Just configured my first Microtik 1100AHX2 routerboard. My question: Is there a way to verify the configuration before I put the router into production? Basically I set ether1 as my wan port 8.8.8.8/28 (not the real ip) and ether2 as my lan port 192.168.1.1/24. I can pint from 8.8.8.8 to 192.168.1.1 using winbox terminal. I setup a dhcp on 192.168.1.1 and switched 3,4,5 to use ether2 as master port.
Thanks for your help, ![]()
