v7 Linux Kernel version ?
Just curious, what Linux version will/is ROS v7 be running under the hood ?
(Noting v6 is running v3.3.5)
As far as I read from other post, 4.x
It is even possible that there will be v7 linux kernel for v7 routerOs
Yes, i think everything is possible abtuet The last 5 years…
Version kernel 4.14.131 RouterOS 7
AFAIK. Because Tile(ra) architecture (CCR) support is dropped after kernel v4.14.x
According to Normis they don’t use kernel’s support for Tile so this won’t affect them:
It’s version 5.6.3.
(You can check it in ros npk package (lib/modules/xxx)
[admin@MikroTik] > /system/package/print
Columns: NAME, VERSION, BUILD-TIME, SIZE
# NAME      VERSION  BUILD-TIME           SIZE
0 routeros  7.16.1   2024-10-10 14:03:32  11.7MiB
[admin@MikroTik] > /system/resource/usb/print
Columns: DEVICE, VENDOR, NAME, SPEED
# DEVICE  VENDOR                NAME                  SPEED
0 3-0     Linux 5.6.3 xhci-hcd  xHCI Host Controller   5000
1 1-0     Linux 5.6.3 ehci_hcd  EHCI Host Controller    480
2 2-0     Linux 5.6.3 xhci-hcd  xHCI Host Controller    480
3 1-1     Fibocom               FG621 Module            480
