I’m a newbie on Mikrotik devices and trying to learn, started with mikrotik router board / 4 Port.
I’m working on VLANs on my device, created vlan10, assigned ip and dhcp, when i tag my virtual machine as 10 it gets ip from VLAN10 dhcp but there is no internet access or can not ping the router or reach to web interface. During my searches i’ve found bridges but it makes me confuse because some says “bridging is not right way for vlans” but some says “you can’t vlan without bridges”, i couldn’t be able to fix it so wanted to ask here, most probably i’m doing a very obivous rookie mistake but what could cause the internet problem on my config.
MikroTik RouterOS 6.49.8 (c) 1999-2023 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@MikroTik] > /export hide-sensitive
# jan/01/2002 01:37:54 by RouterOS 6.49.8
# software id = WREN-K22N
# model = RB750Gr3
# serial number = HCM07MR932A
/interface vlan
add interface=ether2 name=vlan10 vlan-id=10
add name=WAN
add name=LAN
add name=dhcp_pool0 ranges=192.168.10.1-192.168.10.253
add address-pool=dhcp_pool0 disabled=no interface=vlan10 name=dhcp1
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US up-port=1700
add address=eu1.cloud.thethings.industries down-port=1700 name="TTS Cloud (eu1)" up-port=1700
add address=nam1.cloud.thethings.industries down-port=1700 name="TTS Cloud (nam1)" up-port=1700
add address=au1.cloud.thethings.industries down-port=1700 name="TTS Cloud (au1)" up-port=1700
add address=eu1.cloud.thethings.network down-port=1700 name="TTN V3 (eu1)" up-port=1700
add address=nam1.cloud.thethings.network down-port=1700 name="TTN V3 (nam1)" up-port=1700
add address=au1.cloud.thethings.network down-port=1700 name="TTN V3 (au1)" up-port=1700
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
add interface=ether1 list=WAN
add list=LAN
add address=192.168.88.254/24 interface=ether2 network=192.168.88.0
add address=192.168.10.254/24 interface=vlan10 network=192.168.10.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.10.0/24 dns-server=192.168.1.1,208.67.220.220,208.67.222.222 gateway=192.168.10.254
/system gps
set set-system-time=yes
/system routerboard settings
set auto-upgrade=yes
/tool user-manager database
set db-path=flash/user-manager
