Variable nightmare
Routeos V 5.25
What i want???.. a counter of hotspot logins (simple scritpt), really simple (extracted from another post)
Into on-login section of user profile script of hotspot:
/system script run contarusuario;
Into script section, the script named “contarusuario”
:global usuarios;
:set usuarios ($usuarios + 1);
:log info "number of HS logins: $usuarios"
What is the problem???..
1º. If i execute the script manually (into script sections)… the result is as wanted, the variable “usuarios” increase… and can see their values into “environment” sections of scripts.
2º. If i execute manually (into terminal window)… same result, all is ok
3º. But if is executed with hotspot login…
a. Value is always “1”, no matter how many logins, and logoff we did, even with two users online, value show to terminal is “1”
b. The variable is not shown into “environment section”.
c. Even more… if i execute several times manually the script, i can see the variable increasing… 5,6,7… if i do a login into hotspot… “1”… but “global” variable remain as previous 7,8,9
Conclusions…
1º. The scripts is executed on login… (as result is showed into terminal).
2º. But the variable created is not global, but local… and afther the job is done, their result is deleted, so results are useless.
How can i solve this trouble???
For security reasons global variables are global only for particular user (for example “admin” user). Hotspot on-login script owner is not “admin” but internal system user “sys*”, so it cannot write value to “admins” variables.
So, ¿is there any solution to my small trouble?.. is there any way to bypass this limitation???
One workaround is write value to the file and then read content from the file
Since a link to this topic appeared in a recent post, without further ado:
Simply read how many time contarusuario is launched, and you have already the count without useless operations...
:put [/system script get contarusuario run-count]
So, inside the script just put:
:log info "number of HS logins: $([/system script get contarusuario run-count] + 1)"
(+1 because it start from 0)
