With a little sorting on the product matrix, I count 32 products. Compressing it to product families, we get:
BaseBox 2, 5, 6
CRS109-8G-1S-2HnD-IN
CRS125-24G-1S-2HnD-IN
KNOT LR8 & LR9 kits
mANTBox 15s & 19s; mANTBox 2 12s
NetBox 5
NetMetal 5 series
QRT 5 series
RB2011 series
RB911, 912, 922, and 951 series
SXT SA5 series
I don’t know how to quickly verify which ones are both in production and have ready stock, but there are some familiar pieces on that list such as the venerable CRS109 and RB2011.
you can’t fit that package on such little storage.
My understanding is that MIPS boxes have under 2 MB of flash free these days. I looked at the ARM package, and it’s nearly 4 MB. However, I did say it should be pared down to the clients alone. That might be enough, and if not, then you take the next step and remove them in fattest-to-slimmest order until you get under the limit. I suspect “nVME-over-TCP” is the slimmest, but whatever it turns out to be, one is better than none.
I just have been toying with it.
Experienced complete crash on AC3 when enabling capsman.
Log files after reboot seem to indicate system and wave2 package were installed. Again ?
It did not happen again afterwards so maybe a glitch ?
The storage package needs a lot more doc. It seems that it is possible to mount an iSCSI volume, and to export an NFS volume, but is it also possible to mount an NFS shared directory from another system? I do not see the parameter to specify the server path. As in:
mount -t nfs server:/path /mountpoint
type nfs and mountpoint are clear.
Just tried rose-storage. Using 2 SATA-III SSDs inside RB1100, I can at least create a “mirrored disks” (RAID 1). So that part works!
But noticed several things:
Files window in winbox still shows a “sata1-part1”, even though that doesn’t exist. The raid volume does show up e.g. raid1-part1 okay however.
2a. Setting the slot= on a raid partition, doesn’t persist reboot. e.g. I’d set the slot=disk1, but after reboot comes back as default raid1-part1.
2b. Similar nfs-export and smb-export also don’t seem to persist reboot.
Could NOT mount RouterOS ROSE disks using NFS Mac after using nfs-export=yes - tried various things: Finder using URL, Terminal using mount, using both and :/raid1-part1 in path – nothing obvious seem to work and docs less helpful here.
The relationship with existing /ip/smb is unclear. I do NOT have /ip/smb enabled, but did try smb-export=yes in /disks. Similar issues to NFS - couldn’t figure out any way to mount. Only thing that got close was if I add smb-share=/disk1, then MacOS prompts for a password when using smb://<MT_IP>/disk1 - but neither using “Guest” or “Registered User” with ROS creds failed so no mount. If you set smb-user=/smb-password=, then it doesn’t even prompt for a password on MacOS and doesn’t work either - but those seem more to mount a SMB volume on RouterOS (I’m was trying to share the ROSE disk as SMB share)
Basically I have a working mirrored disk, that cannot be renamed or shared. RAID alone is still useful, but clearly some better docs and/or bug fixes might be needed…
Small nuance: NO as it is right now.
But it has been stated the possibility might come in the future that both legacy and wave2 capsman could be integrated in one solution. ETA ? Crystal ball needed …
That’s a bit sad, since i have 6 non Wave 2 devices and two Wave 2 (AC3), that will now be replaced by RB5009 and left as an AP. So no way to put them on the same network. It is what it is.
You can still put them on the same network.
But you will need 2 different CAPSMAN controllers for the time being: one for legacy, one for wave2 (and if you also want redundancy, multiply by 2).
Like you say: it is what it is.
Even with APs within the same capsman constellation, there is no seamless switch.
I believe you need roaming parts of the wifi-specs for that to happen. It’s being worked on but not fully implemented yet (as it is now to my knowledge, only within same AP = from 2.4 to 5Ghz and vice versa if same SSID is used. Unless I missed something in the latest versions in that context.).
Not realy sure. When i tested this with PING from my phone i moved from one AP to another and PING didn’t drop inbetween. But sometimes i notice, that phone doesn’t switch to another AP when it should. Especialy this is noticable when doing WiFi calling and call drops.
