I’m new to vlans so am trying to set up the simplest possible thing
I have two routerboards (hEX and 951) and am trying to set up something basic between them
I have created a vlan(10) on eth1 on one box and given it the address of 10.1.1.1
I have created a similar vlan on the other mikrotik and given it the address of 10.1.1.2
they are directly connected so nothing in between (although there is a dumb switch hanging of one of the other ports which is on bridge)
there are no other vlans configured.
both routers otherwise working perfectly
Should I be able to ping from 10.1.1.1 to 10.1.1.2 using winbox? So far its not working so I am assuming i’ve just missed something.
It looks like one side is broadcasting an arp request but not hearing a reply?
I am using winbox and choosing the vlan interface to ping
