submenu info country-info is removed.
Info is to be collected via /interface/wifiwave2/radio print detail
(but currently output is not of the same level/detail as it was using country-info so I asked about that again)
EDIT: extended info will become available in /interface/wifiwave2/radio print detail
Oh but it’s not important at all to me.
I know where to find that info in other places.
The info used to be there prior to 7.7, some users are having problems determining why some settings they are using are not working.
I assumed nobody ever bothered creating a ticket for it. I did, got a response and shared that info.
Info from authorities sometimes doesn’t exactly match limitation built in ROS. Sometimes is thus very useful to get this info to verify what are actual limits imposed by ROS in actual device.
I have been using 7.8rc1 for 3 days now, and there has not been any issue with interrupted streaming since then. My main streaming service is Netflix, and IPv6 is enabled in the network. I believe the AAAA resolution issue with DNS has been resolved. Those who have encountered the issue before can upgrade to 7.8rc1 for testing.
I found a bug (present in 7.4.1 through to 7.7) where OSPF ECMP routes, when they return after a failure, are not loaded into the L3HW, despite showing up in the routing table. I’ve submitted a ticket but haven’t heard back yet.
