Virtual L2 connection between 2 routers
Hello.
Is there a way how to bridge port on one mikrotik to another mikrotik using existing vpn?
I want to join Device 1 and Device 2 to one isolated L2 network. Is it possible?
Of course.Just bridge ether ports via unique vlan or directly.
i think he want to make l2 over vpn. try with eoip
Sent from my Moto G (5) Plus using Tapatalk
L2TP L2 Briging is no Problem
With EOIP I will find MTU Issue…
https://wiki.mikrotik.com/wiki/Manual:BCP_bridging_(PPP_tunnel_bridging)
He said over existing vpn.
So I just need to bridge eth1 interface and l2tp interface?
L2TP is layer 3 vpn, so no. You should shift l2tp to eoip and bridge ethernet interfaces with it.
If i dont mistake, EOIP doesn’t work over NAT and it is insecure.
So, i shall to encapsulate EOIP over L2TP?
No, you need to ruine l2tp, create eoip over ipsec and set ip address space in eoip interfaces.
…sorry. that is what i said? l2tp vpn…and then eoip tunnel
No. I said that he must delete l2tp vpn and create new one with eoip. Lets just add as much headers as possible: ip over l2tp over eoip over pptp over ipsec(sarcasm).
..so you say that must be eoip from wan to wan and then secure with ipsec?
Raceboy you are wrong!
From Wiki:
With L2TP, a user has a Layer 2 connection to an access concentrator - LAC (e.g., modem bank, ADSL DSLAM, etc.), and the concentrator then tunnels individual PPP frames to the Network Access Server - NAS. This allows the actual processing of PPP packets to be separated from the termination of the Layer 2 circuit
We use that every day in our WISP Network, it is a Layer2 VPN if it is used in the right way!
And with MRRU you don’t have to worry about the MTU
Setup 2 Profiles one on every side with bridge in it, don’t forget to setup Admin Mac, in the Bridge, and you’ve got an L2 VPN
ok. thanks. i dont say im wright:) but only with eoip i can make multicast iptv pass through
