VLAN and WIREGUARD basic
Hi all,
It’s my first time here and I would apologize in advance for my bad English.
I need help to setup my first net with a Mikrotik router.
Now I try to explain my situation.
I’ve a FTTH connection provided by the ISP that comes in the building with a fiber to Ethernet converter.
Starting from this, I need to create 5 independent VLANs with 5 independent DHCP servers and 5 different IP pools.
I need that the every single VLAN is completely independent and invisible from the others, like as is working on 5 different router.
I’ve write something like this:
add name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=impianti vlan-id=50
add interface=bridge name=rovera vlan-id=100
add interface=bridge name=frongia vlan-id=150
add interface=bridge name=geometra vlan-id=200
add interface=bridge name=eberhofer vlan-id=250
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=50pool ranges=192.168.50.10-192.168.50.254
add name=100pool ranges=192.168.100.10-192.168.100.254
add name=150pool ranges=192.168.150.10-192.168.150.254
add name=200pool ranges=192.168.200.10-192.168.200.254
add name=250pool ranges=192.168.250.10-192.168.250.254
add address-pool=50pool disabled=no interface=impianti name=50dhcp
add address-pool=100pool disabled=no interface=rovera name=100dhcp
add address-pool=150pool disabled=no interface=frongia name=150dhcp
add address-pool=200pool disabled=no interface=geometra name=200dhcp
add address-pool=250pool disabled=no interface=eberhofer name=250dhcp
add bridge=bridge comment=defconf interface=ether6 pvid=50
add bridge=bridge comment=defconf interface=ether2 pvid=100
add bridge=bridge comment=defconf interface=ether3 pvid=150
add bridge=bridge comment=defconf interface=ether4 pvid=200
add bridge=bridge comment=defconf interface=ether5 pvid=250
/interface bridge vlan
add bridge=bridge tagged=bridge vlan-ids=50
add bridge=bridge tagged=bridge vlan-ids=100
add bridge=bridge tagged=bridge vlan-ids=150
add bridge=bridge tagged=bridge vlan-ids=200
add bridge=bridge tagged=bridge vlan-ids=250
add interface=rovera list=LAN
add interface=frongia list=LAN
add interface=geometra list=LAN
add interface=eberhofer list=LAN
add interface=impianti list=LAN
add address=192.168.50.1/24 interface=impianti network=192.168.50.0
add address=192.168.100.1/24 interface=rovera network=192.168.100.0
add address=192.168.150.1/24 interface=frongia network=192.168.150.0
add address=192.168.200.1/24 interface=geometra network=192.168.200.0
add address=192.168.250.1/24 interface=eberhofer network=192.168.250.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.50.0/24 dns-server=8.8.8.8 gateway=192.168.50.1
add address=192.168.100.0/24 dns-server=8.8.8.8 gateway=192.168.100.1
add address=192.168.150.0/24 dns-server=8.8.8.8 gateway=192.168.150.1
add address=192.168.200.0/24 dns-server=8.8.8.8 gateway=192.168.200.1
add address=192.168.250.0/24 dns-server=8.8.8.8 gateway=192.168.250.1
set servers=8.8.8.8
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system clock
set time-zone-name=Europe/Rome
I’ve done this searching on the forum regarding the VLANs management and I hope that’s works.
But I’ve need also to create 4 VPN for the VLANs 1, 2, 3 and 4 to access remotely.
I’ve read about WIREGUARD or OVPN but here I’ve no experience about routing 4 wireguard connection trough firewall rules.
Attached there’s a simple graphic of my configuration:
I’ve choose a RB4011iGS+RM for my net and I think that’s a very good product.
Thanks in advance for everyone that will help me!
Regards,
Davide
Hi Davide, excellent start.
A good article to read on setting up single bridge vlan filtering is ( the rb4011 is old and if you are spending money the RB5009 is much better investment ).
I recommend taking one port not used off the bridge, giving it its own IP address and the doing the config from that safe spot.
Just plug in laptop to that port and put in IPV4 settings to match 192.168.77.2 and you should have access.
/ethernet
name=OffBridge8
add interface=OffBridge8 list=LAN
add address=192.168.77.1/30 interface=OffBridge8 network=192.168.77.0
Hi Anav!
Thank you for your feedback!
I’ve added the last eth port for management as suggested by you, really thanks I hadn’t thought about it before.
I’ve already seen that topic and it was really useful and I’ve started from here to write my configuration file.
But it didn’t mention the WIREGUARD or OVPN external connection and also about firewall is not so deeply explained.
I’ve found this line in the “FirewallCustom.rsc” that could be useful:
# Allow all VLANs to access the Internet only, NOT each other
add chain=forward action=accept connection-state=new in-interface-list=VLAN out-interface-list=WAN comment="VLAN Internet Access only"
In this way I can isolate every single VLANs I think, correct?
But talking about WIREGUARD o OVPN how I need to operate?
I need to create 4 new IP pools and route these into the VLAN trough firewall?
But I really don’t know how do that…
Thank you!
Hi!
I’ve tried to update the rsc file with a partial WIREGUARD setup for the 4 VLANs.
The code is this:
# mar/09/2023 00:24:18 by RouterOS 6.49.7
# software id = Uxxxxx
#x
# model = xxxxx
# serial number = xxxxx
/ethernet
name=OffBridge8
/interface wireguard
add listen-port=13231 name=wireguard_rovera
add listen-port=13232 name=wireguard_frongia
add listen-port=13233 name=wireguard_studio
add listen-port=13234 name=wireguard_eberhofer
/interface vlan
add address=192.168.99.1/30 interface=OffBridge8 network=192.168.99.0
add address=192.168.101.1/24 interface=wireguard_rovera
add address=192.168.151.1/24 interface=wireguard_frongia
add address=192.168.201.1/24 interface=wireguard_studio
add address=192.168.251.1/24 interface=wireguard_eberhofer
/interface wireguard peers
add allowed-address=192.168.101.1/24, endpoint-address=192.168.100.252 endpoint-port=13231 interface=wireguard_rovera public-key="paste key here"
add allowed-address=192.168.101.2/24, endpoint-address=192.168.100.253 endpoint-port=13231 interface=wireguard_rovera public-key="paste key here"
add allowed-address=192.168.101.3/24, endpoint-address=192.168.100.254 endpoint-port=13231 interface=wireguard_rovera public-key="paste key here"
add allowed-address=192.168.151.1/24, endpoint-address=192.168.150.252 endpoint-port=13232 interface=wireguard_frongia public-key="paste key here"
add allowed-address=192.168.151.2/24, endpoint-address=192.168.150.253 endpoint-port=13232 interface=wireguard_frongia public-key="paste key here"
add allowed-address=192.168.151.3/24, endpoint-address=192.168.150.254 endpoint-port=13232 interface=wireguard_frongia public-key="paste key here"
add allowed-address=192.168.201.1/24, endpoint-address=192.168.200.252 endpoint-port=13233 interface=wireguard_studio public-key="paste key here"
add allowed-address=192.168.201.2/24, endpoint-address=192.168.200.253 endpoint-port=13233 interface=wireguard_studio public-key="paste key here"
add allowed-address=192.168.201.3/24, endpoint-address=192.168.200.254 endpoint-port=13233 interface=wireguard_studio public-key="paste key here"
add allowed-address=192.168.251.1/24, endpoint-address=192.168.250.252 endpoint-port=13234 interface=wireguard_eberhofer public-key="paste key here"
add allowed-address=192.168.251.2/24, endpoint-address=192.168.250.253 endpoint-port=13234 interface=wireguard_eberhofer public-key="paste key here"
add allowed-address=192.168.251.3/24, endpoint-address=192.168.250.254 endpoint-port=13234 interface=wireguard_eberhofer public-key="paste key here"
/ip dhcp-client
set servers=8.8.8.8
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=accept chain=input comment="WG handshake" dst-port=13231 protocol=udp
add action=accept chain=input comment="WG handshake" dst-port=13232 protocol=udp
add action=accept chain=input comment="WG handshake" dst-port=13233 protocol=udp
add action=accept chain=input comment="WG handshake" dst-port=13234 protocol=udp
add action=accept chain=forward dst-address=192.168.100.252/24 src-address=192.168.101.1/24
add action=accept chain=forward dst-address=192.168.100.253/24 src-address=192.168.101.2/24
add action=accept chain=forward dst-address=192.168.100.254/24 src-address=192.168.101.3/24
add action=accept chain=forward dst-address=192.168.150.252/24 src-address=192.168.151.1/24
add action=accept chain=forward dst-address=192.168.150.253/24 src-address=192.168.151.2/24
add action=accept chain=forward dst-address=192.168.150.254/24 src-address=192.168.151.3/24
add action=accept chain=forward dst-address=192.168.200.252/24 src-address=192.168.201.1/24
add action=accept chain=forward dst-address=192.168.200.253/24 src-address=192.168.201.2/24
add action=accept chain=forward dst-address=192.168.200.254/24 src-address=192.168.201.3/24
add action=accept chain=forward dst-address=192.168.250.252/24 src-address=192.168.251.1/24
add action=accept chain=forward dst-address=192.168.250.253/24 src-address=192.168.251.2/24
add action=accept chain=forward dst-address=192.168.250.254/24 src-address=192.168.251.3/24
add action=drop chain=input comment="drop all else"
/system clock
Hope that someone can help me please :slight_smile:
Thanks!
If we can be clear on requirements, assistance can be rendered.
a. identify all users/devices, external and internal, and admin
b. identify the traffic the groups above required.
(explain purpose of vlans etc.)
I’m sorry, I belived that the first post was clear enough.
Talking about user/devices per user there will be 5 user:
    • User 1 (named “Rovera”) for VLAN1 that need to navigate on internet with xx device connected in his LAN and 2-3 external devices connected trough WIREGUARD in his VLAN1. The VLAN is not visible and reachable from others VLANs
  • User 2 (named “Frongia”) for VLAN2 that need to navigate on internet with xx device connected in his LAN and 2-3 external devices connected trough WIREGUARD in his VLAN2. The VLAN is not visible and reachable from others VLANs
  • User 3 (named “Studio”) for VLAN3 that need to navigate on internet with xx device connected in his LAN and 2-3 external devices connected trough WIREGUARD in his VLAN3. The VLAN is not visible and reachable from others VLANs
  • User 4 (named “Eberhofer”) for VLAN4 that need to navigate on internet with xx device connected in his LAN and 2-3 external devices connected trough WIREGUARD in his VLAN4. The VLAN is not visible and reachable from others VLANs
  • User 5 (named “Impianti”) for VLAN5 that need to navigate on internet with xx device connected in his LAN. The VLAN is not visible and reachable from others VLANs
  • User 6 the “Management user” single user with fixed IP on eth8 that have full access on Mikrotik
I’m really a beginner, I know.
But I think that the base of this project is good.
The purpose of these VLANs is to create 5 independent network for 4 user and 1 technician with a single WAN connection.
All user need to reach their NAS or other device on their VLAN when they’re out of home.
I’ve think to create 4 WIREGUARD connection that listen connection on 4 different port and assign the connection to a specific IP; then trough routing and firewall assign the WIREGUARD connection to the specific VLAN.
But I don’t know if I’ve missing something or I’ve done something drastically wrong.
Thank you for your patience.
1.Upgrade firmware to 7.12 and then to 7.17 ( also routerboard )
2. Then using ether2 to config… RB4011 has two switch chips, thus to keep all ports used on the same bridge moving them to 6-10
So first step is to move ether8 to ether2 !!
3. Added management vlan
4. Single Wireguard interface but will use different IP addresses to help ensure clarity on traffic flows.
5. Port 10 which goes to the managed switch for Equipment/Building Services is a trunk port carrying the management vlan and the Services VLAN.
6. IP DHCP client MUST be disabled if your IP is done through the pppoe interface!!!
/ethernet
name=OffBridge2
add listen-port=15511 name=wireguard1
/interface vlan
add interface=bridge name=gestione20  vlan-id=20
add name=TRUSTED
add interface=gestione20 list=LAN
add interface=OffBridge2 list=LAN
add interface=wireguard1 list=LAN
add interface=gestione20 list=TRUSTED
add interface=OffBridge8 list=TRUSTED
add interface=wireguard1 list=TRUSTED
add name=20pool ranges=192.168.20.100-192.168.20.120
add address-pool=20pool disabled=no interface=gestione name=20dhcp
add bridge=bridge ingress-filtering=yes frame-type=admit-only-priority-and-untagged  interface=ether2 pvid=20 comment="admin pc for management"
add bridge=bridge ingress-filtering=yes frame-type=admit-only-priority-and-untagged  interface=ether6 pvid=100
add bridge=bridge ingress-filtering=yes frame-type=admit-only-priority-and-untagged  interface=ether7 pvid=150
add bridge=bridge ingress-filtering=yes frame-type=admit-only-priority-and-untagged  interface=ether8 pvid=200
add bridge=bridge ingress-filtering=yes frame-type=admit-only-priority-and-untagged  interface=ether9 pvid=250
add bridge=bridge ingress-filtering=yes frame-type=admit-only-vlan-tagged  interface=ether10  comment="trunk to  switch impianti"
set discover-interface-list=TRUSTED
add bridge=bridge tagged=bridge,ether10  vlan-ids=20,50  comment="vlan20 to give managed switch an IP address"
add bridge=bridge tagged=bridge untagged=ether6 vlan-ids=100
add bridge=bridge tagged=bridge untagged=ether7 vlan-ids=150
add bridge=bridge tagged=bridge untagged=ether8 vlan-ids=200
add bridge=bridge tagged=bridge untagged=ether9 vlan-ids=250
add interface=OffBridge2 list=TRUSTED
add address=192.168.20.1/24 interface=gestione20  network=192.168.20.0
add address=192.168.99.1/30 interface=OffBridge2 network=192.168.99.0
add address=192.168.25.1/24  interface=wireguard1  network=192.168.25.0 comment="genione wg subnet"
add address=192.168.51.1/24  interface=wireguard1  network=192.168.51.0 comment="impianti wg subnet"
add address=192.168.101.1/24 interface=wireguard1  network=192.168.101.0  comment="rovera wg subnet"
add address=192.168.151.1/24 interface=wireguard1  network=192.168.151.0 comment="frongia wg subnet"
add address=192.168.201.1/24 interface=wireguard1  network=192.168.201.0 comment="geometra wg subnet"
add address=192.168.251.1/24 interface=wireguard1  network=192.168.251.0 comment="eberhofer wg subnet"
add allowed-address=192.168.25.2/24  interface=wireguard1 public-key="paste key here" comment="genione admin device1 - laptop"
add allowed-address=192.168.25.3/24  interface=wireguard1 public-key="paste key here" comment="genione admin device2 - smartphone"
add allowed-address=192.168.51.2/24  interface=wireguard1 public-key="paste key here" comment=impianti peer1"
add allowed-address=192.168.51.3/24  interface=wireguard1 public-key="paste key here" comment=impianti peer2"
add allowed-address=192.168.101.2/24  interface=wireguard1 public-key="paste key here" comment="rovera peer1"
add allowed-address=192.168.101.3/24  interface=wireguard1 public-key="paste key here" comment="rovera peer2"
add allowed-address=192.168.151.2/24  interface=wireguard1 public-key="paste key here" comment="frongia peer1"
add allowed-address=192.168.151.3/24  interface=wireguard1 public-key="paste key here" comment="frongia peer2"
add allowed-address=192.168.201.2/24  interface=wireguard1 public-key="paste key here" comment="geometra peer1"
add allowed-address=192.168.201.3/24  interface=wireguard1 public-key="paste key here" comment="geometra peer2"
add allowed-address=192.168.251.2/24  interface=wireguard1 public-key="paste key here" comment="eberhofer peer1"
add allowed-address=192.168.251.3/24  interface=wireguard1 public-key="paste key here" comment="eberhofer peer2"
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.1
set servers=8.8.8.8
/ip firewall address-list
add address=192.168.20.0/24  list=Authorized  comment="management network"
add address=192.168.25.0/24  list=Authorized comment="admin wg subnet"
add address=192.168.99.2 list=Authorized comment="admin OffBridge"
add action=accept chain=input  connection-state=established,related,untracked
add action=accept chain=input comment="WG handshake" dst-port=15511 protocol=udp
add action=accept chain=input comment="admin access" in-interface-list=TRUSTED src-address-list=Authorized
add action=accept chain=input comment="user to services" in-interface-list=LAN dst-port=53 protocol=udp
add action=accept chain=input comment="user to services" in-interface-list=LAN dst-port=53 protocol=tcp
add action=drop chain=input comment="drop all else"    {   insert this rule  last  }
add action=accept chain=forward  connection-state=established,related,untracked
add action=drop chain=forward comment="internet traffic"  in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="impianti wg to subnet"  in-interface=wireguard1 src-address=192.168.55.0/24  dst-address=192.168.50.0/24
add action=accept chain=forward comment="roverai wg to subnet"  in-interface=wireguard1 src-address=192.168.101.0/24  dst-address=192.168.100.0/24
add action=accept chain=forward comment="frongia wg to subnet"  in-interface=wireguard1 src-address=192.168.151.0/24  dst-address=192.168.150.0/24
add action=accept chain=forward comment="geometra wg to subnet"  in-interface=wireguard1 src-address=192.168.201.0/24  dst-address=192.168.200.0/24
add action=accept chain=forward comment="eberhofer  wg to subnet"  in-interface=wireguard1 src-address=192.168.251.0/24  dst-address=192.168.250.0/24
/system clock
If any of the assumptions are incorrect, clearly things change.
You don’t have a management vlan, so I added one, but perhaps your impianti vlan is your admin working vlan and you consider it a trusted vlan etc… lots of moving parts here.
Another point did you want the users coming in on wireguard, going to the subnets, to have access to the internet or just their singular LAN subnets?
