Valheim Port Forwarding
Hi Guys
Iv’e been trying for the past few hours to setup port forwarding for a Valheim server I’m going to be hosting on my server and cannot seem to get it to work.
I have followed the basic YouTube tutorials and wasn’t getting anywhere.
This lead me to the forums and I have tried a few of the solutions provided by others for Minecraft etc. to no avail.
http://forum.mikrotik.com/t/port-forwarding-dynamic-ip/133346/2
http://forum.mikrotik.com/t/best-way-to-securely-host-a-minecraft-server-at-home/154395/2
I have ended up restoring a backup of my router and it’s back to default for the most part. There were too many changes made that I lost track and decided fresh was safer…
I have a dynamic external IP from my ISP that changes every couple of days. The IP matches the Public Address in the IP/Cloud tab.
My server is hosted on internal IP 192.168.1.11 and needs ports 2456-2458 to be opened.
Please see the below export of the router :
[admin@MikroTik] > /export hide-sensitive
# dec/24/2021 19:54:28 by RouterOS 7.1
# software id = XW7F-JHTS
# model = RB4011iGS+5HacQ2HnD
# serial number = B8E00A09F582
add admin-mac=74:4D:28:CC:6B:28 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="south africa" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge secondary-frequency=auto ssid="Hide Your WiFi" \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="south africa" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid="Everyday I'm Buffering" wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=**************@*********.co
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Africa/Johannesburg
/system leds
add interface=wlan2 leds=wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-led,wlan2_signal4-led,wlan2_signal5-led type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/tool mac-server
/tool mac-server mac-winbox
Just followed the following example as well, no joy …
[admin@MikroTik] > export hide-sensitive
# dec/24/2021 22:05:48 by RouterOS 7.1
/interface wireless
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=****************@*****************.co
/port
set 0 name=serial0
set 1 name=serial1
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.11 client-id=1:70:85:c2:80:96:b2 mac-address=70:85:C2:80:96:B2 server=defconf
/ip dns static
add action=accept chain=forward dst-address=192.168.1.11 dst-port=2456-2458 protocol=tcp
add action=dst-nat chain=dstnat dst-port=2456-2458 in-interface=ether1 protocol=tcp to-addresses=192.168.1.11 to-ports=2456-2458
/system clock
/system leds
/tool mac-server
[admin@MikroTik] >
Anyone?
You need to use something like these rules but remember to change the variables to suit your config.
If you have Firewall you have to accept the incoming port in the inbound interface, Also you have to bypass this connection from FastTrack.
add action=dst-nat chain=dstnat comment= disabled=yes dst-address=PublicIP dst-port=incoming port protocol=tcp to-addresses=PrivateIP-local to-ports=internal-port
add action=dst-nat chain=dstnat comment= disabled=yes dst-address=2.2.2.2 dst-port=0000 protocol=tcp to-addresses=192.168.88.5 to-ports=0000
Please read through this article, and then come back with any questions.
https://forum.mikrotik.com/viewtopic.php?t=179343
I have run a valheim server in the past. I only see traffic ever hit my udp rule, but I do have both. So you should follow Owners instructions on the creation of the rules, except make two, one for protocol=tcp and one for protocol=udp. You must put your public IP address in the “dst-address” field (In place of the 2.2.2.2). You can figure out what your Public ip is by googling “What is my ip?” You must also ensure that 192.168.1.11 is statically assigned to your intended server machine.
add action=dst-nat chain=dstnat comment= disabled=yes dst-address=2.2.2.2 dst-port=2456-2458 in-interface=ether1 protocol=tcp to-addresses=192.168.1.11 to-ports=2456-2458
add action=dst-nat chain=dstnat comment= disabled=yes dst-address=2.2.2.2 dst-port=2456-2458 in-interface=ether1 protocol=UDP to-addresses=192.168.1.11 to-ports=2456-2458
it looks like your Firewall is set up to accept Dstnat traffic from WAN so you should be good to go. Except:
is not required.
