v7.9rc is released!
Tx Power for 2.4 GHz interface on hAP ax2 is limited to 15 dBm. Tested with different Country configured.
Moreover, right after changing a country 20 dBm is displayed for a while and then it falls to 15 dBm.
Creation of PKCS8-format private SSH ed25519 keys using ssh-keygen seems to be impossible.
What is the recommended procedure for creating an ed25519 PKCS8-format SSH private key?
Non. Currently ed25519 keys for public key authentication are not supported.
Don’t push them too hard, they’ll have the last laugh and tell us it will be in version 8!
it is their market share and they are laughing at it.
ipv6 was introduced 27 years ago. most competitors have fast-track support now.
Copy & Paste???
http://forum.mikrotik.com/t/v7-9beta-testing-is-released/165419/119
Same reply:
Is correct, 15 + 4,5 ~20dB…
Latvia do not use IPv6, so…
https://www.google.com/intl/en/ipv6/statistics.html#tab=per-country-ipv6-adoption
And on Italy (8,74%) I’m contributing just with only 2 “/32”
[/quote]
Hmmm…:
*) ssh - added support for Ed25519 key export and import in PKCS8 format;
*) ssh - added Ed25519 host key support;
So they only added Ed25519 for “host keys”, not for authentication? That’s unfortunate…
Small problem with characters in log…
What characters? “%*8”? Is interface with .id = 8
on terminal, for know the name:
/int pri where .id=*8
The bug is not the character, but the missing convertion from .id to name.
For those with the RB5009 and a GPON SFP, Does Forcing 2.5Gbps rate work on v7.9rc1?
Ah OK thanks rextended
At the moment Ed25519 key import/export is available only under the “/ip/ssh/” menu. The format must be PKCS8. An additional fix for the “/ip/ssh/import-host-key” function will be available in rc2.
Please note that ssh-keygen ignores the PKCS8 format parameter for Ed25519 key, you should use OpenSSL to generate the key and store it in PKCS8 format.
“openssl genpkey -algorithm ed25519 -out private.pem”
Hi Strods, I am curious as to where folks are supposed to know these gems?
In other words, why not publish such known work-arounds or such ‘tricks’ on a web page, and then close the line when added to winbox etc.
Please also fix the missing password parameter on /user ssh-keys private import private-key-file=xxx user=xxx
Someone lost it along the way
Yes, you copy-pasted your assumption as a reply to the reported and still-existing bug.
You do not read the specs… or if you read it, you do not understand what you read, and this is not one assumption, is a fact.
See the official reply if you do not like know from other users how the things works…
http://forum.mikrotik.com/t/v7-9rc-is-released/165607/1
With 7.9rc1 I suddenly see VRRP announcement traffic on interfaces that have a group-master (which is not themselves).
This is causing rapid address flapping
Logs
15:50:13 vrrp,info vrrp-security-dns now MASTER, master down timer
15:50:13 vrrp,info vrrp-security-dns now BACKUP (set by VRRP Group)
15:50:17 vrrp,info vrrp-security-dns now MASTER, master down timer
15:50:17 vrrp,info vrrp-security-dns now BACKUP (set by VRRP Group)
Relevant config
[admin@router-backup] /interface/vrrp> print
Flags: X, I - INVALID; B, F - FAILURE
Columns: NAME, INTERFACE, MAC-ADDRESS, GROUP-MASTER, VRID, PRIORITY, INTERVAL, VERSION, V3-PROTOCOL, SYNC-CONNECTION-TRACKING
 #    NAME                     INTERFACE        MAC-ADDRESS        GROUP-MASTER       VRID  PRIORITY  INTERVAL  VERSION  V3-PROTOCOL  SYNC-CONNECTION-TRACKING
12  B vrrp-mgmt-dns            vlan-mgmt        00:00:5E:00:01:35  self                 53        25  1s              2  ipv4         no
15  B vrrp-security-dns        vlan-security    00:00:5E:00:01:35  vrrp-mgmt-dns        53        25  1s              2  ipv4         no
I have already deleted and manually recreated the entire VRRP config and the announcements are still (incorrectly) sent on the non-master interfaces.
My router on 7.8 correctly only announces on the group-master
Same issue on my routers since 7.9beta4. I created SUP-112104 on Mar29. still “Waiting for support” status.
EDITTED
On Apr05, I received a message that MikroTik had reproduced this issue.
I would like to know the status of the partitioning bug in 7.9 releases.
http://forum.mikrotik.com/t/v7-8-stable-is-released/164757/322
Is there a fix in handling /dev during partitioning as promissed in 7.8?
Is it tested?
regards
