Hello friends.
Faced with this problem, similar encountered a year ago.
From a computer running WIN7 (IP 192.168.210.21) from the local network the router is attacked. The computer is probably infected with a virus. Has anyone encountered such a problem? The AVG antivirus is up to date. Please advise how to cure where to look.
22:54:31 system,error,critical login failure for user from 192.168.210.21 via telnet
22:54:32 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:54:33 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:54:34 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:54:36 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:54:37 system,error,critical login failure for user from 192.168.210.21 via telnet
22:54:38 system,error,critical login failure for user from 192.168.210.21 via telnet
22:54:39 system,error,critical login failure for user MikroTikSystem from 192.168.210.21 via telnet
22:54:40 system,error,critical login failure for user SolucTec from 192.168.210.21 via telnet
22:54:41 system,error,critical login failure for user SolucTec from 192.168.210.21 via telnet
22:54:42 system,error,critical login failure for user dircreate from 192.168.210.21 via telnet
22:54:43 system,error,critical login failure for user EServicios from 192.168.210.21 via telnet
22:54:45 system,error,critical login failure for user EServicios from 192.168.210.21 via telnet
22:54:46 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:54:47 system,error,critical login failure for user user from 192.168.210.21 via telnet
22:54:48 system,error,critical login failure for user user from 192.168.210.21 via telnet
22:54:49 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:54:50 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:54:52 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:54:53 system,error,critical login failure for user sysadm from 192.168.210.21 via telnet
22:54:54 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:54:55 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:54:56 system,error,critical login failure for user from 192.168.210.21 via telnet
22:54:57 system,error,critical login failure for user Admin from 192.168.210.21 via telnet
22:54:58 system,error,critical login failure for user Admin from 192.168.210.21 via telnet
22:54:59 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:55:00 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:55:02 system,error,critical login failure for user root from 192.168.210.21 via telnet
22:55:03 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:55:04 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:55:05 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:55:07 system,error,critical login failure for user admin from 192.168.210.21 via telnet
22:55:08 system,error,critical login failure for user meo from 192.168.210.21 via telnet
22:55:09 system,error,critical login failure for user Admin from 192.168.210.21 via telnet
22:55:10 system,error,critical login failure for user Admin from 192.168.210.21 via telnet
22:55:11 system,error,critical login failure for user guest from 192.168.210.21 via telnet
22:55:12 system,error,critical login failure for user ubnt from 192.168.210.21 via telnet
22:55:13 system,error,critical login failure for user ubnt from 192.168.210.21 via telnet
22:55:14 system,error,critical login failure for user Administrator from 192.168.210.21 via telnet
22:55:18 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:19 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:20 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:21 system,error,critical login failure for user MikroTikSystem from 192.168.210.21 via ftp
22:55:22 system,error,critical login failure for user SolucTec from 192.168.210.21 via ftp
22:55:23 system,error,critical login failure for user dircreate from 192.168.210.21 via ftp
22:55:24 system,error,critical login failure for user EServicios from 192.168.210.21 via ftp
22:55:26 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:27 system,error,critical login failure for user user from 192.168.210.21 via ftp
22:55:28 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:29 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:30 system,error,critical login failure for user sysadm from 192.168.210.21 via ftp
22:55:31 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:32 system,error,critical login failure for user Admin from 192.168.210.21 via ftp
22:55:33 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:34 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:35 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:36 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:37 system,error,critical login failure for user meo from 192.168.210.21 via ftp
22:55:38 system,error,critical login failure for user Admin from 192.168.210.21 via ftp
22:55:39 system,error,critical login failure for user guest from 192.168.210.21 via ftp
22:55:40 system,error,critical login failure for user ubnt from 192.168.210.21 via ftp
22:55:41 system,error,critical login failure for user Administrator from 192.168.210.21 via ftp
22:55:42 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:43 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:44 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:45 system,error,critical login failure for user vodafone from 192.168.210.21 via ftp
22:55:46 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:47 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:48 system,error,critical login failure for user Administrator from 192.168.210.21 via ftp
22:55:49 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:50 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:51 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:52 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:53 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:54 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:55 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:56 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:55:57 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:58 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:55:59 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:00 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:01 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:02 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:03 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:04 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:05 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:06 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:07 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:08 system,error,critical login failure for user Admin from 192.168.210.21 via ftp
22:56:09 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:10 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:11 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:12 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:13 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:14 system,error,critical login failure for user admin from 192.168.210.21 via ftp
22:56:15 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:16 system,error,critical login failure for user root from 192.168.210.21 via ftp
22:56:17 system,error,critical login failure for user user from 192.168.210.21 via ftp
22:56:18 system,error,critical login failure for user root from 192.168.210.21 via ftp
