VLAN and VLAN Interface with DHCP CRS328
Hello eveyrbody,
I’m desperate. I don´t get t to work.
I´m using for a test an CRS328. 3 VLAN. This is working. Now I´m trying to geht the Routing between the VLANs to work. I´m not able to Create an VLAN IF in the VLAN on the CRS328. Its not reachable (Of course DHCP is also not working). On the client I configuratet a static IP and tried to ping the VLAN IP Interface. Its not possible.
Whats wrong in the config. Using PCunite Tutorial (he is using one Switch with Trunk Ports an one Router).
/system identity set name="Switch"
# VLAN Overview
# 10 = BLUE
# 20 = GREEN
# 30 = RED
# 99 = BASE (MGMT) VLAN
# Bridge
# create one bridge, set VLAN mode off while we configure
/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
# -- Access Ports --
# ingress behavior
# Blue VLAN
add bridge=BR1 interface=ether1 pvid=10
add bridge=BR1 interface=ether2 pvid=10
add bridge=BR1 interface=ether3 pvid=10
add bridge=BR1 interface=ether4 pvid=10
add bridge=BR1 interface=ether5 pvid=10
add bridge=BR1 interface=ether6 pvid=10
add bridge=BR1 interface=ether7 pvid=10
add bridge=BR1 interface=ether8 pvid=10
# Green VLAN
add bridge=BR1 interface=ether9  pvid=20
add bridge=BR1 interface=ether10 pvid=20
add bridge=BR1 interface=ether11 pvid=20
add bridge=BR1 interface=ether12 pvid=20
add bridge=BR1 interface=ether13 pvid=20
add bridge=BR1 interface=ether14 pvid=20
add bridge=BR1 interface=ether15 pvid=20
add bridge=BR1 interface=ether16 pvid=20
# Red VLAN
add bridge=BR1 interface=ether17 pvid=30
add bridge=BR1 interface=ether18 pvid=30
add bridge=BR1 interface=ether19 pvid=30
add bridge=BR1 interface=ether20 pvid=30
add bridge=BR1 interface=ether21 pvid=30
add bridge=BR1 interface=ether22 pvid=30
add bridge=BR1 interface=ether23 pvid=30
#add bridge=BR1 interface=ether24 pvid=30
# egress behavior
/interface bridge vlan
# Blue, Green, Red VLAN
add bridge=BR1 untagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,BLUE_VLAN vlan-ids=10
add bridge=BR1 untagged=ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16 vlan-ids=20
add bridge=BR1 untagged=ether17,ether18,ether19,ether20,ether21,ether22,ether23 vlan-ids=30
# -- Trunk Ports --
# ingress behavior
# Purple Trunk. Leave pvid set to default of 1
add bridge=BR1 interface=sfp1
add bridge=BR1 interface=sfp2
# egress behavior
# Purple Trunk. L2 switching only, Bridge not needed as tagged member (except BASE_VLAN)
set bridge=BR1 tagged=sfp1,sfp2 [find vlan-ids=10]
set bridge=BR1 tagged=sfp1,sfp2 [find vlan-ids=20]
set bridge=BR1 tagged=sfp1,sfp2 [find vlan-ids=30]
add bridge=BR1 tagged=sfp1,sfp2 vlan-ids=99
# IP Addressing & Routing
# LAN facing Switch's IP address on a BASE_VLAN
/interface vlan add interface=BR1 name=BASE_VLAN vlan-id=99
/ip address add address=192.168.0.2/24 interface=BASE_VLAN
# The Router's IP this switch will use
/ip route add distance=1 gateway=192.168.0.1
# IP Services
# We have a router that will handle this. Nothing to set here.
# VLAN Security
# Only allow ingress packets without tags on Access Ports
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether1]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether2]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether3]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether4]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether5]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether6]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether7]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether8]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether9]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether10]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether11]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether12]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether13]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether14]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether15]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether16]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether17]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether18]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether19]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether20]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether21]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether22]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether23]
#set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether24]
# Only allow ingress packets WITH tags on Trunk Ports
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=sfp1]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=sfp2]
# MAC Server settings
# Ensure only visibility and availability from BASE_VLAN, the MGMT network
/interface list add name=BASE
/interface list member add interface=BASE_VLAN list=BASE
/ip neighbor discovery-settings set discover-interface-list=BASE
/tool mac-server mac-winbox set allowed-interface-list=BASE
/tool mac-server set allowed-interface-list=BASE
# Blue VLAN interface creation, IP assignment, and DHCP service
interface vlan add interface=BR1 name=BLUE_VLAN vlan-id=10
ip address add interface=BLUE_VLAN address=192.168.205.1/24
ip pool add name=BLUE_POOL ranges=192.168.205.10-192.168.205.254
ip dhcp-server add address-pool=BLUE_POOL interface=BLUE_VLAN name=BLUE_DHCP disabled=no
ip dhcp-server network add address=192.168.205.0/24 dns-server=192.168.205.1 gateway=192.168.205.1
# Green VLAN interface creation, IP assignment, and DHCP service
interface vlan add interface=BR1 name=GREEN_VLAN vlan-id=20
ip address add interface=GREEN_VLAN address=192.168.206.1/24
ip pool add name=GREEN_POOL ranges=192.168.206.10-192.168.206.254
ip dhcp-server add address-pool=GREEN_POOL interface=GREEN_VLAN name=GREEN_DHCP disabled=no
ip dhcp-server network add address=192.168.206.0/24 dns-server=192.168.205.1 gateway=192.168.206.1
# Red VLAN interface creation, IP assignment, and DHCP service
interface vlan add interface=BR1 name=RED_VLAN vlan-id=30
ip address add interface=RED_VLAN address=192.168.207.1/24
ip pool add name=RED_POOL ranges=192.168.207.10-192.168.207.254
ip dhcp-server add address-pool=RED_POOL interface=RED_VLAN name=RED_DHCP disabled=no
ip dhcp-server network add address=192.168.205.0/24 dns-server=192.168.205.1 gateway=192.168.207.1
# Optional: Create a DHCP instance for BASE_VLAN. Convenience feature for an admin.
/ip pool add name=BASE_POOL ranges=192.168.0.10-192.168.0.254
/ip dhcp-server add address-pool=BASE_POOL interface=BASE_VLAN name=BASE_DHCP disabled=no
/ip dhcp-server network add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
# Turn on VLAN mode
/interface bridge set BR1 vlan-filtering=yes
You do not add VLAN interfaces in /interface bridge vlan, so
/interface vlan
is correct for creating a VLAN interface, but this
to connect the VLAN interface to the bridge VLANs is incorrect.
Given your script, leave
add bridge=BR1 untagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=10
unchanged, and modify the trunk section to include the bridge itself
# Purple Trunk and CPU access
set bridge=BR1 tagged=BR1,sfp1,sfp2 [find vlan-ids=10]
The CPU in CRS devices are not very powerful, so you can route a small amount of traffic but do not expect to get anything like wire-speed routing.
Thank you very much for your help and your Time TDW. I will try it. Hope it works.
