on ccr2216 appling Force-Mac-Address to a bonding interface block all the logic of the router, no winbox or mac-telnet, but it respond to ping on all other interfaces then bonding with force mac address.
7.9rc1 on CCR2216 has an higher icmp ping loss compared to 7.8 and previews.
7.9rc1 respond with ~3x1000 loss
same hardware, same configuration but with 7.8 respond with ~3x10000 loss
just an order of magnitude higher.
*) ssh - added support for Ed25519 key export and import in PKCS8 format;
Does
/user/ssh-keys/import
also support Ed25519 public keys?
If so, what format(s) are supported?
I’ve tried (what I think are) OpenSSH and PKCS#8 without passphrases and both return unable to load key file (wrong format or bad passphrase).
Well, this is a “release candidate” and MT had occasions where more than one RC happened before corresponding “full” release. Meaning that even MT considers this more a lab testing release than for production environment. Surely it’s up to anyone to install rc or even beta in their production networks if they decide so.
And RC should never be run in production. I would say stay away from 7.x.0 and wait for 7.x.1 or higher. But it seems that MT like to add new function compare to make it stable. I was hoping on 7.8.1 be fore 7.9beta/rc, or at lest backport fixes broken in 7.8 to make 7.8.1 and try to reach the first long time release for 7.x
Anyone noticed lockups on CCR2216 on 7.9beta4? Not sure yet if it’s hardware or software related but usually since watchdog is enabled you would get a reboot, no response on console either…
