Visual C++ Runtime Error!
Hi All,
Anyone seen this error before or has any idea how to resolve the problem… (please see attached file)
Every couple of days The Dude server will hang with this error…
Thanks in advance.
I’m seeing the same thing only on 1 of our machines which has been running Dude server for approx 4 years now on Windows XP.
I have 6 other Servers running Dude without this issue on XP and Windows 7…
Mine is crashing about 4 times a day.
Would really luv to know what is casing the issue…
this could indicate a conflict with some other software in your computer, try to boot in safe mode, or disable some startup items in “run → msconfig”
basically this is a windows problem
Thanks Normis,
By the way I enjoyed the meeting in Brisbane, hope you enjoyed your stay in Australia :slight_smile:
thanks! it was awesome. see you next time :wink:
What I have encountered the same error, no one to solve!
[quote=“chenczl”]What I have encountered the same error, no one to solve!
chencz try another or new machine, I only encounter it on one PC and haven’t seen the issue again.
I’m currently have around 10 Servers running on both XP and Windows 7 VM’s without any issues.
I have the same error.
How to fix?
I have the same error on both of my machines after upgrading from XP to Win7. Neither machine had this problem before and both are running essentially the same software as before. One of these machines only has two applications running, Dude and Spotlight. We had a system go down over the weekend and this error froze up The Dude, so I was not notified until I arrived at work this morning.
The machine that has two apps is not running C++, the other machine is.
