Visio Stencils
Are they any updated Visio stencils floating about?
Something that includes the newer kit like the CRS317/CRS326 and 4011’s..
James
Sounds like something MT should post as a link to their Support Tab at the website!!!
Thanks. I take it that there aren’t any available then?
James
Updated Visio stencils would be great (+1).
Anyway you can try to create it with Illustrator or similar, and then, convert it to Visio.
Regards.
Any news?
Thanks for answer…
