What seems to be the issue?
Did you follow the example in the wifiwave2 documentation?
You may need to set /interface/wifiwave2/cap set discovery-interfaces=all on the cAP as well as add wifi interfaces to a bridge for wireless clients to get DHCP addresses.
Also WPA1 and WPA3 cannot be used simultaneously.
Please elaborate.
Name(slot) does not change on previously added/formatted disks. On newly done formats slot will assume new name based on physical slot. If name was “disk1”, slot will stay “disk1” until you reformat.
maybe you need dns-forward domain many times, it will crash the dns, then it will be empty, pppoe-client still online. alreay have the video and submit to the ticket
Same here, was using the United States3 country in 7.7beta6 but now unable to get any United States country configuration to work. Along with the /interface/wifiwave2/info command being removed or moved somewhere I haven’t been able to locate yet.
Upgraded RB5009 from 7.7beta9 to 7.7rc1 using Winbox “Check For Updates” - upgrade itself worked, installed and latest versions reported correctly, but the changelog window (both before and after upgrade) still shows “What’s new in 7.7beta9” and the corresponding 7.7beta9 changelog.
We’ve noticed in 7.7rc1 that when using ipv6 the dynamic routes do not update with old delegated prefix staying in the list well after they have been changed.
In our test we adjusted the delegated range in our clients Radius Auth from 1::/64 to a::/64 however in the routing table 30 minutes later still showed the old route. Secondly when testing ipv6 address assignment from a pool we noted that if the customer assigned the IP to the wrong interface eg. WAN instead of LAN and then reconfigured the assignment to the correct interface eg. LAN on the PE there remains in the routing table the original direct route and the new route containing the intermediate.
Due to the new route having an intermediate it is not enabled and leaves the old direct and now invalid route active. The only fix we have found is to reboot the PE router as these routes survived a CPE reboot also.
Incorrect PE Routing and Neighbour List showing multiple routes:
After Reboot of PE Only the 1 route:
I could have it totally incorrectly configured also
Did some more digging into 7.7rc1 and the radio issues on the hAP ax2. Seems it is missing the countries configuration in the radio after updating, I suspect this means it won’t accept any country.
Output from 7.6 release and 7.7rc1, note the missing counties field and info country-info output in 7.7rc1:
Any information on how to use this ?
I can make a GRE tunnel inside a vrf but cannot got outside. Eg src/dst of the tunnel in VRF External vrf, but not the IP of the tunnel.
