Version upgrade?
I have found that on certain versions, I try to upgrade via the web interface and when I hit upgrade it reboots, but no changes have been made. Still running the same version. I’ve noticed that when I slowly increment up the versions it works fine.
2 questions please:
  1. Is there a way where I wouldn’t have to do this?
  2. If there isn’t then where can I find an archive of older versions so that I may upgrade little at a time?
Thanks very much for your help.
Luke
Hello friend.....
first download the package from http://www.mikrotik.com/download.html
than FTP to your router, after upload the package, excute command:
/sy pac downgrade
than pres 'y' to make reboot for your router. this easy to make upgrading.
Hasbullah.com
Thanks for your help, much appreciated- worked great.
