RouterOS version 7.7beta3 has been released “v7 testing” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 7.7beta3 (2022-Oct-26 11:31):
*) bgp - improved BGP advertisement printing;
*) bonding - properly detect VPLS interface state changes;
*) bridge - added support for static MDB entries;
*) bridge - disallow port-controller while the bridge has MSTP enabled;
*) bridge - fixed “edge=yes” setting for MSTP;
*) bridge - fixed incorrect root port blocking for MSTP;
*) bridge - fixed mst-override port priority for MSTP;
*) bridge - fixed MSTP compatibility with STP;
*) bridge - fixed port priority for STP and RSTP;
*) bridge - fixed RSTP BCP with bridged PPP interfaces;
*) bridge - fixed STP blocking state on port-controller;
*) bridge - improved port-controller system stability;
*) bridge - improved system stability when using MSTP and many VLAN mappings;
*) certificate - improved certificate management, signing and storing processes;
*) container - fixed handling of groups and usernames from Dockerfile;
*) dhcpv6-client - handle receiving of invalid T1 and T2 times;
*) discovery - added “discovered-by” parameter to indicate which protocol discovered the neighbor;
*) discovery - added “mode” parameter for discovery configuration;
*) discovery - fixed neighbor discovery on Mesh interfaces;
*) discovery - report IPv6 LL address if global address does not exist;
*) filesystem - fixed repartition on devices with containers;
*) hotspot - added “install-hotspot-queue” parameter to control dynamic queue creation (CLI only);
*) ike1 - improved expired IPsec-SA processing;
*) interface - improved system stability when handling large packets on CCR2216;
*) ipsec - removed Blowfish and Camellia encryption algorithms for IKE;
*) ipv6 - do not generate LL addresses for VPN interfaces when IPv6 is disabled;
*) ipv6 - do not use invalid/disabled global addresses for IPv6 ND;
*) l2tp - added VRF support for L2TP Ether interfaces;
*) lte - added CA information in 5G mode;
*) lte - fixed new MTU value validation;
*) lte - use RSRP value reported by MBIM signal for MBIM type modems;
*) lte - validate bearer count when activating MBIM modem;
*) macsec - fixed packet duplication on Ethernet interface;
*) macsec - fixed packet transmission using traffic-generator;
*) macsec - fixed packet validation;
*) netwatch - improved “interval” and “packet-interval” coexistence for ICMP type;
*) ntp - log error message when server is unreachable;
*) ospf - fixed simple authentication and checksums for NBMA and PTMP links;
*) ospf - fixed virtual-link address selection for PTP links;
*) ping - fixed ARP ping;
*) port - added serial port support for Telit FB990 modem;
*) port - do not show unusable USB port on hAP ax^2;
*) ppp - changed default lease time of dynamic DHCPv6 server to 1 day;
*) quickset - fixed addition of bridge filter rules in bridged mode;
*) quickset - fixed interface list member table on configuration changes;
*) quickset - update DNS server IP address when changing router’s IP address;
*) rb4011 - fixed reporting of current CPU frequency and changed default frequency to “auto”;
*) sfp - allow usage of “10G Base-LR” mode for XS+31LC10D module;
*) snmp - added support for “lldpRemLocalPortNum” OID’s;
*) supout - added missing IPv6 firewall sections;
*) supout - added MSTI and mst-override monitor for bridge MSTP;
*) switch - avoid packet corruption in some setups for 98DX3257, 98DX3255, 98DX4310, 98DX8525 and 98PX1012 switches;
*) switch - fixed SFP Tx disable when changing auto-negotiation settings for 98DXxxxx and 98PX1012 switches;
*) switch - improved 10Gbps Ethernet interface stability for 98DX8212 switch;
*) system - allow up to 4GB of RAM allocation per process on x86, ARM64 and TILE;
*) system - improved handling of user policies;
*) tr069-client - updated data model to version 2.15;
*) traffic-flow - fixed sending of sampling interval;
*) tunnels - added VRF support for EoIP, IPIP and GRE tunnels;
*) vxlan - added “local-address” parameter support;
*) vxlan - added VRF support;
*) webfig - fixed displaying of VRF routes;
*) webfig - fixed input validation for “VPLS ID” parameter;
*) webfig - fixed setting of “DHCP Option Set” parameter;
*) wifiwave2 - added “datapath” settings to configure data forwarding for an interface (CLI only);
*) wifiwave2 - added disable/enable commands to configuration profile sub-menus (CLI only);
*) wifiwave2 - added interworking/Hotspot 2.0 support (CLI only);
*) wifiwave2 - added more informative log messages on configuration profile changes;
*) wifiwave2 - added option to set per-client vlan-id in access list (only supported on 802.11ax interfaces) (CLI only);
*) wifiwave2 - added “provisioning” menu to automatically assign interface configurations to radios (CLI only);
*) wifiwave2 - do not permit a client device to be connected to more than one interface at a time;
*) wifiwave2 - removed maximum limit for group key update interval and changed the default to 1 day;
*) winbox - added “Active” prefix for current “Circuit ID” and “Cookie Length” fields for L2TP-Ether interfaces;
*) winbox - added “Make Static” button to “IP/DHCP Server/Leases” menu;
*) winbox - fixed minor typo in “Zerotier” menu;
*) winbox - improved handling of large WinBox protocol messages;
*) winbox - properly save “Interfaces/Detect Internet/Detect Internet State” menu in session file;
*) winbox - show “Switch” menu on Chateau 5G ax;
*) winbox - show “System/Health/Settings” only on boards that have configurable values;
*) winbox - show “System/RouterBOARD/Mode Button” on devices that have such feature;
*) winbox - show “USB Power Reset” menu on Chateau 5G ax;
*) wireless - fixed setting of realms interworking parameter if realms-raw is unset;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
