Verify integrity and authenticity of installation files Router OS
Good morning I recently purchased a hAP AC3 and needing to reinstall RouterOS I downloaded from Mikrotik.com site the installation files I wanted to know if it is possible to perform a check to verify the integrity and authenticity of the downloaded files in order to avoid that the files,have been tampered with,but I can not find on the site the checksum and the file. sign for checksum signature verification,Mikrotik releases the checksum and the file.sign for checksum signature verification? Thank you very much for the clarification good day
Tom
See here:
https://mikrotik.com/download/archive
Checksum is there.
Thank you very much I would also like to verify that the Router OS installation files are authentic just the ones made available by the developer, how can I verify that the RouterOS installation files have not been tampered with? Is there a file.sign for checksum signature verification? thank you very much good afternoon
Tom
Don’t push your luck :laughing:
If you don’t trust the download servers from Mikrotik, use upgrade process on the device itself.
But in the end they will go to the same file server …
I usually encounter issues iwth upgrading directly from the devic (upgrade) if its behind other switches etc…
Thanks Bye
Thanks bye
