an ethernet interface which is not part of a bridge, but get “Invalid slave interface”. Any idea?
[user@host] /interface/macsec> print
 0 I ;;; Invalid slave interface
     name="macsec1" interface=e20__TEST status="invalid" cak=4d84367e465e28c63333eb9589f6ec70
     ckn=6cbda7b285ddf825a8db1659995d87c43cc11b36a3727f10f4388cd4d7344b85 profile=default
