v7.8beta [testing] is released!
capsman currently doesn’t improve roaming experience of wireless clients. capsman2 might (and hopefully will in the future). If you configure APs with same security profile (replicate it on APs directly or in other capsmans) and make sure resulting wireless interfaces are part of same L2 network (e.g. served by same DHCP server without resorting to DHCP relay or anything similarly redundant), then client roaming experience will be the same whether APs are provisioned by same capsman or if they are configured individually.
Eitehr way, it’s up to client to decide when it wants to switch, newer standards (802.11 r/k/v; only /r is implemented in wifiwave2 driver and works between radios of same AP) assist client by providing more information (k/v) and by allowing faster registration to target radio (r). When everything works as designed, then switch is very fast and user normally doesn’t notice it.
… but it will never be as fast as with some competing products that provide “seamless roaming”, i.e. the entire installation operates as a single AP MAC address on a single channel.
I hope this is one of your jokes.
Nope, it’s real.
What are the limitations for the CRS3xx devices that cause this version not to be recommended?
example?
No, really. There are manufacturers that offer a WiFi where there is only a single AP MAC for the controller, all APs listen on the same frequency and the same MAC, the traffic they receive is forwarded to the controller together with a signal strength value (RSSI), and the controller keeps the location of the strongest received signal so when they need to transmit data it can be sent via the AP where the signal is strongest.
With such a system there is no real roaming, it is just like a large single-frequency diversity system. There are absolutely no interruptions due to roaming.
But of course the fact that there is a single channel can limit the performance. However, more modern systems can operate several channels in parallel each with this system, so the users will be distributed over different channels.
Please provide an example of a manufacturer currently advertising such a feature.
Fortinet is one https://www.fortinet.com/blog/industry-trends/the-power-of-virtual-cell-wi-fi
which comes from acquisition of Meru Networks
It feels to me that, at least at this stage, it’s meant more for router-to-router use, particularly for containers on diskless devices. I couldn’t get a router to mount an iSCSI target from my TrueNAS box. I tried NFS and Samba from the 2116 to my Mac too. I couldn’t get anything to work the way one would expect to another computer.
I then loaded 7.8b2 on a hAP AC3 and connected it to the 2116 using NFS and it worked immediately. However, when trying to connect the hAP to the 2116 via iSCSI, the hAP just hung. Now, even after a reboot, it hangs when trying to export or print the disk config. I can’t even remove it, so I’ll have to reset it and try again.
[Edit] Turns out NFS works with Linux and macOS, provided you have the correct options: https://forum.mikrotik.com/viewtopic.php?p=979643#p979643
Yes - finally!! Confirmed fixed, Thanks!!
I appreciate storage management but at the moment Im not able to use SAMBA on 7.7 stable with my camers HIKVISION: I have already sent (SUP-104510) but no solution yet. I have hAP AX3 and I would like to use it as SAMBA server for my cameras but I have to keep old ASUS router with 1GB HDD to be able save vidoes from Cameras.
MIKROTIK PLEASE TAKE THIS SUP SERIOUSLY THERE ARE MILIONS OF HIKVISION CAMERAS AROUND THE GLOBE.
I got MacOS to mount the NFS share:
sudo mkdir /Volumes/2116/
sudo mount -t nfs -o vers=4,hard,bg,intr,resvport,rw 192.168.x.x:/nvme1 /Volumes/2116/
I also got it to auto mount the share:
# add to /etc/auto_master if you don't already have it
/-			auto_nfs	-nobrowse,nosuid
# create /etc/auto_nfs, then add this line for Catalina and later; 2116 is the name of my share, change it to what you want
# nvme1 is my disk's name on the 2116
/System/Volumes/Data/../Data/Volumes/2116	-fstype=nfs,vers=4,hard,bg,intr,resvport,rw  nfs://192.168.x.x/nvme1/
supporting disk monitoring, improved formatting, RAIDs, iSCSI ,NVMe over TCP,
Mmmm the PCIe CCR2004 will probably get much more interesting :wink:
I tried this:
add slot=nfs type=nfs nfs-address=192.168.1.3 nfs-share=/local/dreambox
it seems to try the mount (I see TCP port 2049 traffic) but no M appears in the listing of disks and it does not appear as a folder.
0   nfs      nfs://192.168.1.3//local/dreambox  network
1 M ramdisk                                     ram        800 002 048
I got the NFS mount working. However, there apparently are no error messages. So when I configured something incorrectly, it just silently accepted the “add” and then in showing the status the nfs line would not show the M status. I would have expected an error in the log indicating the failed mount, but there wasn’t any.
I got one of these for my lab CCR2116 (Orico M.2 NVMe to SATA Expansion Card):
Here’s what it looks like installed (top is off, sitting in rack):
I hooked up a Kingston 256GB SSD that I had in an enclosure and powered it via a separate power supply.
Flags: B - BLOCK-DEVICE; M, F - FORMATTING; p - PARTITION
Columns: SLOT, MODEL, SERIAL, INTERFACE, SIZE, FREE, FS, RAID-MASTER
#     SLOT               MODEL             SERIAL             INTERFACE                 SIZE             FREE  FS    RAID
0     pcie1              SATA Controller                      PCIe 2x8 GT/s                                          none
1 B   pcie1-sata1        KINGSTON SH103S3  50026B73XXXXXXXX   SATA 6.0 Gbps  240 057 409 536                         none
2 BMp pcie1-sata1-part1                    @512-240057409536                 240 057 409 024  235 152 457 728  ext4  none
Exported it via NFS, mounted the NFS share on my Mac, and with Blackmagic Disk Speed Test, I’m getting 136MB/s write, 496MB/s read (specs claim 555MB/s read, 510MB/s write).
I’ve ordered a 6-bay SSD 2.5" chassis to hook up to this thing to experiment with RAID and with exporting drives and/or partitions to diskless routers for containers, particularly my 2004’s with 4GB of RAM.
Now if I could only find a way to route those cables straight out a whole in the back and put the lid back on…
Does RouterOS support TRIM/UNMAP?
for us 7.8beta2 still has critical pppoe server issues:
  • after 48h the pppoe-servers (more 10.000 servers on the box) crashe and let the dynamic pppoe queues go invalid (reboot needed)
  • some time the dynamic pppoe-client interface doesn’t go running (you can manually remove them and let the client router to reauthneticate)
    [SUP-97493] updated with all the supout and autosupout generated
