Running the script (no matter if on terminal or on winbox) the run script count increase by 1 and /system script environment report the right value.
But after some minutes and after terminal or winbox is closed, the run script count return to 0 and the environment is cleaned.
I hope you believe me, I’m not the only user notice that and also because I indicated exactly the hardware used and how the device is configured…
No, also tried on 7.4 and 7.6, but the device is always installed from 0 by netinstall.
Tomorrow I try to find one RB951 to test it,
but the bug appears both on RB911G-5HPnD and on RB922UAGS-5HPacD with RouterOS 7.7rc1 and RouterBOOT 7.7rc1 with WinBox 3.37 64 bit
(powered by PoE 24V from a CRS112-8P-4S-IN), do not appear on RB5009 (arm64).
Currently I have done the test on a hAP ac3 (arm) and the same thing happens, the global variables disappear from the environment after a few minutes of closing the winbox.
the 7,7rc1 in our case (more then 5M routes) freezes when modify a filter rule.
opened ticket [SUP-100981]
very dangerous case because the router desn’t reboot just freeze and need a powercycle.
